Old 08-11-2004, 06:46 PM   #8431
forty6's Avatar
Default Re: Spur Gears!
Originally posted by Hodapp
Try using the Precision Racing Products 134 tooth spur gear. They lower the motor quite a bit which improves handling. Not to mention that they are incredibly strong and are almost impossible to strip. I have been using one for 2 months now and no problems. Sure would like to have a spare just in case.
They make 134? I thought they only go up to 132.
forty6 is offline   Reply With Quote
Old 08-11-2004, 06:49 PM   #8432
Hodapp's Avatar
Send a message via AIM to Hodapp Send a message via Yahoo to Hodapp
They have 134's.
Hodapp is offline   Reply With Quote
Old 08-11-2004, 07:02 PM   #8433
forty6's Avatar
Greg,
Were you running the rigid chassis and new towers at the KO race?
p.s.
Congrats on the win!
Old 08-11-2004, 07:11 PM   #8434
Hodapp's Avatar
forty6 - Thanks. I was running the new front tower but not the new chassis. My complete setup, along with a race report will be on http://www.mytsn.com later tonight.
Old 08-11-2004, 07:37 PM   #8435
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I will call Tony at PRS tomorrow and let him know you need some more!! The newest batch coming should have the tooth numbers stamped on the spurs.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-11-2004, 07:56 PM   #8436
tmunno's Avatar
R/C Tech Charter Subscriber
Default Special Thanks...
Thanks to Jared Scott from Team X-Ray for all the help and work he did on my car last week at Speedline. If you ever need anything don't hesitate to ask. Thanks again.
Tony Munno
Munnograffix
CFX Paintworks,
tmunno is offline   Reply With Quote
Old 08-11-2004, 08:32 PM   #8437
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
have a little problem with rear end on highspeed sweepers. as the car reaches its apex the rear end tends to step out.
could adding spacers under the rear uprights help? or should i use the inner shock hole on the rear arms?. btw i'm already on the outermost hole on the shock tower.
thanks!!
S-T-R-l-K-E-R is offline   Reply With Quote
Old 08-11-2004, 09:35 PM   #8438
Hodapp's Avatar
S-T-R-I-K-E-R - What rear roll center are you using? Low roll center should step out the least. Inside hole on the arm will also help but you might lose some steering.
Old 08-11-2004, 09:45 PM   #8439
stumper1's Avatar
Default PRS - Precision Racing Products
Where can I get these spur gears? Do they fit the X-ray without modification?
stumper1 is offline   Reply With Quote
Old 08-11-2004, 09:55 PM   #8440
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
thanks!!
loosen rear diff maybe...
Kennedy is offline   Reply With Quote
Old 08-11-2004, 09:56 PM   #8441
Kennedy's Avatar
Default Re: Factory Kit
Originally posted by Kennedy
Hy Guys,
I've managed to strip the one way pulley and my belt kept on flipping upside down as a result. Is this available as a spare part or do I hve to buy adn entire one way diff again? If not what is the part #?
Many thx
Anyone?
Old 08-11-2004, 09:59 PM   #8442
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Default Re: PRS - Precision Racing Products
http://www.precisionracingsystems.com/ yes they fit the xray no problem. 134 tooth are not listed yet but email them for it.
BHenderson is offline   Reply With Quote
Old 08-11-2004, 10:12 PM   #8443
rice's Avatar
Originally posted by Neil Rabara
Are you referring to pitch, or brand of 64p spur gears?
im referring to 48 pitch spur gear.
hodapp,
i'll try those spur 134 pitch.
rice is offline   Reply With Quote
Old 08-11-2004, 10:17 PM   #8444
stumper1's Avatar
Default Re: Re: PRS - Precision Racing Products
Thanks!!
Old 08-11-2004, 10:18 PM   #8445
rice's Avatar
kennedy,
yes you can buy it separate you dont have to buy the entire oneway assembly just to use the pulley.
