Old 08-27-2004, 06:25 PM   #8656
ok help! I just decided on getting an Xray ...after racing years with the TC3 and need to know what i need. I'll be racing on carpet and do i have to do anything special to mount jaco purple tires to the car or if it can be done already. I am racing a monster stock pro and need to know what pinion to use WITH the stock spur gear. This car is the Factory Team T1 so keep that in mind. I need an answer soon cause the car will arriv e in a few days and i want the tires here and pinon in time to completly assemble it.
rustler753 is offline   Reply With Quote
Old 08-27-2004, 08:15 PM   #8657
Oasis's Avatar
Trader Rating: 36 (100%+)
Anyone have a good set up for a T1R,short arm susp. for parking lot track,I'm going to give the Xray one last chance..I have never done very well with this car,I want to like Xrays but the one I have is just not up to speed.. All my other TC's are fast,TQ and win with them,best ever with the Xray is 3rd..
Oasis is offline   Reply With Quote
Old 08-28-2004, 03:09 AM   #8658
have you got the same gear ratio/rollout that might be why it's slow
Chazz
Chazz is offline   Reply With Quote
Old 08-28-2004, 05:01 AM   #8659
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
get a graphite chassis, the plastic chassis is to flexible
dontfeelcold is offline   Reply With Quote
Old 08-28-2004, 07:13 AM   #8660
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
I am going to be jumping onboard the xray bandwagon soon. Just wondering about the option and spare parts...
Do the standard axles wear out - is it worth gettting the spring steel set?
As for spares I was unsure about the following...
spare belts
spare diff pulleys or even complete diff/oneway sets
outdrives
hinge pins
Any other good spares to get other than arms and hubs?
Also how much weight does this chassis need to get to 1500g if using all the latest small electrics?
Ooj is offline   Reply With Quote
Old 08-28-2004, 07:55 AM   #8661
Pyramid's Avatar
Average at 100gr. Don't get any spare first, this car (T1 series) is a very strong car.
Pyramid is offline   Reply With Quote
Old 08-28-2004, 08:38 AM   #8662
Tom G's Avatar
Normally, I would encourage spares but I'll agree with the previous post only because in a carpet track, I've yet to replace anything because of breakage.
I do have a complete set of belts, upper and lower front and rear arms, and almost every other component to fix any of the corners. I have found myself lookin' for a shock rebuild kit to cure what I believe is excessive oil leaks [from the top and possibly the bottom end].
^5
Tom G is offline   Reply With Quote
Old 08-28-2004, 09:27 AM   #8663
Pyramid's Avatar
Originally posted by Neil Rabara
I don't think I have this part. I have an original FK.
It means the first batch.. even the newer batch that already have the 4 holes, the included part list sheet still stating the old 3 holes part number. I knew it because I mistakendly order the old one by reffering to the included part list sheet. Mostly, you will get your new 4 holes with the newer xray packaging for T1FK. Is a blue shiny box with T1FK printed as sticker, but some also still have old tower.
Old 08-28-2004, 09:31 AM   #8664
Oasis's Avatar
Ooj,Get the spring steel hubs in the front,It's not a wear issue on the stock hubs,they are just more prone to damage,For spare parts(even though I have never really broken much)I would have a set of hubs,set of knuckles,at least one front and rear A arms,I would also get the spare parts kit(extra screws,washers,C clips..etc.)I dont think you need spare belts..but you never know.On the hinge pins..If you bend one of these..wow,I think their would not be much of your car left..
Old 08-28-2004, 09:32 AM   #8665
Pyramid's Avatar
Originally posted by markp27
Somehow I always end up getting the old stuff
Mark, you bought too early while using them too late , I expect you have the first production packaging box that shows the picture of the car and all its new items highlighted.
Old 08-28-2004, 01:05 PM   #8666
some one please anwser my question, i am still waiting for a response.....read above. Oh yeah and where can i buy the Xray t1 factory that IS IN STOCK!!?? i ordered from rc-mushroom.com but i don't know if its in stock so any other sources would be great....and again answer my question above PLEASE
Old 08-28-2004, 01:36 PM   #8667
Tom G's Avatar
You may not have anyone anwering because they [we] are in the same boat as you.
Besides, it's the wekend, most are racin' or runnin' their stuff.....like we should be
Try Stormer's, if you haven't already.
Good luck!
Old 08-28-2004, 01:52 PM   #8668
i aslo asked if i need anything special for foam racing or can i buy the premounted jaco tires (purple i think is okay for carpet?) and just put them on? Also what is a good pinion to use with the stock spur gear for stock racing with a monster motor. I wana pre order this stuff so when the car arrives so will the wheels and stuff. I went to stormer hobbies and they as well as rcmart.com are sold out of the almight T1 factory kit!! I orderd from rc-mushroom.com but i have to wait to see if they are sold out becaue for some reason, these websites doen't tell you if they have it in stock, u just order it.
Old 08-28-2004, 01:56 PM   #8669
forty6's Avatar
Xray FK's are hard to come by as of yet because of the distributor change. I was told that they should be back on the shelves by mid to late September.
forty6 is offline   Reply With Quote
Old 08-28-2004, 02:44 PM   #8670
Tom G's Avatar
For tire, motor and pinion Qs, you wanna ask the local track racers what they are doing or running. They'll give you the best starting point regarding what to get ad what is a must have item(s).
Try e-mailing the e-tailers, they should be able to advise on their inventory. But as the previous post stated, this new distrbution change is affecting everyone right now.
^5
