Old 08-16-2004, 11:49 AM   #8491
Qwiglee's Avatar
Originally posted by MR JOLLY
Rear toe in
I tryied running 1 degree & it was awfull,then a experience x-ray driver told me allways stay at 3 degree
Does any one else go this way as well? this is on asphalt with rubber not them spongy looking things(foams)
Never get yourself locked into thinking that one setting must always be used. I always use 2 deg rear toe-in and I think I am an experienced Xray driver too..but I would never tell someone ALWAYS use 2 degree rear toe.
Just try different settings and use what works best for you but keep an open mind.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 08-16-2004, 03:29 PM   #8492
Tom G's Avatar
Qwig, thanks.
I realize that these "car" kits have their own little particulars, however, it took you guys to remind of simple basics [would have eventually thought of the rear toe in, you guys just saved me a bit of time and a lot frustration.....
^5s
Tom G is offline   Reply With Quote
Old 08-16-2004, 10:32 PM   #8493
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Default REAR TOE IN
I run 27t stock mostly, so i was under the impression to run as little toe in as poss to keep the speed up in a straight line also aiding accelleration & braking so that is why i was on 1 degree
But i suppose with a car with so much steering you properly have to run 2+ degree on the rear to keep it in line
Q) Would it have been better to run 6 degree castor blocks instead of std 3 degree
The problem i had just a little to much initial turn in(snatch)
Moving from 1 degree to 3 degree cured this but it then felt it lost it`s zip (to much slip angle on rear)
The handling of the car was 95% there it was just the last 5% i was after
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 08-17-2004, 03:21 AM   #8494
MrRolla's Avatar
Trader Rating: 29 (100%+)
Default Xray swaybar kit
Hi guys,
I just built my Factory Kit and found a swaybar set for sale, its from and original T1. Will this setup work on my FK?
Cheers Dave
MrRolla is offline   Reply With Quote
Old 08-17-2004, 05:41 AM   #8495
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Default Re: Performance/Set-up questions: Evo2 w/ pivot ball-long arm suspension
Originally posted by Tom G
The track [Mike's in Carrolton, TX] is considered a medium to high bite ozite track and mixed technical, or so I've been told [not enough experience yet to make determinations of my own].
Thanks gang!
Sorry to step back this far in the convo, but we are not racing on Ozite. We are running on the DuPont version and I feel it has much more consistant bite and the track is high-bite still.
Ninety percent of us (I'm using a FTTC3 at the moment) run XRAY's so there is ample help at the track. I would be willing to help you with your starting point or sweet-spot settings. Your driving style will dictate your settings.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 08-17-2004, 05:59 AM   #8496
fastolfart's Avatar
Dave, if the front bar is the blade type, it won't work on the FK.
The rear is the same on all X Rays
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Old 08-17-2004, 06:03 AM   #8497
P2
P2's Avatar
Default Re: REAR TOE IN
How much automatic brake to you have set on your radio/esc? When I run stock I adjust my throttle trim so the car will move at a walkingk pace when the radio is at neutral. This will help eliminate some initial turn in. You should try 2* rear toe in.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 08-17-2004, 06:37 AM   #8498
MrRolla's Avatar
Ok then ill make sure ill ask...
Thanks for that
Old 08-17-2004, 06:37 AM   #8499
new92's Avatar
This may be a dumb question but here goes anyway....oh yea, I am at work right now or I would try myself lol...but while I am thinking about it....
I have the T1R last series I was running a Monster with the stock 93 spur and a 28 pinion .....The 28 is the largest I can go when placing the pinion on the motor and then sliding it thru the bulkhead...the 29 will not fit in the opening in the bulkhead.
Can I put the motor on without the pinion then slide the pinion on after the motor is loosely mounted in the bulkhead.....I mean I know I physically CAN do it but would the larger pinion push the motor down too far or below the chassis? What is the biggest pinion you have run with the stock spur?
I will probably pick up some more spurs anyway, but just wondering if I need to get them before this weekend or can I wait a few days?
new92 is offline   Reply With Quote
Old 08-17-2004, 07:24 AM   #8500
jag88's Avatar
Just curious, how big is the track your running on ? 29 tooth pinion seems a tad large with a 93 tooth spur. The biggest pinion I've used with a moster stock and a 93 tooth spur is 25 and I though that was pushing it.
jag88 is offline   Reply With Quote
Old 08-17-2004, 07:36 AM   #8501
new92's Avatar
It is the only track I have ever raced on so I dont really have anything to compare it too. From what others have said though its pretty big. I was running the 28 pinion with the Monster to keep up with everyone else. The motor would get pretty hot but going any smaller and I was getting blown by on the straight. I will find a picture of the old layout...it is a banked oval, with the touring track in the infield.....the new layout uses a back straight just a tad longer than the oval straight (considering they have longer corners).
The 29 and higher pinion was going to be for the 19T we are running this series.
Here is a link to the picture page of the track...the webmaster of that site is an oval driver so you sorta have to look through the oval cars to see the layout lol. The touring layout has changed just a bit but the straight is just a bit longer than the old dirt straight.
http://home.comcast.net/~shawnleary/...ld/photos.html
THe site has it listed as a 360 ft drive line for the oval track.
Attached is an overhead view of the old layout but sorta hard to judge prospective.
Its a really really nice track, looking at the pictures it looks alot bigger than what I noticed when there lol....guess I never really noticed it when people are standing around for the scale effect lol.
Old 08-17-2004, 07:56 AM   #8502
jag88's Avatar
Your right, that's a nice track !! If the track is as large as it looks and your running a 19 turn maybe a 29 would be ok. It just seems like a lot of gear.
I just looked back a couple of posts and you said your running a T1R. Did you switch to the low ratio pulley set ? If not then larger pinions make more sense.
Old 08-17-2004, 08:02 AM   #8503
new92's Avatar
No, I still have the stock pulley set. I was debating off and on of getting the low ratio set. I think I am going to get a one-way first though. Thanks for the help and info.
Like I said I have never been anywhere else but this summer a few friends took a trip with some of the other guys from the track and all came back saying..."wow, our track IS huge" lol. I will be traveling soon though so we will see lol.
Old 08-17-2004, 09:01 AM   #8504
JDXray's Avatar
Send a message via AIM to JDXray
Default couple set up q's
Okay whats better for carpet stock racing?
3 degrees anti-dive or 0?
And same for Rear Anti-Squat?
0 or 3?
And for Caster blocks, If i were to run 3 degree anti-dive with 3 degree caster it would be 6 degree caster. But would it be the same as running 6 degree caster blocks with 0 degree anti-dive?
Sounds alittle confusing but any information would help.
Jon
JDXray is offline   Reply With Quote
Old 08-17-2004, 09:09 AM   #8505
new92's Avatar
This was just asked on mytsn...and I am glad you guys did because I was just thinking about this myself the other night.
Here is what was posted and the response:
Set up Difference RESPOND | ADD TO FAQ
KENNY CHAN (HK) 08.17.04 at 03:58
Hi Tony,
Would you please tell me if there is any difference between the two setups below assuming using C Hub configuration.
1. 0 degree anti-dive with 3 degree caster block;
2. 3 degree anti-dive with 0 degree caster block.
Thanks.
Regards,
Kenny
TONY VREDENBERG (NL) 08.17.04 at 11:27
Hi Kenny,
Yes there is a difference. While the effective caster (3 degrees) and resultant effect is the same, the difference is in the anti-dive (or in this case kick-up).
Running 0 degree anti-dive will result in less chassis roll compared to running 3 degrees (kick-up). On bumpy tracks running 3 degrees will make the car handle the bumps better.
So, if you want to run 3 degrees of caster, on bumpy tracks it is best to use setup 2, on smooth tracks setup 1 will work better.
