Old 08-09-2004, 09:06 PM   #8401
Pyramid's Avatar
Originally posted by etzkev
Thats why you should have gotten the Spring Steel Hubs. Those dont expand, which pinches the bearings, making it nearly impossible to get them out with out damaging them.
-Kevin
If you could find one, it might be nice to have. This items already been discontinued.
Pyramid is offline   Reply With Quote
Old 08-09-2004, 10:07 PM   #8402
etzkev's Avatar
Send a message via AIM to etzkev
Thats a surprise if its true. Are you sure?
etzkev is offline   Reply With Quote
Old 08-10-2004, 12:29 AM   #8403
Pyramid's Avatar
XR-305315 WHEEL AXLE 22MM INTEGR. HEX HUB - SP. has been discontinued
For above part number, I`m sure.
Old 08-10-2004, 12:59 AM   #8404
Neil Rabara's Avatar
Really, how so?
Neil Rabara is offline   Reply With Quote
Old 08-10-2004, 01:29 AM   #8405
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
I've found a few shops that still have it.
JohnMatrix is offline   Reply With Quote
Old 08-10-2004, 02:05 AM   #8406
Pyramid's Avatar
Originally posted by Neil Rabara
Really, how so?
Just a tough.. true they are much stronger, but compare to the hardened alunimum and considering they are rotates, I think aluminum one is better as they are lighter, not to mention much cheaper as well. Their pro layshaft with one piece aluminum is truly work of arts.
Old 08-10-2004, 03:27 AM   #8407
Default Re: Anyone had this happen? howd ya fix it?
Originally posted by BHenderson
I have the spring steel hubs in the front of my car and have a small problem.
I usually run CS premounts and I have a bunch of the old spoke style as well as some of the new bbs style wheels. I have the proper screws and the small bevel washers to fix inside the smaller opening in those wheels. That being said here's my problem, no matter how hard I turn the screw, trust me its on there when i put it on he track, sometimes either one of the front wheels will go flying off during a race. Has anyone else had this happen to them? It has happened to me 4-5 times this year that I know of in the A main and happened this past Sunday. There is nothing worse than knowing you have a decent car out there only to watch a wheel go flying off your car to end your race. Any REAL suggestions on how to fix this problem?
Yea i've had this happened on my T1R , just put the washer the right way around and a small dab of thread lock on the screw threads, works a treat, but you'll have to turn harder to get the wheels off but it's fine
Chazz
Chazz is offline   Reply With Quote
Old 08-10-2004, 03:43 PM   #8408
c-lyon's Avatar
Yes, threadlock works; you could also try putting washers on the inside of the wheel as well as the outside. I've only had the problem with one make of wheel but I don't recall whose.
c-lyon is offline   Reply With Quote
Old 08-10-2004, 03:49 PM   #8409
AdrianM's Avatar
If you are running Take Off premounts or any other ABS wheel be careful. Threadlock eats ABS. If you get it on the rim it turns into something like feta chese and crumbles. I was running with Jared Scott this Sunday and he just used the washers on the outside and had no problems.
Adrian Martinez
Old 08-10-2004, 04:11 PM   #8410
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
Default Shock springs
looking into buying some springs ,can anyone recommend which springs I would need colors used most often(running foams on carpet) I see xray sells 2 spring kits close to $100 for both,kt and speedtech sell individual springs.any help would be great.I would hate to spend 100 on the kits and never use half the springs.
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 08-10-2004, 04:14 PM   #8411
forty6's Avatar
I'm sure Xray will come out with something of an improved version of it, like they always do.
forty6 is offline   Reply With Quote
Old 08-10-2004, 07:11 PM   #8412
Tom G's Avatar
Default Re: Shock springs
Violet and blue seem to be popular on set -ups.
Tom G is offline   Reply With Quote
Old 08-10-2004, 07:14 PM   #8413
Sal Amato's Avatar
Default Re: Re: Shock springs
Thanks I'll have to order a set
360 RC SPEEDWAY 2.0
Old 08-10-2004, 07:30 PM   #8414
Tom G's Avatar
Best thing to do is see what the gang at the track is running. It'll give you a good base, starting line.
Old 08-10-2004, 07:33 PM   #8415
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Default Factory Kit
Hy Guys,
I've managed to strip the one way pulley and my belt kept on flipping upside down as a result. Is this available as a spare part or do I hve to buy adn entire one way diff again? If not what is the part #?
Many thx
Kennedy is offline   Reply With Quote
