Xray T1
Old 10-24-2004, 12:34 PM
  #9571
nick51's Avatar
wut all would i need to put short arms on my t1raycer
nick51 is offline
Old 10-24-2004, 06:32 PM
  #9572
Rob Mincey's Avatar
Just thought I'd post a couple of pics of my T1FK.
Rob
Rob Mincey is offline
Old 10-24-2004, 06:34 PM
  #9573
Rob Mincey's Avatar
One more...
Old 10-24-2004, 06:35 PM
  #9574
Rob Mincey's Avatar
EDIT:
Old 10-24-2004, 06:36 PM
  #9575
JDXray's Avatar
Rob, that is a sweet FK. I like the fan on the bulkhead.
How do you like your VFS ESC??
Jon
JDXray is offline
  #9576
Rob Mincey's Avatar
Last one:
Old 10-24-2004, 06:40 PM
  #9577
Rob Mincey's Avatar
The VFS rocks. I ditched my GT7 for a Keyence Zero V Extreme, and then changed from the Keyence to the VFS-2000 and love it. I've got a profile loaded on there that's aggressive for stock and 19T but fairly easy on the comm too. The programmability is impressive.
As for the fan... yeah, that's just one of the Associated replacement fans zip-tied onto the bulkheads. I've been running it so that the fan blows hot air away from the brush hoods but I think it does a better job of cooling the motor when it blows cool air onto the hoods. Going to change things around for this weekend.
Rob
Old 10-24-2004, 06:45 PM
  #9578
JDXray's Avatar
Rob
Thansk for reply, i was thinking of getting the VFS or Zero V EXtreme.
I would have never thought to blow hot air away from motor just cool air at the motor. Does it keep the motor cool?
JDXray is offline
Old 10-24-2004, 06:52 PM
  #9579
Rob Mincey's Avatar
I think if it were a little closer to the motor, blowing hot air away from the hoods (and consequently sucking air in through the vents at the pinion-end of the car and out through the hoods) might be good. I need to check the temps after a run with the fan blowing both directions to have more objective info, though.
Rob
Old 10-24-2004, 06:53 PM
  #9580
JDXray's Avatar
Rob
Sounds good, let us know. I would maybe try it. Thanks again
Jon
JDXray is offline
Old 10-24-2004, 06:57 PM
  #9581
Rob Mincey's Avatar
Nick, I think all you need are the arms themselves. I've seen an Evo2 FOC with short arms and I don't think there was anything different about the car other than the arms. I'll ask the guy who was running it that way and let you know.
Rob
Old 10-24-2004, 07:10 PM
  #9582
ChrisP's Avatar
There are a lot of minor differences betweent he FOC and the FK....
Hexes are lightened on the FK....No center one-way on the FK(front one-way instead)...lightened outdrives...lightened bulkheads with alternative roll center positions...low ratio pulley kit...solid upper deck instead of flexible deck...
There are other items, but that's a start on the differences
ChrisP is offline
Old 10-24-2004, 07:12 PM
  #9583
Scrad's Avatar
Trader Rating: 15 (100%+)
For you guys running with the rear shock on the outer bottom hole. What size of spacer are you using inside the rim. Or are you cutting the rim down. Also what is the max width the rear can be?
Does anyone know if Losi shock oil is thicker or thinner than Associated?
Scrad is offline
Old 10-24-2004, 07:26 PM
  #9584
S-T-R-l-K-E-R's Avatar
losi rob - you fk looks awesome
what is the weight of your purple springs?
what shock oil do you have in it? fr & rr
keep me updated with your "fan experiment" want to see how well it cools the motor.
S-T-R-l-K-E-R is offline
Old 10-24-2004, 07:27 PM
  #9585
i use it like that and i noticed that i am cutting the shock ends. actually instead of it being circular it now v shaped.
