Old 04-17-2002, 10:35 PM   #1036
Buster Bennett's Avatar
Send a message via AIM to Buster Bennett
JeffC:
Yes the purple should be 10lbs.
Your correct Jeff, if the front sway-bar is effecting the tweak, it is user error. WE ALL HAVE DONE IT!!!
Yes, I have flex decks in-stock. (as of this moment)
Itís better to have an option like the flex deck in your pit box, than to not. Sometimes it can get you to a setup faster if you are racing at an unknown track, or if the track is not exactly perfect. The flex deck will also make the car a little easier to drive. It may not always be the fastest way, but itís faster than if you are just slamming boards every corner without it. Also, the flex deck is great for bumpy tracks, or tracks that use corner dots. It allows the front of the car and the rear of the car to sort of "pivot" independently from one another, which make for a stable car on irregular surfaces, or when you touch one of those corner dots.
Thistle , You are very welcome.
Buster Bennett is offline   Reply With Quote
Old 04-20-2002, 09:47 AM   #1037
Joe
Joe's Avatar
ttt
Joe is offline   Reply With Quote
Old 04-22-2002, 05:02 AM   #1038
RC Nitro's Avatar
Thanks to Buster for all the phone help!! Will call again today/tomorrow as I need wheel screws The only bloody thing I did not loctite was the front wheel screws. It was 1 am and I missed this. Lost a wheel in 1st qualifier. Lessons learned, I 4mm cap screw later I was racing
Car was dialed !! Real happy, most nitro's were real loose. Ran the kit tires with Yoko firm inserts. Real happy, with the exception on the motor. No top end grunt. Geared stock (8.23 23.6 rollout). Could not even hold off a contender on the straights Motor is a GM3. Suggestions??
TIA
RC Nitro is offline   Reply With Quote
Old 04-22-2002, 05:28 AM   #1039
mike_Webb's Avatar
Send a message via AIM to mike_Webb
If this is a tight track then I would try about a 25-26 rollout. If this is a open track try to get the rollout around 29 or 30. THis is what I had to do for the East Coast Champs and my car was a lot faster.. to bad the driver was not a lot better . This was for a P2K2 Motor. You may want to try the higer rollout and then feel the motor after the run to see how hot it is.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 04-22-2002, 07:35 PM   #1040
Just wanted to let everyone know, we just had the second round of our regional series in Australia, and Xrays came first, second, fourth and fifth.
I came fourth just missing out on the podium by nine tenths o a second, i dumped on the last lap, and was passed a few feet short of the line.
I was only running a 12 double compared to others with eights and nines, i guess you cant beat horsepower. my next mission is to have a play with these low wind motors.
Besercoe is offline   Reply With Quote
Old 04-22-2002, 09:53 PM   #1041
HYDRAMATIC99's Avatar
Send a message via AIM to HYDRAMATIC99
what position is everyone using for their roll center bridge? What track conditions do you race in (bumpy, tight, smooth??)
HYDRAMATIC99 is offline   Reply With Quote
Old 04-23-2002, 04:39 AM   #1042
RC Nitro's Avatar
Mike_Webb: Thanks for the info!!. Track tends to be in the middle. They vary the layout every week, parking lot. The main straight tends to be 100 - 150'. It is enough of a straight that I hit 2nd in my MTX-2 and then some from a dead stop. Looks like I need to shoot for ~ 28 rollout as a compromise. I will need to get some more pinions
Old 04-23-2002, 05:21 AM   #1043
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
100-150' straight! I start with a FDR of 6.162 and my Rollout is around 31.59. We have a 150' straight and open track. We run 1/8's so it is never tight. The other track I set up is tighter and smaller, about a 100' straight, and I start out with a FDR of 7.
I now count 6 XRAY's at my local track.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 04-23-2002, 05:25 AM   #1044
I use the top hole on the bridge and hole (4) on the upright.
V-Dezign 4.0
Old 04-23-2002, 06:30 AM   #1045
RC Nitro's Avatar
RCCadet: Thanks for the info. Looks like I need the measuring wheel to check that length. However, I believe I am right. It is >100 and <150 max as we also run nitro's there.
Old 04-23-2002, 06:34 AM   #1046
I used millimeters in that calculator and round to the nearest whole number. I will change it later today so it will accept a decimal.
V-Dezign 4.0
Old 04-27-2002, 12:12 PM   #1047
Joe
Joe's Avatar
ttt
Old 04-28-2002, 05:24 PM   #1048
Default Need to buy an X-Ray
I need to buy an X- Ray, anyone have one they want to part with?If so, please e-mail me at [email protected]. My son wants one, so am trying to find one used if possible.Thank You.
twistert1 is offline   Reply With Quote
Old 04-28-2002, 05:30 PM   #1049
Default New arms & hubs
Buster, have you heard any dates yet for the new arms and hubs? I would like to give them a try as soon as available. Thanks
Old 04-28-2002, 05:43 PM   #1050
mike_Webb's Avatar
Twister-
The New arms and hubs will not be out until the Carpet Option is released. Once that is released then you can buy the whole kit as I think you will need other parts then just the Arms and Hubs, but I am not 100% sure about that.
