Xray T1
Old 10-25-2004, 12:09 PM
  #9601
There are guys here in Memphis racing novice and they are running Tamiya 540 silver cans (which they are required to run) at close to 5.0 FDR. They can almost keep up with a regular stock motor. Sold a 108 64pitch spur and 43t pinion to a guy yesterday so he could try and keep up with the leader.
NismoSkyline17 is offline
Old 10-25-2004, 12:23 PM
  #9602
Default Re: Re: OK
Originally posted by Hondaguy
Here you go. This is how you correct the problem.
http://www.teamxray.com/teamxray/pro...&kategoria=868
I had problems threading the shafts into the ball joints. Every single one of them was a pain... and I still can't get them all the way down.
rayder is offline
Old 10-25-2004, 01:44 PM
  #9603
Rob Mincey's Avatar
Prethread the shock ends with one of the 2mm button head screws prior to trying to place it onto the shaft. Makes life much easier.
Rob
Rob Mincey is offline
Old 10-25-2004, 01:46 PM
  #9604
Rob Mincey's Avatar
I've raced on your track in Memphis and I wouldn't gear a stock motor anywhere near a 5.0.
The 540's are different. They make tons of torque and no top end, so you have to gear 'em like that to get any speed out of 'em. Not the same with a stocker - at least, not with a Binary or Monster, or maybe even a P2K2.
Rob
Old 10-25-2004, 03:32 PM
  #9605
JohnMatrix's Avatar
have ppl been getting parts and kits yet?
Last I heard it was off the boat but is it in anyones hands?
JohnMatrix is offline
Old 10-25-2004, 03:38 PM
  #9606
Sal Amato's Avatar
Trader Rating: 26 (100%+)
Default Screws falling out of bulkhead
I keep finding the screws that hold the bulkheads to the chassis loose or missing has anyone else had this problem,if so how did you correct it?
Sal Amato is offline
Old 10-25-2004, 03:41 PM
  #9607
Default Re: Re: Re: OK
Sorry, I thought you were referring to the shock bodies. Did you pre-thread the ball joints with a 3mm screw? There is a little side note in the instructions about that. It does make it easier to thread the rods into the ball ends if you pre-thread. Also, remember you want 1mm of thread to show.
Hondaguy is offline
Old 10-25-2004, 03:42 PM
  #9608
JohnMatrix's Avatar
yup, happens all the time to me.
Just double check it before each race. I have had Batts and everything fly out.
Takes 3-4 race for the screw to totally back out.
Old 10-25-2004, 03:44 PM
  #9609
Default Re: Re: Re: Re: OK
Yeah, I tried prethreading. I am going to have to try again... might have used a size too small.
rayder is offline
Old 10-25-2004, 05:01 PM
  #9610
Does anyone have the xray t1 fk in stock
ptjonesus is offline
Old 10-25-2004, 05:43 PM
  #9611
They are on the way. RC America's shipment should be there by now and probably all inventoried. I'm sure they will be shipping this week.
Old 10-25-2004, 06:31 PM
  #9612
theisgroup's Avatar
they started shipping saturday. Track I frequent had their delivery saturday. we are just down the street from rcamerica. Fk kits are in the shipment, but did not see any factory diffs.
theisgroup is offline
Old 10-25-2004, 06:49 PM
  #9613
What do you mean by Factory Diffs?
Are they a hop-up option?
v0rtex is offline
Old 10-25-2004, 06:50 PM
  #9614
theisgroup's Avatar
the diffs for the factory kit have lightened out drive and also have the 1.77 gears
Old 10-25-2004, 06:56 PM
  #9615
rayhuang's Avatar
Any short hard rear arms in the shipment that you saw-or is that a myth?
rayhuang is offline
