Old 07-05-2004, 03:48 PM   #7756
Rob Mincey's Avatar
(edit)
Rob Mincey is offline   Reply With Quote
Old 07-05-2004, 06:33 PM   #7757
Registered User
[QUOTE]
Can I get some help from some xray experts. Will the low ratio pulleys make a big difference when i'm racing in stock class? Is the solid center layshaft better than the one-way? The reason I'm asking is because I recently bought an xray with both setups but I only have the spur and pinion combination for the oneway. And if I change to the low ratio pulleys, that means I'll have to buy new pinions and new spurs since the ratios will be way off. If the difference isnt too big...I would rather save some money. Any help would be appreciated. Thanks
The low ratio pulleys were designed to "free up" the car. In theory the more free a car is the faster it will go. So yes there should be a difference in top speed. If it was me I would run the car with low ratio pulleys. BTW You would only need to buy new pinions if you have the 128 64 pitch gear or 93 48 pitch gear. Hope this helps.
Zach
Zach P is offline   Reply With Quote
Old 07-05-2004, 07:45 PM   #7758
Originally posted by MR JOLLY
HEEEEEEEEEELP
I just built a FT the front ride height is good for me
But the rear ride height is at 7mm kit settings on the hole position front,droop is 2fr,5rr,shock length on all shocks is 72mm,
Also can`t use 26mm rims on back if i use the outside holes on wishbones, well i can but the edge of the rim rubs against the ballend of the shock
Any ideas
I just built my FT and had the same problem. It turns out I did not push the cups that hold the springs down onto the shock ball ends. I had to press very hard, but once they were down all of the ride height problems went away.
Losi Lunatic is offline   Reply With Quote
Old 07-05-2004, 07:58 PM   #7759
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
I'm gonna be getting a Evo2 w/ all the hop-ups. Anything I should know about Xray's? I'm switching over from the TC3 because I wanna win!
Nrctc3 is offline   Reply With Quote
Old 07-05-2004, 08:13 PM   #7760
JDXray's Avatar
Send a message via AIM to JDXray
well all i can say is XRay evo 2 FOC is a BEAST! and you should have a blast. TC3 is still a very good tc.
JDXray is offline   Reply With Quote
Old 07-05-2004, 10:29 PM   #7761
evaa's Avatar
Originally posted by Neil Rabara
I wasn't patient enough to file down the hubs. I hammered it out. Ruined the bearing though. Since then, I switched to the spring steel and have had no problems.
so this happens even if you dont hit barriers? wear and tear?
evaa is offline   Reply With Quote
Old 07-05-2004, 10:37 PM   #7762
etzkev's Avatar
Send a message via AIM to etzkev
Just get it, experiment with it, and you will have some questions along the way!
etzkev is offline   Reply With Quote
Old 07-05-2004, 10:48 PM   #7763
evaa's Avatar
Old 07-05-2004, 10:53 PM   #7764
etzkev's Avatar
Oh, by the way, how do all you guys like my new avatar? Haha
-Kevin
Old 07-05-2004, 11:00 PM   #7765
Neil Rabara's Avatar
I even turn down the dual rate, but the alum hubs kept spreading. You have to consider that the alum hubs are the softest metal in the universal.
Neil Rabara is offline   Reply With Quote
Old 07-05-2004, 11:01 PM   #7766
If you think the Evo2 FOC is a beast, you should run the FT.
Old 07-05-2004, 11:21 PM   #7767
evaa's Avatar
yep, thats what i heard too.
Old 07-06-2004, 12:07 AM   #7768
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Ok Question : On Road Nat's in portland and I want to know do we need he front spool and front diff for back up?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 07-06-2004, 12:35 AM   #7769
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
No it not the shock spring retainers,i done that
Camber links are fit ,which is inside hole,
It feels like the springs are to long,the whole back end is very springy as you push down & let go(very tense)
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 07-06-2004, 05:47 AM   #7770
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
the rear usually feels a touch springy all the time just the suspension geomtry
but if its TOO springy then theres a problem
what roll center/spring/shock mounting holes are you using?
Andrew Swanson is offline   Reply With Quote
