Old 08-10-2004, 09:02 PM   #8416
Pyramid's Avatar
Originally posted by forty6
I'm sure Xray will come out with something of an improved version of it, like they always do.
Good thinking
Pyramid is offline   Reply With Quote
Old 08-10-2004, 09:14 PM   #8417
Default Re: Anyone had this happen? howd ya fix it?
Originally posted by BHenderson
I have the spring steel hubs in the front of my car and have a small problem.
I usually run CS premounts and I have a bunch of the old spoke style as well as some of the new bbs style wheels. I have the proper screws and the small bevel washers to fix inside the smaller opening in those wheels. That being said here's my problem, no matter how hard I turn the screw, trust me its on there when i put it on he track, sometimes either one of the front wheels will go flying off during a race. Has anyone else had this happen to them? It has happened to me 4-5 times this year that I know of in the A main and happened this past Sunday. There is nothing worse than knowing you have a decent car out there only to watch a wheel go flying off your car to end your race. Any REAL suggestions on how to fix this problem?
I had this problem before. Just go to the local hardware store and get washers that are made to add pressure to the screw. They look like flat washers that have been warped. You can get ones that are a smaller diameter then the stock cone washers. They work great. Are cheap and work like the stock ones, but fit in the recess in the wheel.
XrayEye is offline   Reply With Quote
Old 08-10-2004, 10:08 PM   #8418
ChrisP's Avatar
305215 was discontinued...that is the spring steel hub for the Pivot Ball front end...
305315 for C-hub front and Pivot/C-hub rear is still current and available according to the Teamxray site...
this makes sense as the pivot ball suspensions seems to have fallen out of favour and the new kits are all C-hub
ChrisP is offline   Reply With Quote
Old 08-11-2004, 01:06 AM   #8419
Neil Rabara's Avatar
That would make sense that some things go out of style. C-hubs seems to be the dominant choice of suspension in electric racing.
Neil Rabara is offline   Reply With Quote
Old 08-11-2004, 07:06 AM   #8420
lazyboy's Avatar
Send a message via AIM to lazyboy
How vulnerable are the rear hubs to a tweak or any of the medium thickness parts on the car. reason i ask, is because i took a couple of hard hits in the main last night, and it feels like one of the rear hubs has a crack or a slight tweak on the hub. but then again it could just be me.
lazyboy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 08-11-2004, 07:35 AM   #8421
rice's Avatar
question?
what brand of spur gear do you guys using 93 up. what brand 96,97,101 and 103.
rice is offline   Reply With Quote
Old 08-11-2004, 02:07 PM   #8422
Qwiglee's Avatar
The biggest I have is 93. I am not sure if bigger than that is possible because the motor gets too low and drops below the chassis. Right now I am running 93/25 and the motor is maybe 1.0mm or less above the chassis bottom.
All my spurs are Kimbrough.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 08-11-2004, 02:17 PM   #8423
c-lyon's Avatar
I've used a K96 with no problem.
c-lyon is offline   Reply With Quote
Old 08-11-2004, 02:18 PM   #8424
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
i must be missing something, casue I'm useing a 128, 64 pitch.
JohnMatrix is offline   Reply With Quote
Old 08-11-2004, 02:21 PM   #8425
Qwiglee's Avatar
I am talking about 48 pitch gears.
Brian Aldridge
Old 08-11-2004, 03:13 PM   #8426
JDXray's Avatar
Send a message via AIM to JDXray
anyone know where i can see Alex Lopez's car setups?
JDXray is offline   Reply With Quote
Old 08-11-2004, 04:21 PM   #8427
Qwiglee's Avatar
Try here:
http://www.mytsn.com
Brian Aldridge
Old 08-11-2004, 05:42 PM   #8428
lazyboy
All parts are vunerable to a hard hit and could possibly break if hit hard enough. Place the car on a setup station to check it out.
Old 08-11-2004, 05:44 PM   #8429
Originally posted by rice
question?
Are you referring to pitch, or brand of 64p spur gears?
Old 08-11-2004, 06:35 PM   #8430
Hodapp's Avatar
Send a message via AIM to Hodapp Send a message via Yahoo to Hodapp
Default Spur Gears!
Try using the Precision Racing Products 134 tooth spur gear. They lower the motor quite a bit which improves handling. Not to mention that they are incredibly strong and are almost impossible to strip. I have been using one for 2 months now and no problems. Sure would like to have a spare just in case.
Hodapp is offline   Reply With Quote
