Old 06-30-2004, 01:05 PM   #7681
theisgroup's Avatar
no, no card stock. it will work without it. The spool is duraluminum and the outdrive will wear divits where the cvd's contact. After a few runs, you will have play between the outdrive and cvd
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-30-2004, 01:13 PM   #7682
howard hudson's Avatar
R/C Tech Charter Subscriber
Default SPOOL
SPEED TECH SELLS THE SPOOL < click....... but he is out of stock as of now he should be getting more
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 06-30-2004, 01:35 PM   #7683
Suspended
Trader Rating: 28 (100%+)
Thats weird,That how i run mine in my schumacher.Its duraluminum.It works fine if you run the blades with little wear or play.The Xray stuff must be softer material.I say just buy a spool.
racenut123 is offline   Reply With Quote
Old 06-30-2004, 01:44 PM   #7684
I just got an evo2 and if I run on asphalt with rubber tires on a medium sized track thats semi-technical. Should I be using the solid center or the center oneway? The front diff is solid. Currently, the center one-way is installed but I haven't really driven it so im not sure how it feels. I also have the low ratio pulley set but I believe that one can only be run with the solid center shaft. Is there a big difference with the low ratio pulleys if I'm running stock beginner class? THANKS!
xraydriver is offline   Reply With Quote
Old 06-30-2004, 03:21 PM   #7685
scmicromike's Avatar
Send a message via AIM to scmicromike
The outdrives on the spool suck. they always spread and give to much play and you end up going through blades like crazy. so to stop that I was using the dif because the out drive is stronger. it worked for a while before I was hearing this noise. I will probably shim the dif. that or wait for TQ hobbies to get in there batches of locked on-ways.
scmicromike is offline   Reply With Quote
Old 06-30-2004, 06:35 PM   #7686
theisgroup's Avatar
you may try the spring steel outdrive for the diff. this is heavier, but has not given me a problem. Been running one for about 2 years without any slop
yang lai
Old 06-30-2004, 06:37 PM   #7687
theisgroup's Avatar
spool is also the duraluminum as well. so not any better. I have 2 spools with problem. And 2 new one, that I would get rid, but no-one here even uses the factory spool.
yang lai
Old 07-01-2004, 09:19 AM   #7688
glide 1's Avatar
Default Spur Gears..
Hi, could someone post a list of the companies that make 48pitch spur gears to fit the xray fk. My lhs only has the stock 93t, i'm looking for bigger spurs, 96t up.
glide 1 is offline   Reply With Quote
Old 07-01-2004, 09:22 AM   #7689
The Evicerator
Default The Ompinator is Omping!
Ompinating the people!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-01-2004, 09:27 AM   #7690
glide 1's Avatar
Default another q
I have the option of using the 34t 1way/diff gear to get an idr of 2.125. This will solve my problem gearing low turn modifieds (motor not touching rear belt). will i gain or loose anything changing from 1.77 idr to 2.125? My car is super quick off the mark right now and i was told that it is due to the 1.77idr gears of the fk.
Old 07-01-2004, 10:43 AM   #7691
Neil Rabara's Avatar
The drive train will not be as free using the 2.125 pulleys.
Neil Rabara is offline   Reply With Quote
Old 07-01-2004, 01:32 PM   #7692
Default Re: Spur Gears..
kimbrogh is the only one i found so far ( the black gears)
Old 07-01-2004, 04:12 PM   #7693
Tom
Tom's Avatar
I got an xray 96t spur. Its a kimbrogh though, just in an xray bag.
Tom is offline   Reply With Quote
Old 07-01-2004, 07:25 PM   #7694
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
which essentially means more top speed but it's shit all difference anyway
Kennedy is offline   Reply With Quote
Old 07-01-2004, 07:31 PM   #7695
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Actually the main benefits are that it'll accelerate faster and will give longer runtime.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
