Old 01-12-2005, 05:28 AM   #11236
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
technically 1.77777 rounds to 1.78 so however you want to look at it...thats probably where the 78 is coming from
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 01-12-2005, 06:28 AM   #11237
OleC's Avatar
Ah! So I should probably adjust my gearing charts a bit then.
Strange that they have rounded the wrong way though....
OleC is offline   Reply With Quote
Old 01-12-2005, 06:33 AM   #11238
rdub202's Avatar
i would go with what the manual says, i guess i was just playing devil's advocate to where the 78 is coming from.
Old 01-12-2005, 03:19 PM   #11239
TTT
Jamie Corrado is offline   Reply With Quote
Old 01-12-2005, 06:25 PM   #11240
Send a message via AIM to (V)r>??@uD@ Send a message via Yahoo to (V)r>??@uD@
hey guys can you fit 26mm foams on the front and 30mm foams on the back of a standard Xray T1Raycer
(V)r>??@uD@ is offline   Reply With Quote
Old 01-12-2005, 06:36 PM   #11241
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
nope
dontfeelcold is offline   Reply With Quote
Old 01-12-2005, 06:43 PM   #11242
so you can even use 26mm foams what happens if you use front foams on the back and front
Old 01-12-2005, 06:47 PM   #11243
R/C Tech Charter Subscriber
Just use 28mm foams all the way around. They fit and that's what most use. As for compounds:
Jaco- Orange double pink/ double pink or Orange purple/ purple
Parma- Magenta/ cyan or Plaid/ purple
TRC- Plaid/ purple
All of which are 28mm.
NismoSkyline17 is offline   Reply With Quote
Old 01-12-2005, 07:26 PM   #11244
Rob Mincey's Avatar
They fit if you file down the rear arms. Easy to do and makes 'em fit like a dream.
Rob
Rob Mincey is offline   Reply With Quote
Old 01-12-2005, 08:55 PM   #11245
were do you file down ?? do you have pic to explain it??
Old 01-12-2005, 09:04 PM   #11246
Rob Mincey's Avatar
Here's a pic.
Rob
Old 01-12-2005, 09:05 PM   #11247
Rob Mincey's Avatar
See where the shock attatches to the arm? Grind down the arm where the shock mounts until everything is flush. Drill the shock hole all the way through the arm BEFORE grinding.
Rob
Old 01-12-2005, 09:53 PM   #11248
thanks rob
Old 01-12-2005, 10:46 PM   #11249
I just can't leave well enough alone.
Old 01-12-2005, 10:47 PM   #11250
And new body for this weekend.
