Old 01-01-2005, 03:01 AM   #11056
Jon Williams's Avatar
A closeup of the PDub bumper.
(As you'll see I rounded mine off some.)
Jon Williams is offline   Reply With Quote
Old 01-01-2005, 03:04 AM   #11057
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Why does everyone race foam in stock?
Out here in Cali we do the rubber on carpet for carpet and 19turn, sooooo much cheaper and no changing ride hight no chunking.
What made most places go foam and not rubber?
Just seems so much easier to do rubber.
JohnMatrix is offline   Reply With Quote
Old 01-01-2005, 03:09 AM   #11058
That's a can of worms, but...
Honestly, on carpet, I prefer foams. It's all we run in the Northeast. Rubber tires are good outside (i.e.: no mandatory changing of ride height/droop), but even then to run them properly and fast is just as expensive as foams if not more so.
I can run a set of Parma Cyans/Magentas starting at 57(!) and have a good setup on the car and get 12 runs out of them and they're down to 54.5. No chunking--nothing.
Old 01-01-2005, 04:43 AM   #11059
MrRolla's Avatar
Trader Rating: 29 (100%+)
Default Re: Futaba 9550 ?
Originally posted by jland
Has anyone used the 9550 servo. I had to take off some of the back of the servo horn to keep it from hitting the servo, is this normal?..
HAPPY NEW YEAR
Yeah i had the same problem, i just gor a stanley knife and cut the back of the servo horn off..
MrRolla is offline   Reply With Quote
Old 01-01-2005, 07:42 AM   #11060
NVisible's Avatar
Originally posted by jdwca
Nvisible - Trick wallpaper. It's up on my desktop now.
glad you like it
NVisible is offline   Reply With Quote
Old 01-01-2005, 11:36 AM   #11061
Here in Toronto, Canada, the largest class is the 19T rubber-tire class ... we are not running foam because rubber is more economical. Foam-mod is starting to get popular, however, no-where near 19T.
www.torontorc.com
duckman996 is offline   Reply With Quote
Old 01-01-2005, 11:39 AM   #11062
ChrisP's Avatar
How is Rubber more economical than foam when I'm being told prior to going to the Takeoff race that tires are best of only used for 1-2 runs????? whereas foams can last for huge amounts of time, only requiring to be trued occassionally?
ChrisP is offline   Reply With Quote
Old 01-01-2005, 11:41 AM   #11063
Default Re: Re: low ratio pullies
Originally posted by mazmorbid
I would suggest buying a NEW FK, you will spend money on the EVO2 i think, but nothing on the FK, depends the price of the EVO2 I guess?
I have both the EVO2 and the FK ... what money will he need to spend on the EVO2 that he will not have to spend on a FK?
Both cars are bullit-proof in design, the only difference is that the FK uses the short arms, and the EVO2 runs the longer arms .... I really have not seen too much of a difference between the two cars in their handling - it's all in driving style.
Old 01-01-2005, 11:45 AM   #11064
ChrisP's Avatar
And don't forget that you'll also in all likelihood need to buy at least a front diff for the FK....
Don't fal into the trap that you need the latest and greatest car with all the conceivable hopups...
The original Xray T1 is still competitive if set up properly.
If you are a top-lvel driver lookig to gain that last fraction of a second on your times then the extra option parts may make a difference...
scrub a wal once or twice and you may as well save your hopup money for other stuff
Old 01-01-2005, 11:49 AM   #11065
1-2 runs .... who told you that - they may have some set-up problems with their car?
At TORC (where the take-off race is being held) we get 4-6 weeks out of the tires with no problem ... I have a set that I use for practice that I have had for 4 months and they still work well. If you are going to be pitching your tires after every 1-2 runs - throw them my way ...
It's all about prep - making sure that they are clean before applying your tire - "goop".
Old 01-01-2005, 01:14 PM   #11066
ChrisP's Avatar
Sweet....
what do you consider proper prep though?
I'l be running on rubber for my first time at this race...(with my TC4....saving my Xray for Mod)
Old 01-01-2005, 01:24 PM   #11067
Cleaning the glueing surface with some motor spray or summit (i can't be bothered, works ok if you don't), and if you've got the time, removing the groove in the centre of the tyre (meant to give a more even tyre surface, i don't do that either because i'm lazy and don't have the time)
Chazz
Chazz is offline   Reply With Quote
Old 01-01-2005, 01:39 PM   #11068
BlackKat's Avatar
Chazz
Sanding the mold line (that line that goes along the center of a tire) will let your tires "come-in" quicker
I found that helps with my Take-Off's
BlackKat is offline   Reply With Quote
Old 01-01-2005, 04:45 PM   #11069
drx
drx's Avatar
Send a message via AIM to drx
I'll second that!
The PDub bumper is tremendous.
I find that the front end on my EVO2/C-Hub can take a lot of punishment without breaking anything using this bumper.
Worth every penny to me.
</DrX>
Originally posted by DavidAlford
The P-Dub racing bumper is sweet. Every car should have one.
drx is offline   Reply With Quote
Old 01-01-2005, 05:34 PM   #11070
Anders Myrberg's Avatar
@Winsorguy99:
If you drive Sorex on carpet, the tires are just great and pretty equal for 10 rounds.
Anders Myrberg is offline   Reply With Quote
