Xray T1
#9811
I'll be doing the winter series at Don Valley, I'm doing mod but i'm gonna do stock aswell if i can get a spare place on the day.
In stock i'll probably be gearing my Monster between 7.6 and 8.
Are you getting the 15/40's at the track or somewhere abroad (HK Japan USA etc) at a reasonable price?
#9812
Re: Xray FK snowplow
Originally posted by damo
How can i get the Fk to have more turn in. Just finished building it and understeer is an understatement. Help me out. My T1 neve pushed this bad, and with a oneway, wow.
hope this helps.
-JC
#9815
Originally posted by TigeRyan
Do you guys recommend building the shocks in the regular mode or the adjustable piston mode? I figure that is where I will spend most of my night, building the shocks and getting them all nice and even....
Boy, talk about really wanting to play sick from work today
Well its your choice, its nice to have the external adjustmentss, but for me i have an extra set so i built one with adjustable and another non-adjustable. I only run at one track so i just keep the piston settings the same anyways.
But its nice to be able to change the piston settings externally, most kits, or no kits have that.
Jon
#9816
Originally posted by berger
Don Valley? I didnt get a place there so im doing the wirral winter series and jubilee winter series instead..
Rob, we get our 15-40's from the lhs (morley models) but newbold usually take looooads of to the onsite shop...aswell as wheels and inserts.
watch out tho, at the juniors the guy at the shop said he didnt have any of the new one piece controlled insert in stock and he doesn't know when he is getting them in..so don't rely just on him as he might not have any, and if he does they are gonna sell fast.
and about understeer, i have 2 pistons open front and rear, with 0 degrees toe on foams..and usually 1 out with rubbers and it turns in really well....i also run 2 degrees rear toe in apposed to std 3 degrees.
#9817
hey, i just got this on ebay today and i want to know if you guys think it was a good deal. at least i hope ill like it more that the tc3.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
also, is the evo2 the short arm version? is it the newest version?
thanks
marshalv
thanks
marshalv
#9819
thanks
marshalv
thanks
marshalv
#9821
It is very light. Many of Josh Cyrul's setups require 45 gram weight in the center.
#9822
so what parts would i need to get to make it the short arm? do i need new driveshafts? how much is the decrease in width? how much will it cost? will it be a noticeable difference?
thanks marshalv
thanks marshalv
#9823
All you need is the short arms. They don't change any of the dimentions and you will only be out at most $40. They mount outside the bulkhead instead of inside.
#9824
hey, im about to check out a slightly used T1fk from one of the local racers here....what should i look out for? your advice will be much appreciated.
#9825
Just the basics that you would normally do when purchasing a used car. Look to make sure all the parts are there and make sure that it is in the condition it is described.
