Old 08-18-2004, 09:32 AM   #8536
JDXray's Avatar
Send a message via AIM to JDXray
in my t1r i have all around 2.125. I think i have another 2.125 diff i can put in his car. I have to check.
Whats your ideas on a spool in the front on carpet stock racing? No need to right?
JDXray is offline   Reply With Quote
Old 08-18-2004, 10:14 AM   #8537
Qwiglee's Avatar
Originally posted by JDXray
Right now i am running a 2.125 i think it is diff pullies. If change over to 1.77 would it make a big difference? Is 1.77 more for modified racing or stock racing, or is it just a change for either?
Before i go, another question. On my bros fk. I put that factory made diff in the rear but i didnt put the one-way in front. I think that factory diff is 1.77, i couldnt find another diff that had 1.77 so i just put an extra diff in from my other Xray. i believe it is 2.125. Is it bad to run 1.77 in rear and 2.125 in front? I tried loosening the front with postitioning bulkhead notch on loose but the belt is still tight. I think its from the different ratios. What should I do?
I dont feel like putting that one-way in, if i run carpet on a small-medium track.
Maybe someone already mentioned this but I think different ratios front and rear mean that front tires will be spinning at a different speed than the rear which would probably result in very poor handling. It's also a bad idea to have your belts too tight because of the extra drag it creates which is bad for your drivetrain and your motor...not to mention it just makes you slower.
Xray makes an option part called "low ratio pulley set" which will change all the pulleys on any T1 kit other than the FK which doesn't need them. In the low ratio set the diff pulleys are slightly smaller but also the center pulleys are larger. Be careful, I dont think the pulleys will fit on the optional one-way diff and I am not sure if they will fit a car with a center one-way.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 08-18-2004, 10:16 AM   #8538
JDXray's Avatar
thanks qwiglee, my bro put a spool in for now, he didnt want to take my extra diff. I guess he wanted to stay with 1.77. His belts are loose now after putting in the different diff. Thanks for the help guys.
Old 08-18-2004, 10:31 AM   #8539
lazyboy's Avatar
Send a message via AIM to lazyboy
IMPACTPLAYR
unforcently, im the only one running a xray on foams where i race, when i talk to the tc3 guys and the losi guys i try to convert it over to be as close as possible to there roll out but not being way off, the only time (for having this car for 3 weeks) i ever have problems with roll out are when im running my foams on the rim or close to it... my car likes small tires but it just gets harder and hard for me to get the gearing right to keep up with the other fast guys. my car to me scrubs off maybe a 10th a corner cuz the fast guys are doing 11.6's and im doing 11.9 and 11.8's, when i ran the cemelon i was fine and when i went to the cemelon 2 pro the car just was like "blah" down the straits and in the infeild... another thing that i did notice was that i also have a slight off-power push coming in to the corner coming off the sweaper and on the front strait aera of my track. im also running AE purples all around since i only have a small assortment of xray springs
lazyboy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 08-18-2004, 11:42 AM   #8540
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Preston, run about a 1.08 - 1.12" rollout for a Chameleon at trackside. Your best bet is to get the low ratio pulleys too.
And as far the car setup, well soon you'll have that taken care of.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-18-2004, 11:57 AM   #8541
Scrad's Avatar
Trader Rating: 15 (100%+)
Preston, I'll have to look at my set up sheets, ( I think they are in my car), I usually run about 58mm foams and a 128, 28 gear with the low ratio pullies. I run the Reedy. I ran at Trackside a few times last year, but didn't have much luck. I think I even used my T1R chassis and long arms there. At Road Rage my car handled pretty good on Med to High grip. I'd think Trackside right now is med grip right?
Scrad is offline   Reply With Quote
Old 08-18-2004, 12:07 PM   #8542
lazyboy's Avatar
well id say more like med to low high grip, im running the t1r chassis and long arms, but soon to be getting a bmi chassis and short arms.
Random Guy
FT B4
Trackside hobbies
Old 08-18-2004, 02:01 PM   #8543
Scrad's Avatar
I could only find my rubber setups. When you get the short arm stuff Pm me and I'll give you my setup off of my evo2. You should talk to Stephen I think he went to short arms on his Xray.
Old 08-18-2004, 03:10 PM   #8544
lazyboy's Avatar
from what i know stephen only switched to the c-hubs but idk about short arms. can you PM your rubber setup i dont care if its outdoors or indoors cuz ill be needing both next year
Random Guy
FT B4
Trackside hobbies
Old 08-18-2004, 08:43 PM   #8545
kuanseng1981's Avatar
Wink
test
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
Old 08-19-2004, 08:50 AM   #8546
JDXray's Avatar
What do you guys think of compound issues on carpet. What type of company, color, shores, etc would be a good pair of foams.
I have JACOs DBL Purple, DBL Pink. And DBL Orange pink (i think), DBL Purple. I seem to get more grip with DBL Purple and DBL Pink. But are there any other combos that are good.
I am interested in any company. (TRC, JACO, ELLEGI etc) If you could just list the company, color (if any), Shore (if any).
Jon
Old 08-19-2004, 08:56 AM   #8547
JCB
JCB's Avatar
For TRC: I like plaids front and purples rears.
For Jaco: Purple/Orange fronts, Purple Rears
Hope this helps.
JCB is offline   Reply With Quote
Old 08-19-2004, 09:04 AM   #8548
theisgroup's Avatar
i find that the jaco dbl pink/dbl pink and orange works about the same as the trc dbl purple\plaid combo
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-19-2004, 09:39 AM   #8549
JDXray's Avatar
thanks for the replies..
Old 08-19-2004, 01:34 PM   #8550
Scrad's Avatar
Preston, check your pm.
