Old 09-16-2004, 07:25 PM   #8986
Send a message via AIM to Fstng00
yeah i have started racing there. i have been twice so far also over at superior.What about u?
Fstng00 is offline   Reply With Quote
Old 09-16-2004, 07:33 PM   #8987
If you are going to be at tq tomorrow I have to drop by and pick some stuff up. I can give you a good setup. Where do you pit and I will find you. I'm usually pitting with tony padilla or jeff phares.
zjp_rc_racer is offline   Reply With Quote
Old 09-16-2004, 07:40 PM   #8988
Default i
i will not be there tomorrow going out of town this weekend. maybe i could get a hold of u for the weekend after?
Old 09-16-2004, 07:41 PM   #8989
Neil Rabara's Avatar
Originally posted by Randy Caster
You are the Weissest of us all.
Randy, getting an Xray?
Neil Rabara is offline   Reply With Quote
Old 09-16-2004, 07:42 PM   #8990
Originally posted by Evicerator
I went to Bratislava once...it was nice... I was there for about a month... it cost me $17.89
Where the hell is that?
Old 09-16-2004, 09:33 PM   #8991
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default Re: front and rear shock tower
Originally posted by OVA
Question :shock Hole number 1, it is the outer or inner hole of the shock tower?
anybody know?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-16-2004, 10:05 PM   #8992
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
Default Re: Re: front and rear shock tower
anybody know?
start counting from the inner
S-T-R-l-K-E-R is offline   Reply With Quote
Old 09-16-2004, 10:28 PM   #8993
Randy Caster's Avatar
Trader Rating: 46 (100%+)
When they become avalible in the US It'll be nice to have an actual distributor dedicated to XRay/Hudy though.
Old 09-16-2004, 10:29 PM   #8994
BTW, I have heard in the past that the spring steel front axles are a necissary part, but they are discontinued now, do the factory kit ones work just as good?
Old 09-16-2004, 10:47 PM   #8995
I am pretty sure it is only the narrow old pillow ball fronts that have been cancelled, the long (22mm i think) should still be available. Someone will surely post the part number, i think they are listed by xray as rears but they are the same front to rear on the new car.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-16-2004, 11:35 PM   #8996
dal bains's Avatar
Trader Rating: 35 (100%+)
Default drive shafts
Factory Kit---
The parts number is 305321- Drive shaft-51mm-Spring Steel (2), the manual has the name part number used for the front and rear...
dal bains is offline   Reply With Quote
Old 09-17-2004, 06:17 AM   #8997
theisgroup's Avatar
actually the part number i think he is looking for is #305315 Wheel Axle - 22 mm - Integr. Hex Hub - Spring Steel (2).
the part you refer to comes on the factory kit as stock
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 09-17-2004, 08:22 AM   #8998
R/C Tech Charter Subscriber
The ones you are thinking of are the short ones for the pivot ball suspension. The ones for the Chub suspension are the same as the rear for pivot ball and they are use all the way around. The ones on the FT are the basic aluminum stock ones just milled out on the face that the wheel mounts to. I'm sure it still flares out like the old ones. I would definitely suggest getting the spring steel ones for the front.
NismoSkyline17 is offline   Reply With Quote
Old 09-17-2004, 08:30 AM   #8999
Send a message via Yahoo to fotosaccion
Default Team Tamale Xray Parts
Hey guys... My name is Hector and I just purchased a new Xray.....
Is it true that Team Tamale Xray Aluminum parts are guarunteed not to bend?? If they do bend they will replace them...? I thought I read that on this forum, but i cannot find any info on their website about it.....
Thanks!!!
fotosaccion is offline   Reply With Quote
Old 09-17-2004, 08:38 AM   #9000
theisgroup's Avatar
hector,
yes they are guaranteed. Just talk to larry b. he runs at mikes as well
yang lai
