Old 12-02-2004, 03:12 PM   #10606
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
I have to totally agree with David!
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 12-02-2004, 11:42 PM   #10607
kidDynomite's Avatar
Ryan, I'm using Plaids/Purples too. Keep front springs about 5lbs heavier in the front like JD mentioned. But try one hole open if using 30wt Xray oil. Keep a tiny bit of droop. You need some give to get traction.
Try standing up the shocks in front.
If your lifting, try a front sway.
0 front toe (but try adding a 1mm shim in the very front hindge pin supports. This will give you a little more initial turn in without scrubbing speed).
1* front camber (you don't need much camber in front if you go 6* caster blocks. The camber change will dramatically occur near mid corner and the car will dive toward your exit and then straighten out easily).
Got these tips from Ralph and Tom a while ago. I tried them with my DR turned down to 70%, the car was railing and that's with a tight front diff and a looser rear.
kidDynomite is offline   Reply With Quote
Old 12-03-2004, 03:50 AM   #10608
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Hey Guys,
Going to be moving up to 19 turn and still race stock.
Whats the proper position/knotch for the belts? Currently I have them as loose as possible, but i know with 19turn that wont work.
Thanks.
nick
JohnMatrix is offline   Reply With Quote
Old 12-03-2004, 04:58 AM   #10609
JDXray's Avatar
Send a message via AIM to JDXray
Originally posted by JohnMatrix
Hey Guys,
Thanks.
nick
No, loose is fine in 19t. Just take a few tests on the belts in the loose settings if you see that its skipping a tooth go up one notch tighter but i havent had any problems and i am on loose settings.
JDXray is offline   Reply With Quote
Old 12-03-2004, 08:01 AM   #10610
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Everyone, thanks for all the suggestions, going to print them out and take them to the track with me....
John, is the ORL race on Dec 12th, if so I am a no-show since that is Kids day with Santa, priorities ya know?
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 12-03-2004, 08:18 AM   #10611
John Tag's Avatar
Trader Rating: 42 (100%+)
Boy I wish my Santa came early
I along with many others running X-Rays will be at DC tommorow if your looking to come out that way and race,doors open around 10am and racing is at 5pm. There is a good crowd everyweek and the racing is top notch.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 12-03-2004, 08:31 AM   #10612
Finally .....
I got my FK together ... other then some binding in the rear suspension that had to be worked-out, this car went together smooth - looking forward to running the car tonight at a club race here in Toronto. Gonna be a tough time for me though - my EVO2 is dialed for the track layout so the switch is going to be painful.
Look forward to seeing how the car runs - considering all the changes from the EVO2, I am interested to see how the car performs tonight.
duckman996 is offline   Reply With Quote
Old 12-03-2004, 08:37 AM   #10613
sundog1's Avatar
Default Setup
Originally posted by JDXray
Your setup sounds about right, but a few things i could suggest if you dont mind.
Get either Light Purple and Purple springs. You can run those violets in the rear with purple in front (hopefully i got those springs correct, its hard to memorize them, lol)
also try this droop: 0mm front and 1mm rear
Plaid/ Purple foams will do, but you could try some Dbl pink/orange and dbl pink OR Orange/Purple and Purple
But other than that i think you got the setup pretty much down, i used to run violets all around and it wasnt that bad, but with a step stiffer in front it helps.
Hope it helps
Jon
Noted all of your setup advice here - do these apply to stock-rubber also?
sundog1 is offline   Reply With Quote
Old 12-03-2004, 10:39 AM   #10614
JDXray's Avatar
Default Re: Setup
I am not sure about outside with rubbers, i have never ran outside before, i am rug rat, lol
Old 12-03-2004, 11:39 AM   #10615
Default Re: Setup
I'm a rug-rat too. But for stock/rubber you may want to stick with "close to" stock settings (droop). Foams use firmer springs (25-35lbs), when I ran stock I was happy with 3*caster and light blue (20lb) springs with the whites in back_30wt & 2 holes open all around. Front camber at 1*, rear 1.5*- Front toe at 0 and rear 2* (this may differ to track layout) and I set my DR to 75%.
Someone else here may have a better setup since I've been concentrating on 19T/foams. Hope this helps a little.
Old 12-03-2004, 04:49 PM   #10616
John Tag's Avatar
Guys theres a X-ray FK up on the for sale thread, Its a good seller and he has good cars so if your not wanting to wait for the next shipment heres a good deal and has front diff w/ car also.
Old 12-04-2004, 09:40 AM   #10617
sundog1's Avatar
Default Re: Re: Setup
OOps, sorry - should have specified carpet. Hey Kid, where do u race? I race at AJs on Sunday - going to practice at RSJ today cause AJ has oval races. Thanks for the tips.
Old 12-04-2004, 09:54 AM   #10618
SRS
SRS's Avatar
Default Set-Up Sheets
I know their is a website that posts the majority of the Xray set-ups. It is a foreign one I believe, but the set-up sheets are in english? Ring a bell to anyone?
SRS is offline   Reply With Quote
Old 12-04-2004, 11:35 AM   #10619
For X-Ray setups go to http://www.myrcworld.net
It has just about every Team X-Ray setup. Cyrul's 2004 U.S. Indoor winning setup is available on the X-Ray website .
Hondaguy is offline   Reply With Quote
Old 12-04-2004, 12:57 PM   #10620
Default Re: Re: Re: Setup
Sundog1, I usually go to AJ's for saturday practice. Is it oval tomorrow too? I know AJ said it was oval nite Sat. I haven't raced at RSJ's since when it was Venture Raceway. I hear it's Pro4 territory now and a lot of my old friends there are all HPI. No Xray parts on hand. Although my buddy & I might race RSJ tomorrow.
Hope to see ya around!
Tommy
