Old 01-15-2005, 08:35 PM   #11281
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
I haven't read this thread at all really, but a quick ?- why are you guys using Tamiya shocks, aren't the xray shocks any good?
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-15-2005, 08:36 PM   #11282
protc3's Avatar
i used the xray eyelets and spring retainers and it worked for me with rubber tires.i am also trying the corally rdx shocks on the car tommorow.i wanna see how they work.the shocks seem really nice.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-15-2005, 08:37 PM   #11283
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
It isn't that the XRAY shocks aren't any good, it is that the Tamiya shocks are soooo much better. The XRAY/ Serpent shocks are fine for asphalt, the Tamiya ones are just better all the way around.
tc3stocker is offline   Reply With Quote
Old 01-15-2005, 08:51 PM   #11284
When I mounted the TRF shocks on my FK I used the stock X-Ray shock collers with Tamiya knuckles (closed-end) ... the ones that Tamiya uses for their steering knuckles.
My "RC technical english" is not so good so could you post pictures of collars and especially of knuckles or try to explain for me what are those parts exactly
cvt01 is offline   Reply With Quote
Old 01-15-2005, 09:13 PM   #11285
NVisible's Avatar
Default Parma Foams
Anyone using the Parma foam tires? Do they bolt on with the stock hardware?
NVisible is offline   Reply With Quote
Old 01-15-2005, 09:29 PM   #11286
asw7576's Avatar
How many Xray t1 do you have ? Is it necessary to have another xray, perhaps 1 for play and 1 for race ? recently my Lhs is selling xray t1 very cheap ( 20 bux cheaper though ) but it only last until 30 January 2005.
Old 01-15-2005, 09:35 PM   #11287
Rob Mincey's Avatar
Default Re: Parma Foams
You can't use 28mm foam tires in the rear of the car without some sort of modification. You need to grind down the rear arm with a Dremel tool. I posted a picture that shows where, and how much a page or two ago in this thread.
Rob
Rob Mincey is offline   Reply With Quote
Old 01-15-2005, 09:39 PM   #11288
Rob Mincey's Avatar
They work fine if you get them built correctly, but they're difficult (for most of us, anyway) to get built correctly. The Tamiya shocks build easily and are super smooth since the shock bodies and pistons are flourine coated.
Rob
Old 01-15-2005, 10:02 PM   #11289
Michal101's Avatar
They work perfect on my FK without any mods when mountiing the rear shocks on the inner hole of the rear A arm. OR you can also add a small 1 mm wheel spacer when you mount the rear shocks on the outer most hole on the A arm.
I hope this hleps.
Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 01-15-2005, 10:07 PM   #11290
NVisible's Avatar
Default Re: Re: Parma Foams
Rob
seen!. thanks a ton
Old 01-15-2005, 11:01 PM   #11291
kidDynomite's Avatar
Hope some of you guys are still up. I have an early race tomorrow and I have put my Team Tamale Chubs on and need to know if by measuring my droop, can I still get the same settings from under the chub screw?
I don't have any composite chubs to compare and I doubt anybody, but me, will be running Tamales tomorrow.
Thanks!
kidDynomite is offline   Reply With Quote
Old 01-15-2005, 11:57 PM   #11292
I just picked up a Xray FTK.. what eles will I need to run it on carpet with Foam tires. I got my LHS to order me a front diff. Is there anything eles I will need to tune the car in to the track ?
Thanks Guys for any info..
John Q is offline   Reply With Quote
Old 01-15-2005, 11:58 PM   #11293
Rob Mincey's Avatar
The carpet front shock tower is nice. You'll also need the ackerman extensions, and shock springs.
Rob
Old 01-16-2005, 12:08 AM   #11294
wow. you dont have part # do you ?
do they make swaybars for the car ?
Old 01-16-2005, 07:36 AM   #11295
theisgroup's Avatar
team tamale has shock retainers that lower the mount for the shocks.If you want to run 60mm tire, that is the best way to get the ride hight down.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
