Old 10-16-2004, 02:43 PM   #9466
Neil Rabara's Avatar
Originally posted by pucho
To answer your question from sometime ago. Yes the bulkheads and somo of the other parts are coated. My guys striped them for me. The aluminum that Xray uses is more like 2024 than 6061 the diference is that the color will be darker for the 2024 compared to the 6061 stuff. We did one car in black and one it red and I tell you try look awesome. You also have to nake sure that all the NON aluminum items are removed (setscrews, orings, etc.) Hope this helps.
Very nice. You should post the website or place of the shop that did it.
Neil Rabara is offline   Reply With Quote
Old 10-17-2004, 01:03 PM   #9467
JDXray's Avatar
Send a message via AIM to JDXray
If i were to get the BMI Xray Chassis would i have to set my car up different since it will become stiffer?? (I am running a T1R) And i hear that the BMI chassis will not perform as well on the T1R than an FK. Is that true??
Jon
JDXray is offline   Reply With Quote
Old 10-17-2004, 01:20 PM   #9468
N4S
N4S's Avatar
The bmi chassis will change the way you need to set up the car. As for not performing as well on the t1r that is not true. I run the t1r components on my chassis. The difference between the two is flex. your suspension set up on a car that has alot of flex is not as critical as a stiff chassis. A novice driver would not likely feel the difference as much as someone with a higher level of skill. Hope this helps.
N4S is offline   Reply With Quote
Old 10-17-2004, 02:19 PM   #9469
JDXray's Avatar
Thanks N4S, but what would i have to change moving to a BMI Chassis.
Jon
Old 10-17-2004, 02:31 PM   #9470
N4S
N4S's Avatar
It depends on how the car feels to your driving style........ You will probably switch shock oil weights and or springs. With the stiff chassis you will want to go a little softer on spring rate. If you have ever noticed with the FK , EVO2 , and their 1/12 tc all which have carbon chassis they come with the white springs , but the t1r comes with purple and blue. Its all in how you drive it. I have seen people stay with the stock set up and love it. It also depends on the surface you race on. The only way to learn is to play with set ups. dont try a bunch of things at once because you wont know what change did what. do one at a time and see how you like it.
Old 10-17-2004, 02:35 PM   #9471
pucho's Avatar
Send a message via AIM to pucho
Neal:
It's a local shop that does mainly industrial stuff. They don't have a site. But it's called Peninsula Metal finishing.
pucho is offline   Reply With Quote
Old 10-17-2004, 02:43 PM   #9472
JDXray's Avatar
Thanks again i will try it out thanks..
Jon
Old 10-17-2004, 06:50 PM   #9473
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Talking
Hopefull customs will be on our side this week!!
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 10-18-2004, 10:23 AM   #9474
Default Understeer
Hi guys!
Would appreciate your help on understeer problem on FK. Any suggestions? Some say 0 deg c-hub will help give more steering...will this help?
Thanks in advance.
Explorer is offline   Reply With Quote
Old 10-18-2004, 10:36 AM   #9475
mtveten's Avatar
Trader Rating: 27 (100%+)
That's what I figured. However a shop ownere here mentioned the Horizon thing to me. Perhaps she may be confused as the only shop that actually has parts at this time.
I believe that Horizon had a partial distributorship that is no more. When I checked a week or so ago they were showing all out of stock X-Ray items as discontunied.
mtveten is offline   Reply With Quote
Old 10-18-2004, 10:39 AM   #9476
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Mark, What happened to you Xray in the Main yesterday. Why did you have to switch cars?
tamiyarcracer is offline   Reply With Quote
Old 10-18-2004, 10:57 AM   #9477
mtveten's Avatar
The colision that took me out of the 4th qualifier broke more than I thought. I guess I was afraid to check parts I didn't have replacements for, So I did the quick switch to pops car but it was worse than my broken one.
I must have forgotten my luck back at the hotel because I sure didn't have it yesterday.
Mark
BTW how did your race go?
Old 10-18-2004, 11:09 AM   #9478
You know how hack fests can be??
And Todd and I had fixation on each others car when ever we got close to each other. one of those time when I don't want tohit another car so much that you cant stop hitting them. Then when some one would pass me, they went trough me to get ahead of me.
Old 10-18-2004, 11:38 AM   #9479
mtveten's Avatar
Well atleat your battle was with a buddy. I know what ya mean about the rough driving, it was far worse than usual for that group, I felt like I was @ Fantasy World.
Mark
Old 10-18-2004, 11:41 AM   #9480
maybe I need to run at FW so I can get used to it
