Old 01-11-2005, 08:01 PM   #11221
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Originally posted by Jamie Corrado
Danjoy,
Check cefx.net again. The Novak 2004 and Nationals 2004 are foam set-ups. The rest are rubber tire set-ups. Just look in the upper right hand corner of the set-up sheet and it specifies which type of tire Josh was running. These will give you a good starting point and you can make adjustments to suit your driving style and track conditions.
Jamie,
Thanks for that, would both setups OK to use in asphalt track as well.
Thanks in advance
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-11-2005, 08:03 PM   #11222
Anyone know a starting number for roll out for a stock motor, 19t and something like a 10t mod. (you know spur/pinion*trans ratio*tire circumference)
DJG24 is offline   Reply With Quote
Old 01-11-2005, 08:09 PM   #11223
Danjoy,
The asphalt set-ups may be a bit to soft for carpet racing.
DJG24,
Let me check my paperwork and I'll get back to you with that info.
Jamie Corrado is offline   Reply With Quote
Old 01-11-2005, 08:11 PM   #11224
Trader Rating: 74 (100%+)
Default ROLLOUT
DJG24, and Jamie, I beleive, it was around 23.78 for your final rollout. for 19t. And stock was pretty much the same...
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-11-2005, 08:12 PM   #11225
dado11g's Avatar
Send a message via ICQ to dado11g Send a message via AIM to dado11g Send a message via Yahoo to dado11g
with foams trued to 2.25", i use a 128t spur and a 33t pinion in stock, a 128-30 in 19t, and with a 9turn mod 128-26
this is on an indoor carpet track.
dado11g is offline   Reply With Quote
Old 01-11-2005, 08:23 PM   #11226
Michal101's Avatar
Originally posted by theisgroup
you will want to run them if you are running on a fast med to high bite carpet. It smooth's the from steering out. Alot of the guys are going to the 6 degree blocks and then smooth the steering alittle with the extensions.
Please explain what you mean by "It smooths the front steering out"?
Since I have found the steering of my FK to be very smooth and concise with the BMI chassis.
Just trying to get an edge on the competition.
Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 01-11-2005, 08:40 PM   #11227
Originally posted by NismoSkyline17
Anyways anyone use the ackerman extensions on their car for carpet? I don't see any of our local racers using them. I have a set (I think they were home made from an old shock tower) and they don't seem to fit my aluminum steering blocks. Also is it the Tamiya 5.5 aluminum spacer set that people are using to raise the camber links on the hubs? I had some that I though were the correct size but finally measured them and they aren't even close so I just ordered the Tamiya ones. I remember reading somewhere that those will work. [/B]
Yes, the Tamiya 5.5 aluminum spacers are the ones that will fit the car.
duckman996 is offline   Reply With Quote
Old 01-11-2005, 08:53 PM   #11228
Scrad's Avatar
Trader Rating: 15 (100%+)
The extentions make the car less twitchy around center.
Scrad is offline   Reply With Quote
Old 01-11-2005, 09:12 PM   #11229
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
the kit does not come with a turnbuckle wrench per say. xray has a really nice spring steel one that you can purchase.
The FK Kit does come with a turnbuckle wrench. It is not the same spring steel one they sell but rather a flat metal wrench. I was surprised to see they started including them in their kits.
g_bruin is offline   Reply With Quote
Old 01-11-2005, 09:59 PM   #11230
ChrisP's Avatar
Had a brain fart at the track today...
what's the internal ratio on the FK???
ChrisP is offline   Reply With Quote
Old 01-11-2005, 10:02 PM   #11231
danjoy25's Avatar
Old 01-11-2005, 10:08 PM   #11232
ChrisP's Avatar
That's what I thought......but had somebody arguing otherwise....
Old 01-12-2005, 02:23 AM   #11233
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Originally posted by danjoy25
1.77
Actually the internal ratio is 1.78
/Arvid
Airwide is offline   Reply With Quote
Old 01-12-2005, 03:21 AM   #11234
OleC's Avatar
Are you sure about that?
Every Xray document say it's 1.77.
OleC is offline   Reply With Quote
Old 01-12-2005, 03:50 AM   #11235
Airwide's Avatar
I'm positive! divide the diff pulley's 32 teeth by the main shaft's 18 teeth and you get 1.777777...
/Arvid
