Old 01-04-2005, 12:00 PM   #11116
theisgroup's Avatar
john tag, ygpm
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-04-2005, 02:05 PM   #11117
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
when you guys are racing ROAR events, how and where are you adding the weight we need to make limit.
I bought the center weights for the car, with the BMI chassis I only need to add 40 grams. With out it I was well under buy 140 grams.
Nick
JohnMatrix is offline   Reply With Quote
Old 01-04-2005, 02:33 PM   #11118
Jon Williams's Avatar
It's a wise decision on the part of Jason to place all the weight in the chassis. It's the lowest part of the car causing the center of gravity to be lowered as well. Yes, it is heavier because it's a superior graphite and also thicker as well.
Jon Williams is offline   Reply With Quote
Old 01-05-2005, 09:47 AM   #11119
I have my X-Ray T1FK and other touring car related items for sale. If interested click on http://rctech.net/forum/showthread.p...threadid=59239 for details.
Hondaguy is offline   Reply With Quote
Old 01-06-2005, 03:08 PM   #11120
Default Setup
Hey guys. I was setting up my car to Joshs '04 carpet nats setup(for a starting point) and noticed that the front is softer than the rear. Is this correct?
Downforce is offline   Reply With Quote
Old 01-06-2005, 03:21 PM   #11121
R/C Tech Charter Subscriber
What I changed from the setup and it seems that alot of people are doing this, is if you are running the side-by-side saddle packs like the stock or BMI 350 chassises run light purple springs up front (Pepto Bismal pink springs) and Violets in the rear. The setup he is using works perfectly if you are using the BMI split chassis. Thats all I did was change the springs and the setup works perfectly.
NismoSkyline17 is offline   Reply With Quote
Old 01-06-2005, 03:36 PM   #11122
kidDynomite's Avatar
That's what I did as well. But changes I made to suit my driving: Xray 30wt all around. 2 holes closed in front and all open in back. I set my front wheel toe to 0 and I used the 1 degree caster clips in the front hindge pin holders to give the pins 1 degree toe out. I also didn't max my wheel base. It's stock length at 258mm. Droop is at 1 in front and 5 in back. This set up lays it down for stock and 19T. The 350 chassis is a must for carpet.
A Josh tip: Cut off the unused outer holes on the steering/servo saver block. This usually hits the bulk heads during hard hits and will keep you from breaking steering blocks.
kidDynomite is offline   Reply With Quote
Old 01-06-2005, 04:19 PM   #11123
I second the servo saver tip removal idea. I actually just dremeled mine down (for visual sake ;-)) and it prevents breakage of steering arms.
Old 01-06-2005, 06:39 PM   #11124
theisgroup's Avatar
funny thing, the servo save on the original t1 is exactly that. just the 2 inner holes
yang lai
Old 01-06-2005, 06:49 PM   #11125
bad_boy99's Avatar
Default Need help with set-up!
hey guys,
i just got a t1 FK for christmas and i was wondering if anyone had any links to set-up pages for rubber tyres and ash felt or could tell some pointer??
cheers
bad_boy99 is offline   Reply With Quote
Old 01-06-2005, 11:58 PM   #11126
Default Re: Need help with set-up!
Originally posted by bad_boy99
hey guys,
cheers
CEFX.net has most of Josh's setups.
Old 01-07-2005, 01:16 AM   #11127
OleC's Avatar
There’s also a couple of good starting setups on the Xray website.
http://www.teamxray.com
OleC is offline   Reply With Quote
Old 01-07-2005, 12:01 PM   #11128
Dittto jdwca, the car looks so good and so well prepped... it's nice to find a mod to do to the car. I dremeled mine down clean to look factory done. I feel sorry for my buddy's Xray. He's so sloppy I offered to clean up his wiring and such overnight, just so I would be able to look at it next race day.
Old 01-07-2005, 12:16 PM   #11129
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
Hey guys I have a new t1fk chasisis for sale, never used first 45 plus shipping takes it.
weaponx is offline   Reply With Quote
Old 01-07-2005, 01:05 PM   #11130
NVisible's Avatar
Default Motor Screws
Seems i can never keep motor mounting screws around for any of my cars. I also cant seem to find the right size anywhere.
I belive the thread is 3mm but finding the right length is a pain as well.
Does anyone know a place where i can buy specific screws to mount my motor? i belive they are M3x8 Socket Head
NVisible is offline   Reply With Quote
