Xray T1
#9213
Originally posted by rayhuang
Can anyone confirm existence of Hard rear short c-hub arms? And if yes-a part number?
Ray
Ray
#9215
i have heard and have some hard rear but not in the short version.
#9216
Originally posted by tonyv
For an extensive explanation of caster and other setup options follow this link and download the latest Hudy setup booklet: http://www.hudy.net/xhudy/products/p...62&kategoria=0
Tony Vredenberg
Team XRay
Tony Vredenberg
Team XRay
#9217
Thanks-I'll continue my search for a part number now.
#9218
you need to save the file to your computer then use winzip to open it up.
#9219
Hi,
Just a couple of questions.
1) What front shock tower are people running with foams on carpet? I have seen #302096 Shock Tower Front - Factory Kit
and wondered if you can really notice the difference?
2) Does anybody know who carries part # #302205 Ackermann Extension Plate ?
Thanks, Mike
Thanks, Mike
#9221
you guys have probibly already covered this but is a t1 factory just a lighter slightly faster version of the t1r cos i wanna keep the rigidy and strength of the t1r but have the speed and waight of the t1 what could i do i already have the carbon top deck and shock towers can you guys also tell me what i kneed to get to do this
#9222
- low ratio pulleys
- hollow alum. layshaft
- alum. c-hub kit
- ultimate spring set
#9224
i also got the spring steel layshaft and i alredy have the alloy chubs and sterring blocks cos the plastic 1s are to fragile i want to get the low ratio pully set but i dont know if it will affect anything cos im racing[dominating] in stock on a reguler basis i beat t1 factorys and ovo 2s just goes to show that the crapper car can still be good
#9225
pink Pac Man
i changed my T1R to Evo ( chassis also) spec inc the low ratio pully kit , what i should have done was wait and baught a FK with the $$$$ it cost to build the T1R Oh well i have plenty of spares now
i found with the low ratio kit i had more out of the cornners and kept top end after changing my gearing to suit
i run my Evo Spec T1R in mod ( Brushless) and my FK in Stock , you can get the low ratio kit from HK for US$20 + Shipping , i would suggest you get one and try it out if you dont like it or your driving lags change back , you can always resell the pulley kit
you dont always need a fast car to stay at the pointy end of the field , but hell its good when you do and can
Cheers
