Old 11-16-2004, 03:44 AM   #10126
MrRolla's Avatar
Trader Rating: 29 (100%+)
Default Re: Xray T1 Fk
Originally posted by (V)r>?[email protected][email protected]
You have proberly heard this question a million time but i need to know because i will be a proud owner of one soon
1) What do you break/replace often?
2) Is the car quiet e.g silent?
3) Is there any problems running a mod in it?
4) Are the parts easy to find ( if you need to get parts )
thanks a lot for your input
1) front bumper brace, front body post's, they are the two things i have broken most....
2) Mine is still quiet even after 3 moths of racing on a dirty track...
3)no problems running a mod in it
4) In australia the ony place to get parts is CMC in Penshurst, other than that you will have to go Overseas...
Hope to help
MrRolla is offline   Reply With Quote
Old 11-16-2004, 03:53 AM   #10127
Send a message via AIM to (V)r>??@uD@ Send a message via Yahoo to (V)r>??@uD@
Default thanks
thanks Mr Rolla and Olec im getting one for sure im super excited
(V)r>??@uD@ is offline   Reply With Quote
Old 11-16-2004, 04:22 AM   #10128
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
The Xray took 1st 2nd and 3rd in modified at the nationals on the weekend
dontfeelcold is offline   Reply With Quote
Old 11-16-2004, 05:08 AM   #10129
Michal101's Avatar
Originally posted by Michal101
Hi,
Is there really that much difference between the carpet front shock tower and the normal front shock tower? I know what the descriptions say, but I was hoping that somebody had both of the shock towers and was able to give me a true comparison.
Thanks, Mike
Anybody???
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 11-16-2004, 05:11 AM   #10130
R/C Tech Charter Subscriber
Anybody???
Check a couple pages back. I know I, along with a few others, have answered it.
NismoSkyline17 is offline   Reply With Quote
Old 11-16-2004, 06:25 AM   #10131
ChrisP's Avatar
1) You'll want to stock some font C-hubs as well and use the impact absorbing front bumper..other than that the car is pretty much bullet proof
2) very quiet
3) Ask josh Cyrul and Ralph Burch..they seem to like it
4) parts are all over the place and supply keeps getting better
ChrisP is offline   Reply With Quote
Old 11-16-2004, 07:19 AM   #10132
JDXray's Avatar
Send a message via AIM to JDXray
Originally posted by Pyramid
Does it means if nothing mounted on the chassis and you put that piece on top of glass table ... it wont settled?? or I guess it is tweak after mounted..
Built the rear bulkhead first and make sure no tweak when placed on glass table.. then mount it on the chassis. Tighten the upper deck as suggested by Rob. If still tweak, loosen bottom screws of front bulkhead, redo the top deck and retighten the front bulkhead bottom screws. Even after major impact, I still found the original chassis being perfectly flat and no tweak from upperdeck or the bulkhead itself.
I got the tweak under control now but when i first put in down on the table with no wheels and loosened the top deck the chassis was tweaked (twisted on the rear left, i could tap the chassis down on the table, lol) So i did what Rob told me with the X-pattern shock and it leveled out. Then screwed top deck back on and wheels back on and the chassis was leveled.
I then checked tweak one more time with wheels on and just did some minor changes but i think its all covered now thanks for help guys. I'll let you know if i need some more help on it.
Jon
JDXray is offline   Reply With Quote
Old 11-16-2004, 08:14 AM   #10133
TigeRyan's Avatar
Send a message via AIM to TigeRyan
You will also want some spare hardware with you, alot of the sizes of screws XRay uses are not the most common sizes, I used to run associated so I had to really stock up on metric screws....
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 11-16-2004, 09:01 AM   #10134
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
The carpet towers sit lower which allow you to slam the body. A must for carpet racing.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 11-16-2004, 10:06 AM   #10135
Michal101's Avatar
Dave,
I appreciate the info and I did check a few pages back and read up on them as well. I guess that I missed those pages. And it looks as though the carpet shock towers are the ones with the bump in the middle on the top.
Thanks again, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Old 11-16-2004, 11:39 AM   #10136
Originally posted by kaizen
Alas, yes! I am having the same issue. But, I figure I have had the car for a while and have run it both indoors and in some pretty extreme weather outdoors, it may be time to replace the chassis and upgrade.
Not sure what to upgrade to though. XRC or the BMI?
Any arguments for either?
BMI is quality... In regards to the split cell chassis that Nismo runs, it is only good for Carpet tracks. It will burn up your front rubber tires if you race on asphalt, too much weight forward.
BMI makes three chassis versions- 1-batteries moved 1/8 farther forward (more room for electronics), 2-batteries moved 1/2 a cell or .350 thousands forward (if you run small electronics). Both of these chassis are great for indoors and outdoors. And 3- split cell chassis, batteries on the opposite side of the servo side, are moved as far forward as possible, only for carpet.
Give Jason at BMI a call.
I own 2 BMI .350 chassis and am awaiting a split cell to come in the mail.
BSYDOR is offline   Reply With Quote
Old 11-16-2004, 12:02 PM   #10137
markp27's Avatar
Send a message via ICQ to markp27
Default Interference problem.
Hi,
I was wondering if anyone would have any ideas as to by I'm getting interference problems at my circuit.
Quite often when I go past one part of the circuit, where a metail door is in the wall, my steering and throttle glitch very badly - sometimes sending me into the wall
With my other car (non-Xray) this doesn't happen - I'm using the same crystals as with the other car and have even tried changing the frequency, but nothing works.
I run on a counter-clockwise circuit and my rx unit is on the side of the car which is closest to the metal door when I pass it. Has anyone else suffered from this kind of problem and is there a solution?
Here is a pic showing my setup - can anyone spot if I have done something wrong?
markp27 is offline   Reply With Quote
Old 11-16-2004, 12:21 PM   #10138
Suspended
Trader Rating: 9 (91%+)
XR-301111 EXTRA RIGID CHASSIS (XRC) - GRAPHITE 3.5MM
Only USD60....
XR-301163 UPPER DECK - WIDE USD17
I guess that is way most of Asia online shopping has become a threat to the other part of the worlds.
Can I ask where these prices come from? I once used Precision RC, I found they had the cheapest prices, but they will not allow me to buy from them anymore, Thanks.
mazmorbid is offline   Reply With Quote
Old 11-16-2004, 12:40 PM   #10139
TigeRyan's Avatar
markp27,
Have you tried the obvious things...
1. Change the receiver
2. Insultate the receiver with double-servo tape
3. Change the receiver position temporarily in the car
4. Change the motor
5. Try a noise reducer (shoicky (sp?) / capacitors)
6. Try a different servo, they can provide interference as well
7. Try a different ESC, same as above
If you have worked down that entire list and still havent solved the problem, I would say tear the down the door
I hope one of them leads to solving your problem
Old 11-16-2004, 12:43 PM   #10140
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
They wont let you buy from them anymore? That seems strange.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
