Old 09-11-2004, 08:12 PM   #8911
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
brial - i intend to use a losi alfa for my next body. i just wanted to try to get it by means of set-up. if all else fails losi alfa is the answer.
jdxray - i am almost certain that more caster would result in more initial turn in and less exit steering. and less caster would lessen initial turn in and ad more exit steering.
thanks for your replies. need more inputs thanks!!!!
S-T-R-l-K-E-R is offline   Reply With Quote
Old 09-11-2004, 10:08 PM   #8912
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
try taking some droop off the front, this will take some weight off the rear tyres when coming out of the corner or try lengthening the front upper link to the middle upper hole on the shock tower, is the pushing happening on high speed corners or slow corners?
dontfeelcold is offline   Reply With Quote
Old 09-12-2004, 07:41 AM   #8913
it usually happens on slow corners upon exiting to the straight
Old 09-12-2004, 07:53 AM   #8914
JDXray's Avatar
Send a message via AIM to JDXray
Default 134t Spur Gear
I thought i saw someone asking about buying a 134t Spur gear on some website? Is there a 134t spur gear and where could i get one? thanks
-Jon
JDXray is offline   Reply With Quote
Old 09-12-2004, 08:30 AM   #8915
Can you use a 64p spur gear? I have a pretty good number of 64p pinions already.
kevinm is offline   Reply With Quote
Old 09-12-2004, 08:31 AM   #8916
JDXray's Avatar
yes you can use 64pitch spur gears.
Old 09-12-2004, 09:02 AM   #8917
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Default Spring steel axles or Factory Kit Alum?
Are the spring stel axles considered better than the lightened axles that come in the factory kit, I have both and just wondered which ones to buld the car with. Thanks for any info.
TAW is offline   Reply With Quote
Old 09-12-2004, 09:25 AM   #8918
JDXray's Avatar
Well on my t1r the axles can get grooved so i would consider getting spring steel axles. For the FK those axles seem better strong, i havent seen any grooves yet but you never know.
-Jon
Old 09-12-2004, 09:47 AM   #8919
Rob Mincey's Avatar
Default Re: 134t Spur Gear
-Jon
Here's the site:
http://www.precisionracingsystems.com/default2.htm
According to Greg Hodapp, they manufacture 134t spurs, but they aren't listed on the site. Apparently, you can contact them directly to get them. They're supposed to be EXCELLENT spurs.
Rob
Rob Mincey is offline   Reply With Quote
Old 09-12-2004, 09:55 AM   #8920
JDXray's Avatar
THanks Rob, thats exactly what i wanted to see. Thanks.
-Jon
Old 09-12-2004, 12:31 PM   #8921
stumper1's Avatar
R/C Tech Charter Subscriber
Default Re: Re: 134t Spur Gear
Originally posted by losirob
Here's the site:
Rob
I e-mailed them and they said they do not make 134t/64p spurs. The largest listed on their site is 132. I tried to order one a couple of weeks ago and it turned out they weren't in stock. Since then they haven't replied to my e-mail. I saw a post in the main electric forum asking if they were still in business. Seems they have not been responding to others e-mail also. I guess I'll wait a few days and try agian. I would really like to have a spur that size - and I have heard that they make awesome stuff.
stumper1 is offline   Reply With Quote
Old 09-12-2004, 07:17 PM   #8922
JDXray's Avatar
Oh, i emailed them today on the same thing, but they havent responded.
So do they have them or not? And who does?
-Jon
Old 09-12-2004, 07:26 PM   #8923
Send a message via AIM to micros_rock
Default Quick question...
Will the AE springs work with the Xray shocks? Thanks.
micros_rock is offline   Reply With Quote
Old 09-12-2004, 07:27 PM   #8924
JDXray's Avatar
They should i use Xray springs on TC3 shocks.
-Jon
Old 09-12-2004, 07:28 PM   #8925
etzkev's Avatar
Send a message via AIM to etzkev
Default Re: Quick question...
Actually, they will work, but not properly. Xray springs should be used.
-Kevin
etzkev is offline   Reply With Quote
