Old 04-04-2002, 08:42 PM   #991
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Is it Joey? I think Chris Introduced me too you?
Mike
mike_Webb is offline   Reply With Quote
Old 04-04-2002, 09:28 PM   #992
Usagi's Avatar
Not really sure I would a 7-11..... why becasue the quility of r/c in japan far out reach other made where that car is made.......
Usagi is offline   Reply With Quote
Old 04-04-2002, 10:24 PM   #993
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
It's Garett... the kid who never drives his XXX-S. The one you put the speedo in. His friend Nate has an RCLabs 7.
But thanks for thinking I am that unwitty....
ChristopherKee is offline   Reply With Quote
Old 04-05-2002, 08:11 AM   #994
mike_Webb's Avatar
Garret?
Come on man... you have to be on the up and up with me Garret!!
That is the last time that I install your speed contoller, sell you a good P2K2, Fix your suspension, fix your radio, fix your servo, charge your batteries, true your tires, tighten your screws in your car, fill your shocks with shock oil, break in your motor, cut your comm, set your ride hieght, set your droop, cut holes in your body so that you can mount it, flush your bearings, tighten your pinion... and no I will not drive your car so that you can make it at least 1 lap around the track without breaking!!!
Chris- I knew it wasn't you.... you know better . I wouldn't let you use my motors anymore
HAHAHAHAHAHAHA
Mike Webb
Old 04-05-2002, 01:20 PM   #995
uh no it is not garrett or nate i sat right behind garrett last weekend i raced you and beat you so now you know its not him or nate also my name is TC3 FO LIFE make sense
TC3 FO LiFE is offline   Reply With Quote
Old 04-05-2002, 01:45 PM   #996
mike_Webb's Avatar
You say your name starts with J and ends in Y. Paul got first, Chris was in second until Justin made him break and that is when I took over second so you could not have beat me. Third was down 1 lap on me.
Just tell me what you name is... I am leaving to go out of the country for 2 weeks and it is going to bother the hell out of me
Mike
Old 04-05-2002, 10:14 PM   #997
yo this is garrett that kid that it is is jimmy winneger hes messin with you well im on nates sn so i g2g but holla back sorry 4 all of the confusion!!!!!!!
peace,
garrett giles
RSX Type 7even is offline   Reply With Quote
Old 04-07-2002, 08:57 AM   #998
Peter Busch's Avatar
R/C Tech Charter Subscriber
Well after 3 weeks of trying every setup in the book I finnally figured out what could be causing my car to be loose when accellerating. The center one way was slipping so my front wheels were not getting full power. The one way was slipping inside the plastic pulley so I will be calling Buster tommorrow for the new improved version. I hope that does the trick.
Peter Busch is offline   Reply With Quote
Old 04-07-2002, 10:01 AM   #999
mike_Webb's Avatar
Ahhh.. Jimmy . I didn't know he went by Jimmy... I know him as little jim
Hey Garrett, did you race yesterday? How did you three do?
I will be back in two weeks to show you guys how to get around the track really quick.. That is if Chris will get out of my way.
Talk to all you guys when I get back.
Mike
Old 04-09-2002, 07:56 AM   #1000
spongebob,
you can also add 4 set screws to the current one way by drilling 4 small holes in the plastic cover and then theadig in small set screws like you would use in a pinion gear. The Corally car had the same problems and the corallyusa web site has the step by step instructions.
sizzler is offline   Reply With Quote
Old 04-09-2002, 08:01 AM   #1001
dtm
dtm's Avatar
Send a message via ICQ to dtm
hahaha......don't say I didn't tell you so!!!! heres my post on 18th March!!! Don't bother with new version...epoxy works great for a few months at least!!!
Do you guys find it harder to get the back end to hook up with the aluminum rear arms (those who are running them) ?
The problem is the rear end is comming around when I get on the gas.
Are you running the mid one-way loose? If you are then check your mid one-way; grab hold of it and try to turn the spur gear in the 'locked' direction if there is ANY slipping then that will be your problem. 9 Xrays out of 10 Xrays with a loose rear end is the mid one-way...pull it apart, clean and epoxy it back in....problem solved.....for a few more months!!! Alternatively just lock it out!
dtm is offline   Reply With Quote
Old 04-09-2002, 08:01 AM   #1002
Usagi's Avatar
Anyone have the prices on the new over priced xray options? chassy bulkheads and top plate?
Old 04-09-2002, 08:03 AM   #1003
dtm
dtm's Avatar
I thought you were giving up on the Xray??
Old 04-09-2002, 04:24 PM   #1004
Default Prices on parts
From what I know, the chassis is 69.95, the top deck is 38.00, the bulkheads are 79.95. There is also some new arms and hubs that will be available soon. The new hubs in the rear and castor blocks will replace the pillow blocks the car has now. Saw them this past weekend on a team drivers car.
twistert1 is offline   Reply With Quote
Old 04-09-2002, 06:19 PM   #1005
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Replacing the pillow ball hubs with something new? I can't say that I am happy with that upgrade. I did not expect all these changes to improve the T1. Oh well, let me know when you get them Buster.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
