Xray T1
#9511
Again, I would go Kt but where you are living it would probably take a while either way.
#9512
Both Speedtech and KT are excelent shops and will help you know matter what. You can't go wrong with either.
#9513
Re: Also known as a toroid ferrite magnet
Originally posted by Disaster
It adds inductance which filters out noise. Not sure what Yokomo sells them for but they are available from most electronic retailers for a buck or two.
All about Toroids
Cheap Toroid source
All about Toroids
Cheap Toroid source
http://www.radioshack.com/product.as...t%5Fid=273-104
#9515
Originally posted by ALBERTO
those are actually fairly large like half the size a pack of cigeretts. plus you need extra wire to wrap around the RF choke. Ya might want to find something a bit smaller....
#9517
#9518
Stupid question, I know, but gotta ask anyway.
I need to do some diff maintenance and I think the thrust bearing is to blame for the chunky feeling in the diff. Everything else has been cleaned and reassembled. The diff rings were flipped over so they're good. I haven't replaced the balls, but the "chunkyness" only occurs when you spin the outdrive containing the thrust bearing, so...
Anyway, is there a way to remove the "hog ring" or c-clip that holds the washers and thrust bearing in the outdrive without a pair of hog ring pliers?
Anybody got a good way to do this?
Rob
Rob
#9520
Thanks, Kory. I'll try that.
Rob
Rob
#9523
Rob
Rob
#9524
=MisFitz=Nuke,
Did you get your car yet? What's the status of the anodizing and how much $$$ is it going to cost?
Hit me back,
P2
Hit me back,
P2
