Old 01-10-2005, 07:14 AM   #11161
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Originally posted by DavidAlford
Does anyone know offhand what size the holes of xray pistons are? 56 maybe?
Anyone?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-10-2005, 07:50 AM   #11162
work's Avatar
Default Re: spur gears
Originally posted by zinger77
i,am looking for 64 pitch spur gears that will fit fk.
can any tell will i would be able to find some.
thanks
zinger
You can use Speedmind or Tamiya (the one from the 04, 414 etc)
work is offline   Reply With Quote
Old 01-10-2005, 07:55 AM   #11163
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
I need some suggestions on what to get for my soon to come FK's.
I am getting a BMI chassis, ceramic bearings, spring steel hexes, al roll center bridge, aluminum rear uprights, front spindles, and front carriers, and lastly, I am getting a JWerks titanium screw kit.
Is there anything else I need to get?
tc3stocker is offline   Reply With Quote
Old 01-10-2005, 08:25 AM   #11164
ChrisP's Avatar
The Rear Aluminum roll center standoffs may be better than the bridge..allows you to use the shorter rear link position and gets the arms about as close as possible to being parallel
ChrisP is online now   Reply With Quote
Old 01-10-2005, 08:41 AM   #11165
JCB
JCB's Avatar
thanks
zinger
the PRS gears are really sweet! I'm currently using the 128T for my FK.
www.precisionracingsystems.com
hope this helps...
JCB is offline   Reply With Quote
Old 01-10-2005, 09:49 AM   #11166
kidDynomite's Avatar
Winsorguy is right. You dont need the bridge, just the Rear Aluminum roll center standoffs. Super stiff BMI chassis is a must (batteries moved forward and a few mm closer together). Xray bearings are top notch. They come degreased, but lubed, and are the most free bearings in any kit. If you get a spare set of Xray bearings, those for some reason are even more free, I mean super free. I could literally spin them in my fingers for about 10sec. If you get anything else aluminum for you car, get Team Tamale C-hubs. And forget about the titanium screw kit. You shouldn't mix Ti with Alum. because those two metals will "coldfuse" together without any protective barriers between them. The kit already comes with some light weight alum. hex screws for all the light stress areas. And strong steal screws for high stress areas. Plus the car is nearly 150g below legal weight limit. More than enough room to add the BMI and some alum. parts.
kidDynomite is offline   Reply With Quote
Old 01-10-2005, 12:42 PM   #11167
NVisible's Avatar
Default Gearing
Im wondering what to do about gearing on my low ratio evo2.
I could keep my 124T spur and put a 30T pinion, or buy the stock 93T spur and use a 27T pinion.
so my options are
30/124
27/93
for a stock motor. Both yeild a similar ratio but will one work better, or is there little difference at all?
NVisible is offline   Reply With Quote
Old 01-10-2005, 12:47 PM   #11168
theisgroup's Avatar
i would assume that the 124 is 64pitch and the 93 is 48 pitch. the 124 will give you a little more tunign in the long run. Usig 64 pitch gears you can fine tune your ratio a little more. either way, you want to ge tthe largest spur to keep the belt from dragging on the motor.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-10-2005, 12:52 PM   #11169
NVisible's Avatar
ah great. thanks for your help
Old 01-10-2005, 12:55 PM   #11170
Default spur gears
anything larger then a 124 spur out there
zinger77 is offline   Reply With Quote
Old 01-10-2005, 12:57 PM   #11171
theisgroup's Avatar
you can get up to a 134.
yang lai
Old 01-10-2005, 12:59 PM   #11172
rayhuang's Avatar
19 turn 124t
Stock 128-132
mod 128-132
I would say if you own a Xray-you should have at least two different sizes-124 and 128 at the least. But its best to have 124, 128, 130 and 132.
Old 01-10-2005, 12:59 PM   #11173
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Duckman - thanks for the reply. I may give the Tamiya shocks a shot in the future. If there is anything Xray could fix about the car, it's the shocks. I'm sick of them already, and I've only had the car for a few weeks.
Josh
Speedo is offline   Reply With Quote
Old 01-10-2005, 01:00 PM   #11174
NVisible's Avatar
yea i just got this actually. just trying to get it together in time for a race in a few weeks. I'll start adding parts to the collection for it when i have more time.
Old 01-10-2005, 01:04 PM   #11175
where can i buy the larger spurs?
