Old 10-13-2004, 06:12 PM   #9451
war11x's Avatar
Trader Rating: 17 (100%+)
Originally posted by JDXray
Did you set-up the Gt7 when you switched cars?? And did you try a 75 mhz radio?
Jon
John
we use 29/27 meg here in Australia the GT7 was set up the same in both cars ( Programming )
war11x is offline   Reply With Quote
Old 10-13-2004, 06:14 PM   #9452
JDXray's Avatar
Send a message via AIM to JDXray
Originally posted by war11x
John
Oh didnt know that.. well do you have any metal objects around the kit? Sometimes when you switch the car on and put an allen wrench near it, it starts to glitch.. Other than that, sorry i cant help you maybe someone else can.
Jon
JDXray is offline   Reply With Quote
Old 10-13-2004, 06:18 PM   #9453
Neil Rabara's Avatar
It sounds like you have tried everything you can think of. The only thing I can offer is use the FK items on the Evo2 chassis, and vice versa. Perhaps it could be the graphite.
Neil Rabara is offline   Reply With Quote
Old 10-13-2004, 06:29 PM   #9454
war11x's Avatar
Thanks Neil
i will try the top deck and see if that changes
other wise stay tuned in the FORSALE THREAD
CHEERS TO ALL
Old 10-13-2004, 08:41 PM   #9455
D Hall's Avatar
Default another supplier........
I put in an order with precision rc http://www.precisionrc.com/
and they shipped it complete from Hong Kong and was at my door in seven days. The order included several hard to find X-Ray items that are needed to keep your car on the track.
Thought I'd let you guys know.
Hall Ass Racing
CFX Paintworks @ www.cfxpaintworks.com
OC Circuit @ www.socal.rcracing.com
D Hall is offline   Reply With Quote
Old 10-13-2004, 11:50 PM   #9456
Default Re: FK Glitching
Ok i know that this question has been asked a few times or so , and i have looked back and cant seem to find the answers
I have not long ago purchased fk and installed all electrics from my EVO-2 ( never clitched )
now my new FK Clitches like it is having a fit of some sort , i have tried changing the antena around , rerouting the aerial , inclosing the aerial from the receiver in fuel tube , but still no luck , if i put it all back into my EVO-2 all is fine
i am running 27 meg FM with Novak GT7 and either a P2K or Monster
Did Xray change thier carbonfibre in theFK to a more Metallic Fibre or is somone above giving me a hard time
all coments considered
Thank you
War11x - look for the most obvious tings first. look for damaged/loose wires, try different crystals, different motors even borrow a mod motor they are less likely to exhibit glitching, solder the capacitor points on the end of the epic motors. etc
Also get someone else at the track to take a look, it can sometimes be something obvious that you cant see.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-14-2004, 03:13 AM   #9457
I would check whether the brush wire on the negative pole hits the chassis. I allways have a piece of electrical tape on the chassis underneath the endbell to prevent this as you can get interference otherwise. Also when mounting the antenna use the biggest plastic spacer that comes with the kit to raise the antenna a bit higher away from the chassis.
Tony Vredenberg
tonyv is offline   Reply With Quote
Old 10-14-2004, 05:24 AM   #9458
N4S
N4S's Avatar
Did you seal the edges of the chassis with ca? I seal every edge of the car even the cut out for the motor . Try it.
N4S is offline   Reply With Quote
Old 10-15-2004, 06:41 AM   #9459
JHardy's Avatar
Default Im needy
anyone have a set of low ratio gears or shock springs they want to sell? I am looking for a yellow and blue set actually.
JHardy is offline   Reply With Quote
Old 10-15-2004, 07:23 AM   #9460
pucho's Avatar
Send a message via AIM to pucho
Originally posted by Randy Caster
You dont understand, I hate removing anodizing with a passion, lol, it's just such a bitch to do.
To answer your question from sometime ago. Yes the bulkheads and somo of the other parts are coated. My guys striped them for me. The aluminum that Xray uses is more like 2024 than 6061 the diference is that the color will be darker for the 2024 compared to the 6061 stuff. We did one car in black and one it red and I tell you try look awesome. You also have to nake sure that all the NON aluminum items are removed (setscrews, orings, etc.) Hope this helps.
pucho is offline   Reply With Quote
Old 10-15-2004, 09:07 AM   #9461
JDXray's Avatar
pucho that is sweet! nice black bulkheads.
Old 10-15-2004, 09:33 AM   #9462
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Wow, how did you do this and how did you get a red one?
JohnMatrix is offline   Reply With Quote
Old 10-15-2004, 10:09 AM   #9463
JusBox's Avatar
It's called anodizing. You strip the old anodizing off and redo it in the color you want. It's a chemical process.
JusBox is offline   Reply With Quote
Old 10-15-2004, 03:07 PM   #9464
Provided its aluminum only....
Some guy sells home kits for doing your own anodizing if you want. Plus he sells a book that explains everything including the process and tips and tricks.
http://www.focuser.com/atm/anodize/anodize99.html
LeadFoot is offline   Reply With Quote
Old 10-16-2004, 11:07 AM   #9465
A_Stratus's Avatar
Does anybody have a good setup for a Original T1 on Ozite?
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
