Old 01-12-2005, 10:52 PM   #11251
Nismo,
Looks like a BMI chassis, correct? I see you are using the Team Tamale rear camber link blocks. Did the mounting holes on the shock tower line up for you?
Jamie Corrado is offline   Reply With Quote
Old 01-13-2005, 02:59 AM   #11252
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
no one got a setup for polished wood then??
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 01-13-2005, 06:48 AM   #11253
ChrisP's Avatar
Nismo....make sure you bring a spare body with you for this weekend.
One of the locals painted a 12th scale body with Spazstix paint that looked to be a similar colour and the car looked great sitting still, but there were areas of the track where the colour would shift and look dangerously close to the colourof the ozite causing him to momentarily lose track of the car.
ChrisP is offline   Reply With Quote
Old 01-13-2005, 07:19 AM   #11254
R/C Tech Charter Subscriber
Originally posted by Jamie Corrado
Nismo,
It is the BMI 350 chassis. The holes didn't line up on the BMI shock towers but the camber link is parallel to the driveshaft.
NismoSkyline17 is offline   Reply With Quote
Old 01-13-2005, 07:21 AM   #11255
Ya I just wanted to have a body of a different color.
Old 01-13-2005, 07:44 AM   #11256
ChrisP's Avatar
It might work fine on your track with your lighting..and it looks great....just wanted to pass on a local's experience so that you're prepared in case it doesn't work out
Old 01-13-2005, 05:02 PM   #11257
NVisible's Avatar
Default axle angles?
Ive been trying to setup my EVO2 for an upcoming indoor race, following Josh Cyruls setup as close as i can (without going to c-hub) and im noticing an extreme angle in my front axles. This is a bad thing isnt it? Whats the best way to level them out?
NVisible is offline   Reply With Quote
Old 01-13-2005, 05:38 PM   #11258
Send a message via AIM to greencactus3
how low are you running it?
greencactus3 is offline   Reply With Quote
Old 01-13-2005, 05:41 PM   #11259
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
could it be cuz u arent running the c-hub
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 01-13-2005, 06:37 PM   #11260
ChrisP's Avatar
A C-hub setup for a high traction foam race may not translate well to a rubber pivotball car...
Although...the arms are the same effective length so maybe? it could be close?
The axle angle should be the same on either C-Hub or Pivot ball....the center of the tire is still where the axle connects, and the outdrive is still the other end...period...
If you have ever had C-hub on the car though, make sure you are usingthe proper front axles, as thereis a difference in the wheel hex link (which MAY effect angle)
Old 01-13-2005, 07:48 PM   #11261
NVisible's Avatar
well, im planning on putting foam on, i just havent recieved them yet.
All i did was add 3deg of anti-dive and its worked out. Im just confused as how he can run 0 anti-dive and not have such an extreme angle on his axles, and running a 4mm ride hieght. Perhaps it is the C-Hub suspension. I guess ill find out once i get the rest of the parts for it. Thanks for your help guys.
Old 01-14-2005, 10:05 AM   #11262
Slingblade's Avatar
Default rubber?
I am really considering buying the t1 fk. How is it on rubber? Is the thick chassis really needed for carpet? LHS doesn't have it, where is the best place to buy it? This has to be one of th best quality kits on the market today. I am REALLY impressed! Thanks in advance, Slinger
Slingblade is offline   Reply With Quote
Old 01-14-2005, 10:15 PM   #11263
Default Tamiya shocks help
Hi Guys,
I need your help. I bought the trf shocks but can't fit them to my xray.
There are two types of plastic parts fits to the lower end of the piston rod a longer one and a shorter one. I've tried both but the ride height is either 5mm or 10mm and not adjustable.
What did I wrong, please help.
cvt01 is offline   Reply With Quote
Old 01-14-2005, 11:06 PM   #11264
asw7576's Avatar
5mm ride height is fine ( the lowest height for my taste ). If you want higher ride height the best idea maybe you can use the longer end ball plastic and add 1 or 2 white plastic ring below the piston hole to compensate 10mm ride height. It should be 6mm or 7mm.
If you need more droop, you raise the collar. Perhaps you fill in the oil slightly too much if it doesn't give you droop effect.
I suggest to use alluminium lightweight ball connector instead the brass ball connector. That way you don't ruin the groove at suspension arms.
Old 01-15-2005, 08:09 AM   #11265
The 5mm would be fine but if the foam tire wear more it will become less and I can't readjust it.
