Old 08-19-2004, 02:36 PM   #8551
Neil Rabara's Avatar
Originally posted by lazyboy
well id say more like med to low high grip, im running the t1r chassis and long arms, but soon to be getting a bmi chassis and short arms.
You can try putting the short arms on the plastic chassis. You might need to dremel.
Neil Rabara is offline   Reply With Quote
Old 08-19-2004, 03:06 PM   #8552
Scrad's Avatar
Trader Rating: 15 (100%+)
The short arms don't work that great on the T1R. I found that since the droop screws sit so far out on the chassis the droop is inconsistant. When you try to measure the droop by checking ride height and then pulling the chassis up you can see how much it flexes.
Scrad is offline   Reply With Quote
Old 08-19-2004, 03:36 PM   #8553
lazyboy's Avatar
Send a message via AIM to lazyboy
Originally posted by Scrad
Preston, check your pm.
back at ya
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 08-19-2004, 04:06 PM   #8554
etzkev's Avatar
Send a message via AIM to etzkev
Originally posted by JCB
For TRC: I like plaids front and purples rears.
For Jaco: Purple/Orange fronts, Purple Rears
Hope this helps.
This is exactly the "hot setup" around me as for foams on carpet.
JDXray,
No one posted this, but just so you know, most people run 28mm's all around. That seems to work the best.
etzkev is offline   Reply With Quote
Old 08-19-2004, 05:56 PM   #8555
JDXray's Avatar
Send a message via AIM to JDXray
sorry kevin, but what are 28mm's? Jacos? TRC?
JDXray is offline   Reply With Quote
Old 08-19-2004, 05:58 PM   #8556
I noticed that also. I pretty much abandoned the plastic chassis.
Old 08-19-2004, 06:24 PM   #8557
lazyboy's Avatar
same here, im getting my bmi stuff very soon
Random Guy
FT B4
Trackside hobbies
Old 08-19-2004, 09:07 PM   #8558
Scrad's Avatar
Yeah if your racing carpet make it stiff. I took my solid deck off of my original T1 drilled a hole in the middle of the deck exactly where the T1R deck has the hole for the brace support. Then I used the T1R brace with a spacer and used it on my evo2 plate chassis. Now the chassis is pretty stiff with that brace. I couldn't justify shelling out cash for a new chassis when I already had a spare.
Old 08-19-2004, 09:48 PM   #8559
etzkev's Avatar
You can get Jaco's and TRC's in 28mm. John's BSR tires are great too. Same thing goes with their compound and width.
-Kevin
Old 08-19-2004, 09:49 PM   #8560
JDXray's Avatar
okay thanks kevin.
Old 08-19-2004, 09:54 PM   #8561
etzkev's Avatar
okay thanks kevin.
No problem!
Old 08-19-2004, 09:55 PM   #8562
lazyboy's Avatar
im figureing out some roll out with that problem i had before, only problem now that i run across with is, can u get a mess with the gears 100/37,38,39,41??im thinking that this wount work but when i was doing rollout with about 2.125 tires and the old 2.125 internal i can go from a 1.3 to a 1.1 even to a 1.07 idk, this is the only car that ive owned to give me this much greef with finding the right gearing.
lazyboy
Random Guy
FT B4
Trackside hobbies
Old 08-20-2004, 07:14 AM   #8563
Scrad's Avatar
Preston, the largest pinion that I have is a 36 64p. I ran that at RR, which is larger than Trackside. I usually run a 128 or 124 spur gear.
Old 08-20-2004, 07:19 AM   #8564
theisgroup's Avatar
i would have to agree, a 100/37 is a lot of gear for almost any track. you would be at a 5.7 final. I don't even run a monster at that low of a ratio. I have geared some p2k2's that low.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-20-2004, 11:21 AM   #8565
lazyboy's Avatar
i knew something wasnt right after i posted that. ya i went over it again with my other two spurs and i think i might have found a decent gearing, but im not sure. i still cant get over why im having so many problems with finding a good finaldrive, oh well this car still kicks @$$, cant wait to put short arms on this car in a week...idk i should prolly stop looking at my pro4 for gearing help from now on lol, silly shaft drive cars
lazy
Random Guy
FT B4
Trackside hobbies
