Old 07-28-2004, 09:02 PM   #8131
JDXray's Avatar
Send a message via AIM to JDXray
Default XRay?
I know Xray just came out with the Fk kit, are they going to make another kit coming out before 2005 or during 05?
JDXray is offline   Reply With Quote
Old 07-28-2004, 09:27 PM   #8132
Pyramid's Avatar
Default Re: XRay?
Why did you asked? T1FK is not capable to enhancing your satisfaction?
Pyramid is offline   Reply With Quote
Old 07-28-2004, 09:33 PM   #8133
theisgroup's Avatar
Default Re: XRay?
I think what you will see is running changes. Then if the team guys make significant mods, then maybe another evolution.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-28-2004, 11:35 PM   #8134
markp27's Avatar
Send a message via ICQ to markp27
Hi Guys,
Just received my T1FK yesterday and started puting it together - wow, it doesn't take much time It is going together really well; everything fits nicely without slop and very little binding.
I was surprised that there were no anti-roll bars in the kit - now I'm running rubber tyres on a small indoor track, do you guys find that the anti-roll bars simply aren't necessary?
Any suggestions on which is the best servo saver to use?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 07-28-2004, 11:53 PM   #8135
Qwiglee's Avatar
Originally posted by markp27
Hi Guys,
Cheers, Mark.
For $300 dollars they should at least give you a front roll bar. Also a dummy transponder would be a nice touch.
I added the front roll bar because with the front one-way installed the car turns so good that the rear end sometimes wants to come around. The front roll bar helps improve rear traction.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 07-29-2004, 12:16 AM   #8136
markp27's Avatar
This and traction rolling was my concern.
Old 07-29-2004, 12:23 AM   #8137
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Cheers, Mark.
Didn't know there was a choice???
The servo saver is inbuilt in the steering tower
Kennedy is offline   Reply With Quote
Old 07-29-2004, 12:44 AM   #8138
markp27's Avatar
I saw some pictures of Xrays with non-standard servo savers and was wondering if a third-party servo saver was the choice of most guys.
Old 07-29-2004, 12:47 AM   #8139
markp27's Avatar
Default Camber question
I run Nitro with foam tyres a lot more than electro with rubber. To set the camber on my nitro, I make sure that the front tyres wear flat and for the rears that they are slightly coned (i.e. worn more on the inside).
For rubber tyres should I take a similar approach? i.e. the wear on the fronts should be even across the width and for the rears, the insides should show a little bit more wear than the outsides?
Cheers, Mark.
Old 07-29-2004, 12:56 AM   #8140
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
mark i base my camber on tire wear. read the tires carefully to know the proper camber. for me i set it that both front and rear tires have the wear at the center.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 07-29-2004, 12:58 AM   #8141
Pyramid's Avatar
Default Re: Camber question
Cheers, Mark.
Rule of thumb is to have the wear even in the center.. that`s would largely depend on kind of inserts we are using.
Old 07-29-2004, 12:59 AM   #8142
Pyramid's Avatar
Use the one from S710 steering is good enough..
Old 07-29-2004, 01:10 AM   #8143
markp27's Avatar
Thanks for the answers, guys
Old 07-29-2004, 01:12 AM   #8144
markp27's Avatar
Hi Pyramid, you always seem to visit the same forums as me You aren't my long lost twin brother are you?
Do you mean the S710's servo save is a better choice that the Xray one?
Old 07-29-2004, 02:48 AM   #8145
Pyramid's Avatar
[email protected] trying to cut down the habbit for online too much
Anyway, as for my current use of S9550 servo, also that I mounted the servo stay (that aluminum things) not in the most forwad position (closer to center of car) due to that the suspension holder (all plastic only, step 4 front transmission) on that side need 5mm spacer in order to line up the same with the other side, I need horn that will make my servo linkage towards more to the center of the car. The original Xray will make it closer to the servo while the one from S710 will make it farther (closer to belt) and still need +0.75mm spacer to have the linkage straight.
Did you get what I mean?
