Old 07-20-2004, 09:24 AM   #7996
Neil Rabara's Avatar
Originally posted by momotalo
hi
i want to ask about the front arm
is that right that left n right was not same?
not the long , but the position
the left one was more wider than the other
is that right?
The right and left front arms are identical, so are the rear arms. Be careful not to mix up the long and short version arms.
Neil Rabara is offline   Reply With Quote
Old 07-20-2004, 09:28 AM   #7997
Originally posted by Pyramid
Hi, can some one pin point me the discussion, if any, of different battery positions on T1FK? benefits and disadvantages compared to others?
I've tried almost all possible mounting positions on the stock Xray chassis. The best position, in my opinion, is saddleback side by side. Best balance forward to aft, and left to right. If you move the batts all the way to the left or right, the car will turn better in one direction than the other. If the batts are in a saddle, but are on opposing positions, one forward and one aft, you have balance left to right, and forward to aft, but torsionally the car would have more weight on one corner than the other.
Old 07-20-2004, 09:33 AM   #7998
Send a message via ICQ to momotalo
opsss, sorry , that not what i ask about
front susp holder , the left one has a cavity for alu nut
but the right there was no cavity for alu nut
only the plastic. right
that the problem make the wider of the front arm not the same.
are every one has the same like that?
sorry if my question make you confuse......
my english not good enough
momotalo is offline   Reply With Quote
Old 07-20-2004, 09:47 AM   #7999
The plastic holder is for the right side front arm, rear position. When everything is put together, both sides should be the same length. If not, check assembly of parts again.
Old 07-20-2004, 09:48 AM   #8000
theisgroup's Avatar
i think i understand. Yes the hinge pin holder on the side with the server has no aluminum insert. the one on the other side does. This is for the factory kit. This is true for only the rear hinge pin holder on the front bulkheads
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-20-2004, 09:56 AM   #8001
Yea you're right. But they should be the same length when assembled. I wonder where momotalo is measuring?
Old 07-20-2004, 09:58 AM   #8002
theisgroup's Avatar
not sure. they should be the same length. Or maybe he is saying that the length from the bulkhead to the tip of the mount would be different. Then in fact they are different. So you can screw your servo in
yang lai
Old 07-20-2004, 03:23 PM   #8003
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
I know what momotalo means
I have been told by a experience x-ray man ,there is 1mm difference concerning the hinge pin holder, the servo side is a std raycer item, the others with ali inserts are fk, If you put a raycer one on the oppisit side to the servo one then they will be the same left & right
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 07-20-2004, 03:37 PM   #8004
theisgroup's Avatar
but that does not matter. if you get the right one out of the racer kit. the distance from teh bulkhead to the hinge pin is the same. remember the racer has several different sizes of hinge pin mounts. If you have a factory kit. the distance between the outside of the bulkhead and the center of the hindge pin is the same
yang lai
Old 07-20-2004, 05:17 PM   #8005
It's unlikely the wrong part would be put into a particular kit. However, unless machines are packing the boxes, anything could happen.
Old 07-21-2004, 12:54 AM   #8006
Pyramid's Avatar
Yes, you are correct. All T1FK until the last batch (new blue box) has this matter. The one without the aluminum is 0.3mm shorter/flatter for hinge pin hole height when you put them with the alum insert one side by side on the glass table. But when you screw down (depending on how tight you ussually conviniece with), you may need 0.4 to 0.5mm spacer in between the bulkhead and that all plastic suspension holder.
Neil, thanks for bats position advice.
Pyramid is offline   Reply With Quote
Old 07-21-2004, 05:01 AM   #8007
Matt04's Avatar
i was woundering that it would matter if you had a front right Medium 3 degree c-hub and you had a front right SOFT 3 degree c-hub on the car.
cause my dad got the wrong part and i was woundering if this would cause the car to go wierd.
do i have to have medium at the front or can i have soft and medium c-hubs.
Matt04 is offline   Reply With Quote
Old 07-21-2004, 05:33 AM   #8008
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Can someone post pictures from the BMI chassis? I have visited BMI site but there is n't any!
Also what is it's price, and if there are any other parts!
Thank you
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 07-21-2004, 06:43 AM   #8009
Trader Rating: 14 (100%+)
Nick:
Hi,
There is a pic posted in the B.M.I. of the XRay chassis.(2 or 3 pages back) I think the price is $79.00 for the chasssis plate and top deck. there different colors too. satin black,Ti, Gold, Red, Blue and Aqua to name a few. the chassis/top plate are 3mm thick graphite. as for options I know there is a adjustable top plate being tested now. the chassis can be ordered with the battery slots in the stock, .062 ahead and moved in or .350 ahead and moved in.
any other questions call Jason at the phone number on the B.M.I.. web site.
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 07-21-2004, 07:41 AM   #8010
MR JOLLY's Avatar
Here is a nice pic
I /we are going to get one
