Old 11-15-2004, 06:45 PM   #10111
Deves's Avatar
JDXray, why don't you enlighten all of us with your newfound wisdom and inform us of the steps taken to remedy your tweak problem.
Deves is offline   Reply With Quote
Old 11-15-2004, 06:47 PM   #10112
JDXray's Avatar
Send a message via AIM to JDXray
ooo dont ask me.. ask the ONE - Rob Mincey.. lol
JDXray is offline   Reply With Quote
Old 11-15-2004, 06:51 PM   #10113
Rob Mincey's Avatar
Good lord, it's not that big of a deal.
Works on all double deck cars, assuming the chassis itself (and top deck for that matter) aren't inherently tweaked.
Put the chassis flat on the table, loosen the screws that secure the top deck, center the top deck, and press down while tightening the screws in an x-pattern.
No big deal, really. Just passed on a suggestion that happened to work.
Rob
Rob Mincey is offline   Reply With Quote
Old 11-15-2004, 08:32 PM   #10114
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Rob is the man.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 11-15-2004, 09:44 PM   #10115
ChrisP's Avatar
Way to go Rob...and btw...I like the new name
ChrisP is offline   Reply With Quote
Old 11-15-2004, 10:08 PM   #10116
litespeed-dom's Avatar
Very good advice, Rob. Unfortunately a lot of people just don't realize how much that helps. Tom Esposito told me at Nats that he would do that to the top deck after every run, he also said not to tighten the top deck so hardcore, just not loose would do.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 11-15-2004, 10:47 PM   #10117
kaizen's Avatar
Originally posted by JDXray
Thanks Sal, i'll look into it, but as of now i think someone might sell me the pulley as well.
Anyone else getting alot of tweak on there FK stock Chassis? I look at the back of my car and look under and i can really see how tweaked my chassis is. it leans more toward the right and raise on the left. I checked the tweak numerous times and now both wheels come up at same time but the chassis is still tweak-looking. Any ideas?
Alas, yes! I am having the same issue. But, I figure I have had the car for a while and have run it both indoors and in some pretty extreme weather outdoors, it may be time to replace the chassis and upgrade.
Not sure what to upgrade to though. XRC or the BMI?
Any arguments for either?
kaizen is offline   Reply With Quote
Old 11-15-2004, 11:06 PM   #10118
Price is a standout. XRAY chassis is $90 for the main chassis and about $25 for the upper deck. BMI is $80, including upper and lower. BMI lays its fiber in 0, 90 and 45 degrees, it's stronger if you are to twist it, vs XRAY lays it in 0 and 90 degrees only. XRAY chassis is thicker and is heavier. For my money, BMI got my money for both my XRAYs.
Dom
Old 11-15-2004, 11:10 PM   #10119
R/C Tech Charter Subscriber
I love my BMI split chassis (except for having to figure out my battery config). Stiffest chassis i have ever seen. Can't wait for this weekend to give it a try.
NismoSkyline17 is offline   Reply With Quote
Old 11-15-2004, 11:45 PM   #10120
Pyramid's Avatar
XR-301111 EXTRA RIGID CHASSIS (XRC) - GRAPHITE 3.5MM
Only USD60....
XR-301163 UPPER DECK - WIDE USD17
I guess that is way most of Asia online shopping has become a threat to the other part of the worlds.
Pyramid is offline   Reply With Quote
Old 11-15-2004, 11:51 PM   #10121
berger's Avatar
Cant argue though, much better than "rip off Britain" i can get things for half price or less from Hong Kong compared to the UK.
berger is offline   Reply With Quote
Old 11-15-2004, 11:53 PM   #10122
Pyramid's Avatar
Does it means if nothing mounted on the chassis and you put that piece on top of glass table ... it wont settled?? or I guess it is tweak after mounted..
Built the rear bulkhead first and make sure no tweak when placed on glass table.. then mount it on the chassis. Tighten the upper deck as suggested by Rob. If still tweak, loosen bottom screws of front bulkhead, redo the top deck and retighten the front bulkhead bottom screws. Even after major impact, I still found the original chassis being perfectly flat and no tweak from upperdeck or the bulkhead itself.
Old 11-16-2004, 12:07 AM   #10123
Send a message via AIM to (V)r>??@uD@ Send a message via Yahoo to (V)r>??@uD@
Default Xray T1 Fk
You have proberly heard this question a million time but i need to know because i will be a proud owner of one soon
1) What do you break/replace often?
2) Is the car quiet e.g silent?
3) Is there any problems running a mod in it?
4) Are the parts easy to find ( if you need to get parts )
thanks a lot for your input
(V)r>??@uD@ is offline   Reply With Quote
Old 11-16-2004, 03:20 AM   #10124
OleC's Avatar
Default Regarding checking for tweak
Hi all,
When you check the chassis for tweak, make sure you remember to loosen/detach the rear small plastic bumper. This can stick out a little under the chassis, making it look like there is tweak on a flat surface.
The front bumper havent been a problem, but the rear one has fooled me a couple of times...
OleC is offline   Reply With Quote
Old 11-16-2004, 03:22 AM   #10125
OleC's Avatar
Default Re: Xray T1 Fk
1. Nothing
2. Yes, very.
3. No
4. Yes, a lot of webshops have parts. I find Hong Kong to have the lowest prices, by far.
