Old 01-11-2005, 10:41 AM   #11206
ChrisP's Avatar
I'll still place the order..Ijust need to find out how to get in touch with either of these guys
ChrisP is offline   Reply With Quote
Old 01-11-2005, 10:42 AM   #11207
Scrad's Avatar
Trader Rating: 15 (100%+)
Did you guys ever consider that they were at the Novak race?
Anyways for those of you that have the roll center bridge and never use the inner holes anymore I found out that you can cut the middle part out of the bridge and turn them around to use shorter links. You don't need to buy the extension piece.
Scrad is offline   Reply With Quote
Old 01-11-2005, 10:52 AM   #11208
ChrisP's Avatar
Figured that they may be at theNovak race....but have seen other responses during the time frame....
That's why I'm not panicking..but I have been trying to get ahold of people for more than just this weekend
Old 01-11-2005, 10:53 AM   #11209
R/C Tech Charter Subscriber
They weren't at the Novak race a month ago or 3 weeks ago when I sent emails and money. Rubberneck sent me an email 2 months ago about bumpers and that's how I received the pricing and paypal address. Then when I had the money I emailed them and then sent the money. Then when I didn't receive an email or bumper, I decided to eat the $12 and ordered a Pdub bumper about 3 weeks ago; didn't receive anything sent them an email a week after the money and all I got was the automated email from them and at the same time sent an email and PM to Rubberneck. Just let me know if you get in touch with them.
Anyways anyone use the ackerman extensions on their car for carpet? I don't see any of our local racers using them. I have a set (I think they were home made from an old shock tower) and they don't seem to fit my aluminum steering blocks. Also is it the Tamiya 5.5 aluminum spacer set that people are using to raise the camber links on the hubs? I had some that I though were the correct size but finally measured them and they aren't even close so I just ordered the Tamiya ones. I remember reading somewhere that those will work.
NismoSkyline17 is offline   Reply With Quote
Old 01-11-2005, 02:19 PM   #11210
Scrad's Avatar
I'm using the ackerman extensions on my plastic steering blocks. But I had them mounted on some aluminum ones too. I wouldn't put them on aluminum blocks, because I would think they would break pretty easy if you hit something.
I can't really tell what they did for the car, because my setup sucked before I put them on. But Cyrul said it smoothes out the steering, less twitchy around center.
Old 01-11-2005, 04:01 PM   #11211
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
Default setup help
anyone got a setup for a games hall, or polished wood floor?
I have a T1 R converted to just about FK spec.
thanks
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 01-11-2005, 04:29 PM   #11212
NVisible's Avatar
Default Turnbuckle Wrench
I dont have the Turnbuckle Wrench that comes with the Kit, and i really hate using needle nosed pliers as they scratch the living hell out of the metal, so im looking for something better. Is there a better way to do this? what do people use when they dont have the factory wrench?
NVisible is offline   Reply With Quote
Old 01-11-2005, 04:33 PM   #11213
theisgroup's Avatar
the kit does not come with a turnbuckle wrench per say. xray has a really nice spring steel one that you can purchase.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-11-2005, 04:37 PM   #11214
theisgroup's Avatar
you will want to run them if you are running on a fast med to high bite carpet. It smooth's the from steering out. Alot of the guys are going to the 6 degree blocks and then smooth the steering alittle with the extensions.
don't use the alum steering block you will bend them. On the plastic they will just break. lot cheaper that way. One mod that you can do is grind down the servo saver to just the inner mounts for the steering bellcrank. basically what is happening is that if you take a board the bellcrank hits the bulkhead and since something has to give it will be the steering block. so grinding down the bellcrank will actually reduce the size and keep the steering block from breaking. You can also use teh servo saver/steering bell crank from the t1 evo, it only has the inner ackerman mounts.
yang lai
Old 01-11-2005, 04:38 PM   #11215
theisgroup's Avatar
per josh, never take them off.
yang lai
Old 01-11-2005, 04:38 PM   #11216
NVisible's Avatar
ahh ok. i kept reading in my setup book about "use your turnbuckle wrench" and i assumed it came with one, as my xxx-s came with one in the past. Thats what i get for assuming
thanks for the info!
Old 01-11-2005, 04:59 PM   #11217
danjoy25's Avatar
Trader Rating: 37 (100%+)
Default Setup needed
Can anyone help me with a base setup for an asplalt track using foam tires? I will be using a 27 turn stock motor on my FK.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-11-2005, 05:44 PM   #11218
Danjoy,
Check cefx.net for an asphalt set-up.
Jamie Corrado is offline   Reply With Quote
Old 01-11-2005, 07:03 PM   #11219
danjoy25's Avatar
Just did, but would they also be good for foam tires as all the set-ups are for rubber tires.
Originally posted by Jamie Corrado
Danjoy,
Old 01-11-2005, 07:50 PM   #11220
Danjoy,
Check cefx.net again. The Novak 2004 and Nationals 2004 are foam set-ups. The rest are rubber tire set-ups. Just look in the upper right hand corner of the set-up sheet and it specifies which type of tire Josh was running. These will give you a good starting point and you can make adjustments to suit your driving style and track conditions.
