Old 06-29-2004, 01:25 PM   #7651
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
1st file
Andrew Swanson is offline   Reply With Quote
Old 06-29-2004, 01:26 PM   #7652
2nd file
Old 06-29-2004, 01:54 PM   #7653
The Evicerator
You're gonna be ssssSuper DialeDddd now anderew!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-29-2004, 02:13 PM   #7654
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Dear lord! That chassis is a brute. You could seriously beat someone silly with that club
Looks good. What's the geometry like? Batteries still in the same place or moved forward?
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 06-29-2004, 05:33 PM   #7655
RCchica's Avatar
Send a message via AIM to RCchica
OH MY
That is NICE!!
RCchica is offline   Reply With Quote
Old 06-29-2004, 05:35 PM   #7656
Neil Rabara's Avatar
Originally posted by Andrew Swanson
2nd file
Show off!
Neil Rabara is offline   Reply With Quote
Old 06-29-2004, 06:25 PM   #7657
forty6's Avatar
2nd file
Sweeeet!! Is it gonna be available soon?
forty6 is offline   Reply With Quote
Old 06-29-2004, 06:53 PM   #7658
JDXray's Avatar
Send a message via AIM to JDXray
sweetness!!! looks good, keep up the work.
JDXray is offline   Reply With Quote
Old 06-29-2004, 10:31 PM   #7659
scmicromike's Avatar
Send a message via AIM to scmicromike
Default prob with T1R
Well it finally happened. I have a problem with a RC car that I just cant figure out. I have been running my racyer for a while now with no problems other than maintnence.
The problem is a grinding or rubbing sound of some sort when I turn the wheel under power. it sounds a lot like a blown bearing. So naturally I replaced the car with a set of new bearings. But there is still a problem! so here are some other tings I have done to try and fix the problem.
1) replace CVDs
2) replaced hubs
3) tightened the servo saver
4) put a different dif up front.
5) of course checked for binding or rubbage
6) checked all parts
So I have checked and replaced all that I can think of and I still have the problem
Is there anything that you guys can suggest that might be wrong? thanks guys.
scmicromike is offline   Reply With Quote
Old 06-29-2004, 10:37 PM   #7660
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Check your EPA on your radio to make sure the rim isn't hitting the shock end when full locked.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-29-2004, 10:41 PM   #7661
Is the wheel hitting any part of the car while in a turn?
Old 06-29-2004, 10:47 PM   #7662
new92's Avatar
I have a question about my raycer. I am wanting to loosen the belts up to see the difference for stock racing. I have the "holders" of the breaings on the bulkheads set in the stock or middle position. Do I want to loosen the center and front ones? Just one? What about the rear? Do I turn the pieces to the loosest setting or just one notch?
I know I could do this on my own and experiment but I really dont want to take apart the car that many times if someone already knows .
new92 is offline   Reply With Quote
Old 06-29-2004, 11:29 PM   #7663
micro mike-
the grinding sound is probably the cvd binding at full lock it happens on almost all cars. try applying power like 1/4 throttle and then slowly go through the steering throw and i bet the sound starts toward reaching full lock.
new92-
its really hard to give a definite answer on that question with out personally feeling the belts. i would suggest moving the eccentrics 2 position in the front and 1 position in the rear.
try that first then just (unfortunately) experiment
Old 06-29-2004, 11:51 PM   #7664
new92's Avatar
I really dont mind experimenting on the car, was just looking for an easy way out lol.
Thanks again will try it first thing in the morning
Old 06-30-2004, 06:59 AM   #7665
Andrew thanks that sounds like the problem but I have rebuilt the cvds and replaced the parts.
and I have inspected the car about a hundred times for wheel rubbage. and I dont see any at all. but I have noticed that the sound is rougher when the wheel is bolted on.
