Old 10-24-2004, 08:49 PM   #9586
Rob Mincey's Avatar
Originally posted by S-T-R-l-K-E-R
losi rob - you fk looks awesome
what is the weight of your purple springs?
what shock oil do you have in it? fr & rr
keep me updated with your "fan experiment" want to see how well it cools the motor.
Lets see... When I took that picture, the springs were from my carpet setup with foam tires. I was in the process of putting my rubber tire asphalt setting on it.
But, to answer your question, the fronts are XRay 30#'s (light purples) and the rears are XRay 28#'s (violets.)
On my local asphalt track, with rubber tires, I'm running blues up front and whites in the back.
I run XRay 30 wt front and rear.
Rob
Rob Mincey is offline   Reply With Quote
Old 10-24-2004, 09:40 PM   #9587
tornado
Guest
Posts: n/a
Hey guys !!
Just got an old T1 Evo2 second hand.....out of curiosity...what is the difference between the Evo and the FK.
Bryan
Old 10-24-2004, 10:19 PM   #9588
R/C Tech Charter Subscriber
Check 5 posts up from yours.
NismoSkyline17 is offline   Reply With Quote
Old 10-24-2004, 10:24 PM   #9589
wesb_65's Avatar
Hi Everybody!
I just installed the low ratio pulley set in my T1R and found to get the same final drive ratio I had with the old 2.125 pulleys I needed a 20T pinion. The only problem is that the belts rubbed on the motor. I put on a 21T pinion which helped but the rear belt is still rubbing. Should I just gear up some more? I'm running stock on a small techinical carpet track. Any help would be apperciated. BTW here is a pic of my car.
wesb_65 is offline   Reply With Quote
Old 10-24-2004, 10:26 PM   #9590
Don't worry about it. The all do it. When the drive train is underpower the belt lifts off the motor. Just run the gear ratio that you need.
Old 10-24-2004, 10:36 PM   #9591
Rob Mincey's Avatar
You could also run a larger spur gear.
Rob
Old 10-24-2004, 10:40 PM   #9592
asw7576's Avatar
What is the difference between XRAY T1 "Factory Kit" and "EVO2" ?
Some says the Factory Kit is lighter due to thin alluminium chassis but using the newer metal call T6 alluminium ? Is this true ?
Old 10-24-2004, 10:57 PM   #9593
The belt shouldn't be rubbing at all. Check for a larger spur gear.
mtc3od is offline   Reply With Quote
Old 10-24-2004, 11:32 PM   #9594
asw7576's Avatar
Nevermind...... I've got it myself :
New features include:
C-hub style suspension with short arms
Lightweight bulkheads with new roll center positions
Stiff carbon upper deck
Light rear diff with carbide diff balls and thrust bearing
Light front oneway axle with with dual slotted outdrives
Ultra light driveshafts made of Hudy spring steel
Light wheel axles
Efficient low-ratio pulley set and light aluminum top shaft
New rear shock tower with new shock and roll center mounting holes.
Old 10-25-2004, 05:37 AM   #9595
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default OK
Guys,
was almost at the end of building my factory xray kit, how i was dissapointed in the crap of the shocks that they have in the kit. Why the hell where trhey not aluminium. anyway the f### threads are crossed threaded, i can't see how the adjustab;e shocks work.
does anyone know if they make decent aluminium ones
regards brad
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 10-25-2004, 06:03 AM   #9596
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Brad, you can build them either non-adjustable or adjustable.
As far as plastic v's alu goes, it really doesnt make a huge difference as far I have seen, the only real difference could be the strength of the threading on the shock bodies themselves. You always need to a little careful as that kind of thing is usually a pretty fine thread...
v0rtex is offline   Reply With Quote
Old 10-25-2004, 10:16 AM   #9597
Suspended
Trader Rating: 9 (91%+)
Hi, I have a T1R with the new low ratio set, I run 87 spur and 28 pinion (for tight track) and find the belt does not touch, although very close.
mazmorbid is offline   Reply With Quote
Old 10-25-2004, 10:45 AM   #9598
If you are running 28/87 you must be cooking the motor. I only use that sort of ratio on a large outdoor track. Indoors on carpet we were risking overheating our stocks on 21/93
TraceRacing is offline   Reply With Quote
Old 10-25-2004, 10:54 AM   #9599
Default Re: OK
Originally posted by OHBRAD
Guys,
was almost at the end of building my factory xray kit, how i was disappointed in the crap of the shocks that they have in the kit. Why the hell where trhey not aluminum. anyway the f### threads are crossed threaded, i can't see how the adjustab;e shocks work.
does anyone know if they make decent aluminum ones
regards brad
Here you go. This is how you correct the problem.
http://www.teamxray.com/teamxray/pro...&kategoria=868
Hondaguy is offline   Reply With Quote
Old 10-25-2004, 12:00 PM   #9600
Rob Mincey's Avatar
Good grief. That's a 5.49 FDR. What is the temperature of your motor when it comes off the track?
Rob
