Old 03-17-2002, 06:16 PM   #871
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I haven't tried them yet, but I have them sitting in my parts stash.
They SHOULDN'T be any different than the nylon arms, but I guess if they're so much stiffer, they may change the effective spring rate of the back end.
Try dropping one spring weight, open up another hole in the piston, or lay the shock down one hole to see if that gets the back in back in line.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 03-17-2002, 06:37 PM   #872
Peter Busch's Avatar
R/C Tech Charter Subscriber
Jeff, thats cool.
Today I tried all sorts of shock positions, springs, and dampning. It helped to go softer in the rear but it still wasn't enough. What about droop screws? I didn't think to try messing with them today but what would the general effect be? The book doesn't really give much of an explanation of them.
Peter Busch is offline   Reply With Quote
Old 03-17-2002, 06:58 PM   #873
Ps. I ran the diff today and it was way better then the one way.
The car ran really good but I can never seem to have enough rear traction.
Old 03-17-2002, 08:35 PM   #874
Are serpent blue springs stiffer then X ray yellow?
Where can I get a set?
Old 03-17-2002, 09:34 PM   #875
Thistle's Avatar
Send a message via MSN to Thistle
This may sound like a stupid question... But are your tires the same size? If they're different, and you're running the one-way locked, you'll have traction problems.
Thistle is offline   Reply With Quote
Old 03-18-2002, 05:19 AM   #876
They were all the same when I put them on, trued at 61mm but you are right, I wasn't paying attention and after about 10 runs the front were 2mm smaller. I retrued them all so I hope that helps.
Old 03-18-2002, 06:45 AM   #877
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by spongebob
Do you guys find it harder to get the back end to hook up with the aluminum rear arms (those who are running them) ?
The problem is the rear end is comming around when I get on the gas.
Are you running the mid one-way loose? If you are then check your mid one-way; grab hold of it and try to turn the spur gear in the 'locked' direction if there is ANY slipping then that will be your problem. 9 Xrays out of 10 Xrays with a loose rear end is the mid one-way...pull it apart, clean and epoxy it back in....problem solved.....for a few more months!!! Alternatively just lock it out!
dtm is offline   Reply With Quote
Old 03-18-2002, 02:06 PM   #878
Peter, The blue springs are stiffer. I got a set, but didn't try them yet. That's one of the big things I wanted to do Sunday. That, and play with my accentric arm mounts, and roll center bridge. Just kinda see what happens...
What is your setup right now? If anything, my car's a little loose in the sweeper at the end of the straight (driver induced )
but a little pushy the rest of the time.
JeffC is offline   Reply With Quote
Old 03-18-2002, 05:11 PM   #879
Just want to say "Hello" Fellow Xray T1 lovers, I will be the proud Father of 3 Xray's T1, I have now 2 in my arms. All 3 babies have the "Hudy Setup tools and the guages"
milf is offline   Reply With Quote
Old 03-18-2002, 06:49 PM   #880
Milf,
Welcome aboard!! I am in the bayarea as well. Where did you
purchase your XRAY? I know both Castle & Sheldons don't stock
them?
pisnonvtec is offline   Reply With Quote
Old 03-18-2002, 08:06 PM   #881
Usagi's Avatar
I am using those new shock shafts and set. Not bad..........
Usagi is offline   Reply With Quote
Old 03-18-2002, 08:28 PM   #882
Jeff, I changed my set up last night, I'll show it to you on thursday if you are there.
Usagi, do the clickers work better, some of mine are hard to feel the click (old style).
Buster did you get them in yet? and how about the 1 and 1.5mm rear anti roll bars????? Or is everything stuck in customs still
Old 03-18-2002, 09:14 PM   #883
Thistle's Avatar
Spongebob... 2mm shouldn't make that big of a difference. I was tweaking a guy's TC3 at the track last weekend. He had traction problems like you were describing, but his tires were 1/4 inch out!!! He wasn't running any kind of one-way to compensate for it.
Can you post your current set-up? or post a link to it?
Old 03-18-2002, 10:31 PM   #884
Buster Bennett's Avatar
Send a message via AIM to Buster Bennett
[i]
Buster did you get them in yet? and how about the 1 and 1.5mm rear anti roll bars????? Or is everything stuck in customs still [/B]
Sorry, But I did get SOME in, but not even close to enough to fill all of the backorders.....
Please remember, I can only sell what I get, and you can bet that I order plenty.........
I do have the sway bars however, and just about everything else.
Sorry I have been away from the forum, work has been hell....
Buster Bennett is offline   Reply With Quote
Old 03-18-2002, 10:36 PM   #885
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Buster-
I gave up on the Hellfire and went with the Core Stock Motor... same difference but I wanted to get one of them. . I hope I can hook up my car on the asphalt as well as you got me hooked up for the EC Champs with this motor . Thanks for the help you gave me. Are you going to stock the Springs from Peak? Also I am going to need to buy some Foam Tires for the outdoor season.
Thanks again for the help you gave me over the weekend... I will be back in 3 days.
Mike
mike_Webb is offline   Reply With Quote
