Old 07-08-2004, 09:05 PM   #7846
etzkev's Avatar
Send a message via AIM to etzkev
Originally posted by P2
What does adding spacers underneath the camber links on the hub carriers do? I think it will reduce traction, can anyone confirm this.
How about putting the front camberlink on the bulkhead. How does this affect steering/front grip and how many spacers is the norm
Thanks,
P2
Well, I'm not quite sure about doing them under the camber links, but I think it has something to do with roll centers...but once again, I'm not quite sure.
Putting spacers under the steering links on the front Hub Carriers is called "Bump Steer". You probably already know this though. It creates more bite up front (correct me if I'm wrong about the bite though).
-Kevin
P.S. Thanks Brian!
etzkev is offline   Reply With Quote
Old 07-08-2004, 09:23 PM   #7847
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Putting spacers under the front or rear hub carrier ball ends will raise the roll center. This will make the roll of the car quicker in the corner.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 07-08-2004, 10:34 PM   #7848
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
would that affect camber?
Kennedy is offline   Reply With Quote
Old 07-08-2004, 10:36 PM   #7849
Yes, slightly. It effects the amount of camber gain in the corner. But static camber will also be changed depending on the # of washers added, so check it.
USVTA Member #211
Old 07-08-2004, 10:38 PM   #7850
etzkev's Avatar
So after adding spacers, affecting camber, you would have to re-set your camber...right?
-Kevin
Old 07-08-2004, 10:38 PM   #7851
Yes, but it shouldn't take more than a slight twist to reset.
USVTA Member #211
Old 07-08-2004, 10:44 PM   #7852
Kennedy's Avatar
Default O deg Alu. Castor Blocks
Are these a worthwhile investment? Anyone using them?
Old 07-08-2004, 10:44 PM   #7853
etzkev's Avatar
Yeah, I know that, it wouldn't throw it off that much.
I have thought about it, and learned about roll centers more myself! If you just visualize some of this stuff, you can figure out what it changes, affects, and does!
If anyone needs, I think I can explain roll centers a little.
-Kevin
Old 07-08-2004, 10:57 PM   #7854
KMW
KMW's Avatar
Default Re: O deg Alu. Castor Blocks
I use them when I run a spool. If you run a one-way then you shouldn't need them.
KMW is offline   Reply With Quote
Old 07-09-2004, 12:10 AM   #7855
Neil Rabara's Avatar
Putting spacers under the ball raises the ball and alters its curve in the arc of motion. There will be less camber movement in that curve.
Neil Rabara is offline   Reply With Quote
Old 07-09-2004, 12:11 AM   #7856
Some people have them if you like a very direct feel of the car. The slightest inputs to the steering wheel and your car will respond.
Old 07-09-2004, 01:54 AM   #7857
-Kevin
Hello,
Can you explain all that you know about roll centers?
Comments from anyone is welcomed...I remembered reading an article on it but I confused myself and did not really get it.
Any help would be greatly appreciated!
lrcdjcb112 is offline   Reply With Quote
Old 07-09-2004, 04:13 AM   #7858
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
i use them with a oneway and it seems quite nice more onpower steering at the exit. one thing i noticed is that i didnt loose any initial turn-in with the car yet it gave me great exit steering.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 07-09-2004, 07:38 AM   #7859
Send a message via ICQ to momotalo
hi guys. i've got a problem with my xray t1fk,
i've seen in the manual book , that the diameter of the middle shaft bearing was 6*10, but my bearing only 5.5*10
is that wrong from the factory or just my kit?
i use the caliper to count my middle shaft diameter was 6 mm
can anyone give me some advice?
or i must looking for a new bearing?
thank
momotalo is offline   Reply With Quote
Old 07-09-2004, 08:32 AM   #7860
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
The bearing that fits on the end is smaller than the one that fits near the spur gear. You probably just have them mixed up.
The bearing on the Spur side is 6 x 10.
The bearing opposite the spur is 5 x 9.
Check both bearings.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
