Old 11-16-2004, 12:45 PM   #10141
Scrad's Avatar
Trader Rating: 15 (100%+)
I always put a small piece of shrink wrap from the rx to the antenna, just so it isn't setting on the chassis. In your pic it looks like your wire maybe touching the chassis.
Also make sure those weights you have on your servo are insulated and are not touching the case. I've had servos do some weird stuff before.
Scrad is offline   Reply With Quote
Old 11-16-2004, 12:46 PM   #10142
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Something else to check and make sure you have caps on your motor. I also use a piece of fuel tubing on my wire between the RX and the tube.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 11-16-2004, 12:51 PM   #10143
Default Re: Interference problem.
Originally posted by markp27
Hi,
I was wondering if anyone would have any ideas as to by I'm getting interference problems at my circuit.
Quite often when I go past one part of the circuit, where a metail door is in the wall, my steering and throttle glitch very badly - sometimes sending me into the wall
With my other car (non-Xray) this doesn't happen - I'm using the same crystals as with the other car and have even tried changing the frequency, but nothing works.
I run on a counter-clockwise circuit and my rx unit is on the side of the car which is closest to the metal door when I pass it. Has anyone else suffered from this kind of problem and is there a solution?
Here is a pic showing my setup - can anyone spot if I have done something wrong?
Hi Mark,
You could read some tips and trick's but I have another hint.
Your receiverwire is hitting the chassis in the picture??
This shouldn't be.
This can cause interference, due the fact that the chassis is made of full carbonfibre.
Thomas
840918001 is offline   Reply With Quote
Old 11-16-2004, 12:51 PM   #10144
markp27's Avatar
Send a message via ICQ to markp27
Thanks for the replies guys.
@TigeRyan: I haven't tried the obvious things yet, I wanted to check to see if there was an easy solution first
@Scrad: the wire isn't sitting on the chassis, but I'll try puting some fuel tubing on the wire to make sure. I have removed the weights since this picture, so it is not due to them.
@DavidAlford: actually I don't have caps on the motor - would this cause interference at full throttle?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 11-16-2004, 12:53 PM   #10145
Yes sir. Some motors don't need them like the Epic based ones because they are built in. But I think all Reedy based motors and the older Tops do.
Old 11-16-2004, 12:54 PM   #10146
markp27's Avatar
Default Re: Re: Interference problem.
Originally posted by 840918001
Hi Mark,
This shouldn't be.
Thomas
Thanks Thomas, but the wire is clear of the chassis - I have the spare wire wrapped around the bottom of the antenna, now, so it is well clear of the chassis itself.
BTW: My review of the TRF-415 v Xray T1-FK is coming on www.3hobby.com tonight - check it out
Old 11-16-2004, 12:55 PM   #10147
markp27's Avatar
Ok, that can be one of the first things I try then. What about the diode? Is this required?
Old 11-16-2004, 12:58 PM   #10148
Depends on the ESC and the motor. For stock you really don't have to worry about it. But in mod where your gonna need more brakes I'd use it.
Old 11-16-2004, 01:15 PM   #10149
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Definitely put caps on the motor, 3 of them one from positive to negative and then one from negative to can and the third from positive to can, just in case you haven't done it before....
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 11-16-2004, 01:17 PM   #10150
markp27's Avatar
You guessed right - I'm as good as an elektro virgin
Old 11-16-2004, 02:54 PM   #10151
Sow&Steady's Avatar
Default Re: Re: Re: Interference problem.
Folks, the article above has been posted now. Apologies for the delay Mark, kept getting disturbed by the kids.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 11-16-2004, 03:05 PM   #10152
markp27's Avatar
Default Test of Xray T1-FK Versus TRF-415
Eventually I concluded my testing of the Xray and 415 - see the article linked below:
Xray Versus 415
Old 11-16-2004, 03:18 PM   #10153
JDXray's Avatar
Send a message via AIM to JDXray
Default Re: Test of Xray T1-FK Versus TRF-415
Xray Versus 415
Mark Great review, i really like the details.
JDXray is offline   Reply With Quote
Old 11-16-2004, 03:21 PM   #10154
markp27's Avatar
Default Re: Re: Test of Xray T1-FK Versus TRF-415
Thanks, glad you liked it - it was great to do the testing I decided to write the article from my testing notes, to give more of a flavour of what I was having to do to improve each car.
Now, which to choose!
Old 11-16-2004, 03:22 PM   #10155
markp27's Avatar
Default Re: Re: Re: Re: Interference problem.
No problems Sow - thanks for putting the article online!
