Old 12-19-2004, 04:39 AM   #10861
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Default DONT PULL THE DIFF APART
Hey Dave,
DONT PULL THE DIFF APART!! its the worst thing you can do because it will more than likely slip once its back together and you wont be able to stop it slipping when its back together. I will show you my diff next time I see you. I dont know why it is but the diffs dont like to be rebuilt. Even if the diff is gritty it wont affect the way the car handles.
As for bearings the ones off ebay will be fine.
dontfeelcold is offline   Reply With Quote
Old 12-19-2004, 04:52 AM   #10862
theisgroup's Avatar
Default Re: Time for a rebuild over Xmas break
Originally posted by MrRolla
Hi guys,
Since i have a month off racing im going to tear down my FK and rebuild it. This will be my first time rebuilding the rear diff and im aware you need a special tool to do it??
Is the HUDY caster clip remover tool what i need? Also will i need to buy any spares that might break easily or will be worn when i pull apart the diff?
Also i seen some bearings for an xray on ebay for $20US are these ok to use and will they run the same as the standard bearings or should i buy genuine Xray bearings?
All help appreciated
Cheers Dave
i just took an old pair of neddle nose pliers and ground the tip down to a fine point.
you can just sand down the diff rings until they have a mirror finish. use like 1000 wet\dry sand paper. if you don't have the lube, you will need to purchase some. the xray diff lube is a lot thinner then say assoc. stuff. you will want to do all that to the parts under the caster clip as well.
i like the kit bearing. i tried others but always go back. they are very smooth and don't need a lot of work.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 12-19-2004, 04:54 AM   #10863
theisgroup's Avatar
Originally posted by tc3Guru
where can i buy bmi chassis peices cause i've broke a bumper and battery hold down strap. another question. who sales the aluminum rear chubs. also need fk complete shocks.
hoook me up.
Beddow
call jason at bmi, he will sell those part individually. as for c-hubs, most of the online shop will have those part.
yang lai
Old 12-19-2004, 05:02 AM   #10864
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Hi guys,
Cheers Dave
Hey Dave,
This sounds stupid, but the way I looked at it is this. Its almost worth the money to just get a new on and not bother with the rebulid.
I dont know how hard or easy it would be to rebuild but its well worth the 30bucks to not have to worry about it.
Just my two cents.
JohnMatrix is offline   Reply With Quote
Old 12-19-2004, 07:34 AM   #10865
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Contact Jason at www.bmiracing.com He will take care of you.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 12-19-2004, 07:45 AM   #10866
John Tag's Avatar
Trader Rating: 42 (100%+)
the TAMALE "C" hubs I might be getting some soon. will call Monday also.
Thanks [/B][/QUOTE]
Tim, Call Jon on theseHe Can help you out I think
Happy Holidays All
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 12-19-2004, 10:42 AM   #10867
Suspended
Trader Rating: 9 (91%+)
Default Re: Re: Time for a rebuild over Xmas break
I would suggest more like 2000, then polish them.
mazmorbid is offline   Reply With Quote
Old 12-19-2004, 08:56 PM   #10868
Pyramid's Avatar
Maybe buying a new diff ring set is more worthed if you sum all the rework up.
Pyramid is offline   Reply With Quote
Old 12-19-2004, 09:07 PM   #10869
Suspended
I did, then used 2000, then polished the faces.
Old 12-19-2004, 10:07 PM   #10870
Pyramid's Avatar
Actually if we broken in properly on the first place, the diff ring will last very long, onle need polishing within rebuilt meant for clean up. But I like JohnMatirx idea the best
Old 12-19-2004, 10:11 PM   #10871
JohnMatrix's Avatar
Yea screw making or rebulding, lol, im lazy
Old 12-19-2004, 10:29 PM   #10872
danjoy25's Avatar
Trader Rating: 37 (100%+)
I wish that applies to us here in Australia as a complete diff can cost close to $100 Australian dollars.
Originally posted by JohnMatrix
Hey Dave,
Just my two cents.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 12-19-2004, 10:56 PM   #10873
asw7576's Avatar
I just joined 4wd modified race, national series. Won 3rd he... he.... he...
I really admired this car, it's very durable and strong. After several bad hits, accidents, flips, bangs, and so on........ nothing broke at all !!!
Old 12-20-2004, 06:16 AM   #10874
JHardy's Avatar
Default short arms
I have a EVO2 FOC and would like to try the short arms .... can someone tell me what all I will need to buy and maybe the part #s?
Thanks for any help.
JHardy is offline   Reply With Quote
Old 12-20-2004, 08:39 AM   #10875
kidDynomite's Avatar
Default 4 hole front shock tower
Does anybody know if the BMI 350 front shock tower's holes line up with Xray's 4-hole carpet towers?
I recently bought an Xray 4-hole tower, thinking it was the one with the 2-over-3 camber mounting holes. But it's camber holes are 3-over-1 and the holes are way off from the stock FK camber positions.
I have the BMI one as well, so I'd like to use which ever one matches what most of the FK set-up sheets show.
thanks!
kidDynomite is offline   Reply With Quote
