Old 12-16-2004, 02:51 PM   #10816
JBennett's Avatar
Send a message via AIM to JBennett
Wrong pic
Nevermid I don't have one
JBennett is offline   Reply With Quote
Old 12-16-2004, 02:54 PM   #10817
R/C Tech Charter Subscriber
You racing this weekend in Nashville?
NismoSkyline17 is offline   Reply With Quote
Old 12-16-2004, 02:54 PM   #10818
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
You guys run Stock Foam?
Out here we run Stock and 19turn on rubber.
JohnMatrix is offline   Reply With Quote
Old 12-16-2004, 02:55 PM   #10819
Yup.
Old 12-16-2004, 03:02 PM   #10820
JBennett's Avatar
You race at Henderson any?
Old 12-16-2004, 03:04 PM   #10821
JBennett's Avatar
Yeah I probally will, I will be going with Jason Lutz if I go.
Old 12-16-2004, 06:13 PM   #10822
Suspended
Trader Rating: 9 (91%+)
Default Re: tub chassis
Originally posted by Dennis Rabanes
can I use the T1r tub chassis on my FK without any modifications? Thanks
Dennis
I don't know why you would want to do that, but yes you can, although the rear looks like it comes close if you were to use the lower holes when adjusting the anti-dive, and also the rear downstop screws just hit on the edge of the chassis, but they should be ok.
mazmorbid is offline   Reply With Quote
Old 12-16-2004, 06:19 PM   #10823
Scrad's Avatar
Trader Rating: 15 (100%+)
Can someone with the BMI 350 chassis measure how wide the chassis is where the droop screws sit in the rear. My screws sit too far out on the chassis an it makes the droop setting inconsistant. So I have to use internal limiters. I don't know if I have and old style BMI chassis or not.
Scrad is offline   Reply With Quote
Old 12-16-2004, 07:45 PM   #10824
ChadCapece's Avatar
Default Evo 2 setup
Can someone please pm me a good starting setup for 19turn asphalt w/ takeoff 22's. Any help is appreciated.
thanks
chad
ChadCapece is offline   Reply With Quote
Old 12-16-2004, 11:18 PM   #10825
You have one of the old ones but I dunno how wide it is. I got one of the new ones and I have close to 2-3mm on the out side of each droop screw. What is nicer is that the whole chassis is a little narrower.
Old 12-16-2004, 11:31 PM   #10826
Dennis
It will go on but needs some massaging to do so. I know alot of the guys here were trying to run the short arms on their T1R chassis and they had to grind away at some of the ribs so that the hinge pin mounts could be mounted low enough. Hope this helps. I dunno why anyone would want to replace the CF chassis with the tub since the CF chassis is stiffer. I would suggest the BMI 350 chassis. Stiffer and enhances the performance alot more.
Old 12-17-2004, 12:16 AM   #10827
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Default Re: Evo 2 setup
thanks
chad
You can try downloading the stock set up for the EVO2. Its a very nice starting point and you can move on from there.
I usually start with a stock set up whenever i am at a new track and make the necessary changes to suit my style of driving.
AdR|aN is offline   Reply With Quote
Old 12-17-2004, 06:27 AM   #10828
theisgroup's Avatar
the BMI 350 chassis is the same wide as the factory stock chassis. The droop screws sit on the very edge of the chassis. But that is not the problem you are having. the problem you have is that the droop screws are on the opposite side from the shock mount. This creates a twist in the rear arm. The arms are relatively soft and flex. with the heavy springs we are using on carpet, you will get un-even flex of the arms every time.
There has been a revision to the BMI 350 chassis which will give the chassis a little more meat in the rear. But your will still see the same problem.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 12-17-2004, 02:41 PM   #10829
TeamButter's Avatar
Send a message via AIM to TeamButter
Post BMI .350
As posted earlier..the BMI .350 chassis is now 4mm(2mm+2mm) wider in the rear than before. The chassis is now also, 4mm NARROWER throughout the "middle" or where the battery slots are located. This was a running change and every BMI chassis from here on out will be the same.
Not sure about having the inconsitencies with the new chassis. Since switching to the narrow version I have not had any problems or diffrences in my droop settings.
Mike A
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 12-17-2004, 03:24 PM   #10830
When refering to the "split" chassis is that the factory graphite chassis that comes with the FK?
JimMcClure is offline   Reply With Quote
