Old 01-09-2005, 03:28 PM   #11146
chach's Avatar
kimbrough spur gears fit fine
chach is offline   Reply With Quote
Old 01-09-2005, 03:38 PM   #11147
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
PRS spurs are awesome.
Do the Tamiya fluorine coated shocks fir the FK? Do any modifications need to be made, and dimensions wise, how are they different?
Speedo is offline   Reply With Quote
Old 01-09-2005, 03:38 PM   #11148
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Does anyone know offhand what size the holes of xray pistons are? 56 maybe?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-09-2005, 05:31 PM   #11149
Cool, thanx for the pix JDXray. Which servo are you using? Because I've tried to install my Airtronics 357 in that position, but it just didn't fit. I'll get a picture of what I'm talking about in a little bit. Thanx.
skinart76 is offline   Reply With Quote
Old 01-09-2005, 05:36 PM   #11150
ChrisP's Avatar
I was able to get my JR 8417 to fit in that position, but it required that I remove a little material from that hinge pin mount and not use the bottom screw on that side
ChrisP is offline   Reply With Quote
Old 01-09-2005, 05:45 PM   #11151
John Fontaine's Avatar
Send a message via AIM to John Fontaine
Ditto, I got PRS gears and I love em.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 01-09-2005, 06:11 PM   #11152
Default spur gears
where can i find prs spur gears?
zinger77 is offline   Reply With Quote
Old 01-09-2005, 06:14 PM   #11153
dado11g's Avatar
Send a message via ICQ to dado11g Send a message via AIM to dado11g Send a message via Yahoo to dado11g
Default wow!
wow guys. i got this evo2 a couple months ago(used). it drove so-so. it was better than the old tc3 but wasnt winning material. now a couple $100 later, with the bmi 350, jacos, springs, short arms... THIS THING HAULS! i just raced it for the first time and took over the B-main (because of horrible qualifying). all i have to say is wow. this was my first onroad race because im an offroad racer. dbl pink/orange and dbl pink tires with purple and violet springs on a bmi 350 chassis. now i need carpet towers and ill be set.
thank you xray!
dado11g is offline   Reply With Quote
Old 01-09-2005, 06:15 PM   #11154
dado11g's Avatar
btw i run 128t kimbrough spur with a 33t pinion with a monster stock. that works pretty good.
Old 01-09-2005, 06:21 PM   #11155
To mount Tamiya shocks on the FK, you need: four 3 x 8 (10) mm button-head screws, 6 x 2mm spacers, and all the regular tamiya mounting gear (threaded ball-ends). The ball-ends screw right on the same long set-screws that you use for the X-Ray shocks. The only mod that you will need to make is to the shocks on the rear ... you need to change the bottom ball-cups to longer ones or you will not make a 5 mm ride-height.
I made the change and I found the car to be more consistent. I still use XRay springs. I have always had great luck with Tamiya shocks so I put them on the car.
Here's a photo:
duckman996 is offline   Reply With Quote
Old 01-09-2005, 08:13 PM   #11156
JDXray's Avatar
Send a message via AIM to JDXray
Ya no problem. I am using a hitec servo, but i think i am gonna upgrade to a futaba 9550 or KO pretty soon. If you think about it any servo should work even if it is slow because the xray has tons of steering.
JDXray is offline   Reply With Quote
Old 01-09-2005, 08:17 PM   #11157
I run a 9550 in my xray with great success. BTW, the Tamale C-hubs are awesome!!!!!!!! I never knew how bent my Xray ones were until I installed these Tamale ones. Definately a MUST have if you run alum C-hubs.
John
Old 01-09-2005, 09:24 PM   #11158
Cool, thanx for all your help. I was just hesitant on installing the servo on to the back set of mounting holes, when they are that far apart. I've finally switched over, hopefully everything will stay tight.
Before Pix:
After:
Old 01-09-2005, 09:54 PM   #11159
ChrisP's Avatar
To me that's the nicest part aboutthe XRC chassis...
it moves the servo back a little bit so it can sit inboard more
Old 01-10-2005, 04:57 AM   #11160
JDXray's Avatar
at skinart76- i guess you can leave your servo where it is. But you mounted it on the back of the posts if you leave the posts where they are and just put the servo ears on the other side and screw them in, it shold fit nicely.
