Old 02-01-2005, 02:15 PM   #11476
Thraex's Avatar
The T1R is A very good car, I think it;s the best you can buy for that price (in europe).
It's a bit heavier than A evo 2 so it's a bit slower,
but if your A club racer you don't really need to have A lighter car.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 02-01-2005, 02:18 PM   #11477
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
how much heavier? can upgrading it to the T1 FK specs make it lighter?
RCNitroDude999 is offline   Reply With Quote
Old 02-01-2005, 02:25 PM   #11478
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Hey guys, got a problem hopefully someone on here can solve. I have a Evo II with the aluminum from steering knuckles, I need to remove the axle/bone to replace the bone (it is bent) but everything seems locked together.
I tried lightly tapping out he axle, but not luck, it looks like the aluminum is flared out, any suggestions???
Thanks in advance!
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 02-01-2005, 02:30 PM   #11479
litespeed-dom's Avatar
Thanks in advance!
Use a very small file to file down the flare, or if you have the right tool, a dremel will be the quickest.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 02-01-2005, 02:35 PM   #11480
dado11g's Avatar
Send a message via ICQ to dado11g Send a message via AIM to dado11g Send a message via Yahoo to dado11g
yes, the chassis is quite a big difference. and if you really want that little bit more weight off then go for the FK bulkheads
dado11g is offline   Reply With Quote
Old 02-01-2005, 02:39 PM   #11481
Thraex's Avatar
I don't know precisely how much heavier it is, but you can upgrade the T1R to A FK if you want.
Though you shouldn't forget that there's A pricetag on that!
Thijs van M[HPI/HB]
Old 02-01-2005, 03:06 PM   #11482
NVisible's Avatar
im very slowly upgrading my evo2 to FK specs (sorta) im sure its going to cost me a pretty penny.
NVisible is offline   Reply With Quote
Old 02-01-2005, 03:34 PM   #11483
Mike Mandio's Avatar
Thanks in advance!
John, those walls at Mimi's are pretty hard aren't they. When you whack the walls the aluminum tends to mushroom slightly. Place a small file against the flare where the locking clip goes and rotate the axle against the file to remove some of the metal. From experience, I can tell you from experience that you'll need a little more than light tapping to get it out. Replace them with the spring steel axles.
Mike Mandio is offline   Reply With Quote
Old 02-01-2005, 03:34 PM   #11484
Oasis's Avatar
Trader Rating: 36 (100%+)
Why..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 02-01-2005, 04:44 PM   #11485
New parts from Xray:
Part number: # 302160 Short Suspension Arm - Front Lower - C-Hub Hard
Part number: # 303160 Short Suspension Arm - Rear Lower - C-Hub Hard
Part number: # 302321 Composite C-Hub Front Block, Right - Medium - 1.5
Part number: # 302322 Composite C-Hub Front Block, Left - Medium - 1.5
Part number: # 302323 Composite C-Hub Front Block, Right - Hard - 1.5
Part number: # 302324 Composite C-Hub Front Block, Left - Hard - 1.5
Part number: # 302325 Composite C-Hub Front Block, Right - Hard - 3
Part number: # 302326 Composite C-Hub Front Block, Left - Hard - 3
Part number: # 302327 Composite C-Hub Front Block, Right - Medium - 4.5
Part number: # 302328 Composite C-Hub Front Block, Left - Medium - 4.5
Part number: # 302329 Composite C-Hub Front Block, Right - Hard - 4.5
Part number: # 302330 Composite C-Hub Front Block, Left - Hard - 4.5
Part number: # 302331 Composite C-Hub Front Block, Right - Hard - 6
Part number: # 302332 Composite C-Hub Front Block, Left - Hard - 6
mindrev is offline   Reply With Quote
Old 02-01-2005, 04:51 PM   #11486
BlackKat's Avatar
damn c-hubs...sounds like the problem I had back in the day with the hpi cars, I dont wanna have to relive that nightmare again
I've screwed a carbon plate upper front bumper brace, but I'm yet to break a medium 3 degree C-hub (which I've been using the whole time I've had the car)
BlackKat is offline   Reply With Quote
Old 02-01-2005, 06:03 PM   #11487
Send a message via AIM to greencactus3
anyone here currently running a Xray T1 Raycer? Im looking to see what your opinion is on it, how durable it is, and if any parts or upgrades should be installed before racing it.
yea ive been running my t1r. just bought a extreme rc chassis for it from marshall havent tried it out yet. waiting for my eccentric hub carriers and fk battery holders.
the t1r itself is VERY nice. (thank you jon,) yea. only things ive broken are c hubs. and one arm but that was a big hit.
i like my t1r. and yea. its fine for me except for the weak chubs. really considering dropping $50 for the tamale al ones. ugh so expensive tho lol. and right now im wondering if i should get some springs or some low ratio pulleys first. i only run stock. and handles nicely i think. sure its not as planted as it might be with the best stuff but its completely doable for me as of now. and im sure you can mill a bit off the bulkheads if you really need to. and replacing the tub chassis to carbon fiber made it quite lighter and a LOT stiffer. shoulda at least bought a stiffer upper deck a long time ago
greencactus3 is offline   Reply With Quote
Old 02-01-2005, 06:22 PM   #11488
JDXray's Avatar
Send a message via AIM to JDXray
lol no problem man, great to hear that your running well with it.
Jon
JDXray is offline   Reply With Quote
Old 02-03-2005, 07:00 AM   #11489
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
xray use metric or standard? metric im assuming...
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 02-03-2005, 07:09 AM   #11490
ddesros2's Avatar
Question about X-Ray T1:
I'm racing my T1 on carpet with foams, I have diff in front and rear, when I hold one front wheel and hold the spur and turn the other, the diff slips. How much slippage should there be, or should there be any??
Note: I have a TC3 as well and it doesn't slip like that.
Let me know. Thanks.
ddesros2 is offline   Reply With Quote
