Old 09-15-2004, 02:35 PM   #8971
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
perhaps someone can help me out . I got one of those low ratio pulley sets and i'm kind of lost (not uncommon with me) . On the Lay shaft do i keep the one way gear or do i replace it. The kit comes with 2 18 tooth gears , do both go on the lay shaft???? if so how or can you point me in the right direction!!!! THANKS A BUNCH, ALBERTO......
still fishing
ALBERTO is offline   Reply With Quote
Old 09-15-2004, 04:26 PM   #8972
Randy Caster's Avatar
Trader Rating: 46 (100%+)
They should be shipping kits next week from what I understand.
Old 09-15-2004, 04:31 PM   #8973
theisgroup's Avatar
you can not use the one way shaft with the 1.77 gears, you need a solid alum layshaft. and yes both 18 gears go on the layshaft
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 09-15-2004, 04:32 PM   #8974
The Evicerator
I went to Bratislava once...it was nice... I was there for about a month... it cost me $17.89
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-15-2004, 04:35 PM   #8975
TeamButter's Avatar
Send a message via AIM to TeamButter
Weiss- Another one of your random gems of info. We should start a thread for you.
YAYOO!!!!!
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 09-15-2004, 04:37 PM   #8976
The Evicerator
Yes, that's all I'm good for: little bits of useless knowledge.
*sigh*
Steve Weiss
Old 09-15-2004, 05:11 PM   #8977
ALBERTO's Avatar
thank you !!!!!!!!!!!!
still fishing
Old 09-15-2004, 07:56 PM   #8978
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
All good things come to those who wait! lol.. As they say..
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 09-16-2004, 01:43 AM   #8979
*sigh*
You are the Weissest of us all.
Old 09-16-2004, 07:17 AM   #8980
JDXray's Avatar
Send a message via AIM to JDXray
Default couple q's
When checking droop you disconnect the shocks correct?
And i was looking to Shim my car by putting some on the c-hub and rear uprights. How many should i put on? mm?
-JD
JDXray is offline   Reply With Quote
Old 09-16-2004, 08:24 AM   #8981
rayhuang's Avatar
Default Re: couple q's
-JD
When checking droop you disconnect the shocks correct? yes-its more accurate
NOw onto the second question-theres no reason to shim-up the ballstuds unless you have a reason to or someone gives you a set-up for a particuar track that calls for it.
I dont know what shimming-up the ballstud on the caster block does (I havent tried it yet), but in back it frees up the rear end of the car for more corner speed. Of course-you do it if your car feels in NASCAR terms "tight".
It could be the trick you need-or your car might just get loose.
Old 09-16-2004, 09:42 AM   #8982
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default front and rear shock tower
Question :shock Hole number 1, it is the outer or inner hole of the shock tower?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-16-2004, 03:36 PM   #8983
Send a message via AIM to Fstng00
Default setup
i was wondering if anyone can give me a good starting setup for a smooth asphalt track it has a good amount of traction just built my new car and need a setup to start with
Fstng00 is offline   Reply With Quote
Old 09-16-2004, 03:39 PM   #8984
nick51's Avatar
Send a message via AIM to nick51
try this https://www.mytsn.com/setups/setup.asp?sid=2643
nick51 is offline   Reply With Quote
Old 09-16-2004, 03:41 PM   #8985
Fstng00-I noticed you live in Orlando.Are you planning to race at tq hobbies?
zjp_rc_racer is offline   Reply With Quote
