Old 07-26-2004, 09:58 AM   #8071
theisgroup's Avatar
Originally posted by JDXray
well you could try a belt tensioner, but they say thats for modified racing, but if you run 19t maybe you can use it. I think you should go upone step tighter in stock racing they say, in the rear belts i believe.
They notchs on the rear bulkheads, if the manual they say to put it at the 3rd or 4th notch i believe, but most racers say in stock racing you should go up one step tighter.
Hope its not to confusing.
Jon
actually in stock, you want it as loose as possible without skiping. so one tighter then skip. This reduces the friction in the drivetrain to a min.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-26-2004, 09:58 AM   #8072
JDXray's Avatar
Send a message via AIM to JDXray
if you run on the loosest setting, do the belts move alot??
JDXray is offline   Reply With Quote
Old 07-26-2004, 09:59 AM   #8073
stumper1's Avatar
R/C Tech Charter Subscriber
I built may car last night!
I ran into 2 problems. 1 - any tips on building the shocks? I tried over and over and never got them right. 2 - Has anyone managed to fit a Novak Xxtra and GT-7 in a T1-R? If so, do you have any pics? I have a Xxl I can use if I have to but would prefer to use the Xxtra if I can fit it in.
Thanks for the help so far!!
stumper1 is offline   Reply With Quote
Old 07-26-2004, 10:02 AM   #8074
JDXray's Avatar
1- i have the same problem with shocks.
2- you can mount your reciever on top of the servo, but i wouldnt like it there, i use the XXL. But if you prefer the XXtra, then you can mount it on the servo, but then the wires are going through the belts or over the top deck, which i dont like. I use a LRP Q2, and XXL. I might switch to GT7, but for now LRP Q2.
Old 07-26-2004, 10:03 AM   #8075
theisgroup's Avatar
they do flop up and down a little, but really nothing of concern. Some of the other seasoned drivers may be able to shed some light on this one. I have always been told as loose as posibble in stock.
yang lai
Old 07-26-2004, 10:04 AM   #8076
JDXray's Avatar
Thanks, i might have to re-think my stock set-up.
Old 07-26-2004, 10:06 AM   #8077
theisgroup's Avatar
on my setup, you know the notch on the bulkhead all by itself on the loose side, I use the next tighter one. so would not use the notch by itself.
yang lai
Old 07-26-2004, 10:08 AM   #8078
JDXray's Avatar
okay now i am confused..
Old 07-26-2004, 10:10 AM   #8079
Qwiglee's Avatar
Originally posted by stumper1
I just got a T1-R and have a couple assembly questions (for now). First, should I build the shocks with the adjustable or standard pistons? Second, the car comes with a 48 pitch spur. Is there any reason NOT to change it to 64 pitch? I have always ran 64 and have tons of them - just trying to avoid buying new ones.
Adjustable shocks are just such a cool feature. I don't know why you wouldn't want them unless you always race at the same track and your track conditions never change.
With 64 pitch you may have problems mounting them on the shaft. Depending on which brand gears you use. I had a bunch of HPI 64p gears and they wouldn't fit on the shaft because the screw holes wouldnt line up properly. Anyway I like 48p now because they dont strip as easily. I have never stripped a 48p gear but I stripped lots of 64p gears.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 07-26-2004, 10:12 AM   #8080
JDXray's Avatar
I have a couple Trinity 64 pitch spur gears, and they just fit. I kinda have to force it on it, but if you use a dremel or x-acto knife than you can cut inside to make it bigger hole. But the mounting holes fit perfect.
Old 07-26-2004, 10:17 AM   #8081
theisgroup's Avatar
the arrow shows the setting I am using
yang lai
Old 07-26-2004, 10:24 AM   #8082
JDXray's Avatar
Oh okay, so you use that setting all around? Front and back.
Old 07-26-2004, 10:27 AM   #8083
theisgroup's Avatar
yes on new belts.
yang lai
Old 07-26-2004, 10:38 AM   #8084
JDXray's Avatar
oh okay. Thanks, i am going to maybe switch up those notchs and belts. Gotta get ready for indoor season racing.
Old 07-26-2004, 10:51 AM   #8085
Qwiglee's Avatar
Sunday was my first club race with my new T1FK. It was awesome. I have been running the T1 Evo2 for over a year and that was good but now that I have the FK I can see that the FK is a superior design. The most important design change I think is the shorter suspension arms all around. I always use a front one-way and with my Evo2 I was always struggling to keep the rear end from getting loose mid-corner. Every adjustment I could do was never quite enough. When I built the T1FK I set it up with exactly the same suspension settings as my Evo2 so I could compare the performance. I never had any handling problems all day Sunday and I never had to make one single chassis adjustment to the car.
As a result I qualified 2nd and I finally took my first A-main win at my local club race.
I highly recommend the T1 Factory Kit.
Brian Aldridge
