Old 11-09-2004, 02:08 PM   #9976
rayhuang's Avatar
Originally posted by John Tag
I found my sway barTHX Litespeed Dom for the link,and all who pm'd me.Now im a happy camper
Cool!!
Old 11-09-2004, 02:32 PM   #9977
Default tc3 springs
The tc3 springs will work on the Xray. And they are different. The tc3 springs seem to be more linear and the xray springs seem to be more progressive. so, for the same lbs spring, there shold be a difference in feel/handling.
XrayEye is offline   Reply With Quote
Old 11-09-2004, 05:20 PM   #9978
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
Thank you all for your reply on my spring questions.
Ron
Blue Sky is offline   Reply With Quote
Old 11-09-2004, 07:52 PM   #9979
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Xray offers two different optional front shock towers.. There is a factory shock tower(302096) and the carpet tower(302095).
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 11-09-2004, 11:05 PM   #9980
FW-05RR's Avatar
Bearings
did you guys clean your bearings in any way shape or form before building the kit to make them smoother?
do you need to do anything to the bearings?
FW-05RR is offline   Reply With Quote
Old 11-09-2004, 11:15 PM   #9981
Korey Harbke's Avatar
Nope, they alreayd have a light lube in them. The seals and belts will free up with a few runs and the drivetrain will be stupid butter smooth lol.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-09-2004, 11:39 PM   #9982
FW-05RR's Avatar
-Korey
thx
Old 11-10-2004, 03:30 AM   #9983
OleC's Avatar
Hi everybody!
I have been testing the FK for a while now and initially I had problems with the car being too unstable. I have made a few adjustments to the setup and now it is very stable but it scrubs of to much speed going through the turns.
So where do I start to free up the car in the turns without making it too unstable?
I have attached my setup here:
OleC is offline   Reply With Quote
Old 11-10-2004, 06:11 AM   #9984
theisgroup's Avatar
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 11-10-2004, 07:34 AM   #9985
OleC- I looked at your setup, and noticed right away that you run carpet with rubber tires. That is not my specialty! LOL Now if you were using foams, different story. Im sure someone else on herr can shoot you in the right direction. But you did say that it is scrubing too much speed right? Why dont you try shortening the rear camber link.
Old 11-10-2004, 07:39 AM   #9986
nick51's Avatar
Send a message via AIM to nick51
olec-you could try some different tires, maybe like take offs 27's or 22's
nick51 is offline   Reply With Quote
Old 11-10-2004, 07:45 AM   #9987
Pyramid's Avatar
Try the following change all at once,
Anti squat rear at #6 (just to absorb some bumps better)
Front Camber Link #2 (make the lenght identical with rear so you get better balance in suspension geometery for both on and off throttle.. no surprise feeling).
Set Camber all same for equal tire wear (1.5 is a start)
Medium tight diff (75% locked)
If you play on permanent track (and technicall as mentioned), start with the following damping
55W (trinity/asso) all around
3 holes fixed piston all around, if using adjustable, start with 60W
Yellow springs in rear, for front 2 step higher (I believe is blue-green) which should give you about the same damping hardness between F/R.
Last one, but the most important to free up the car in the turns, make all upper camber link as parallel as possible (by adding shims on top of hubs) to its lower arms. This will gives positive value for camber as your body rolls which should give you flying on the air feeling when turning (because loosing traction). If too twichy, either use less dual rate or install F and R stabilizer or just use shorter upper camber link (to get quicker reaction/speed of angle changed) and slightly angled down inside (so that camber not change much while rolling).
Those are just my opinions...
Pyramid is offline   Reply With Quote
Old 11-10-2004, 07:47 AM   #9988
Pyramid's Avatar
I just realize that you did run on carpet.. try much harder dampening combination to start with.
Old 11-10-2004, 07:54 AM   #9989
OleC's Avatar
Thanks for the input Corey and Nick.
I have used this setup with several different tires but the result is the same. Different tires just gives different overal grip with this setup.
It's difficult to explain but I'm looking for adjustments that would make the car "roll" easier thorugh the corners.
If I blip the throttle from a standstill it will roll forever going straight forward. But when I enter a corner at high speed it's like hitting the brakes on all four corners.
I'm not looking to drastically remove the (for me comfortable) understeer I have. It is more a question of gradually going towards a more "loose" setup as I get more comfortable with the car and develop a throtle finger more suited for modified motors (I'm more used to 27T and 19T...)
I will try a softer roll bar in the front and I'll also try shortening the camber links in the rear.
Old 11-10-2004, 08:02 AM   #9990
OleC's Avatar
Wow Pyramid!
Thanks for your input.
The damping you suggest seems awfully high. I've seen that on setups for foam on carpet but do you think it is suitable for rubber on carpet?
It is the rear diff you suggest tightening with this setup? (I use a front one way)
I use a 2mm front anti roll bar in my current setup. Do you suggest removing it with the setup changes you propose?
