Old 06-28-2004, 05:46 PM   #7636
Registered User
3 degree stock caster blocks
Zach P is offline   Reply With Quote
Old 06-28-2004, 06:24 PM   #7637
Neil Rabara's Avatar
Originally posted by Andrew Swanson
got some thick chassis today will let you guys know how they work on asphalt
(sorry no pics)
and ont he arm pics i almost have a full set done soon so ill put pics up as soon as they are done
I see you got something new! Hmmmm.
Neil Rabara is offline   Reply With Quote
Old 06-28-2004, 08:01 PM   #7638
give six degrees a try. i like them, maybe it'll make you quicker.
trigger is offline   Reply With Quote
Old 06-28-2004, 08:34 PM   #7639
rough512's Avatar
Default Ray,
How does the 350 chassis battery position compare with that of the 1st Gen T1? More forward? a little backward? about the same?
I can still get the same effect (moving weight forward) by locating my lead weights at the servo area right? I'm trying to make the 1530g limit my local track has just started to impose
rough512 is offline   Reply With Quote
Old 06-28-2004, 09:08 PM   #7640
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
yes neil new toys!
yea yea
Andrew Swanson is offline   Reply With Quote
Old 06-28-2004, 09:10 PM   #7641
rayhuang's Avatar
Default Re: Ray,
I believe the original T1 had the batteries in the same place as the Evo2-only it had a lot less cutouts so it was the stiffest chassis produced by Xray (for the consumer-not team drivers).
So the 350 BMI chassis is definately more weight bias forward. I dont think placing the lead weight forward will be the same. This is because you still have the heaviest weight over the stock saddle position. I do knw some of the Team drivers at the Bird were running the batteries forward and the needed ballast in the front of the car too.
Trust me-the cars got mad steering when you first try it. Then you tune it out a bit with the diffs and other things like rear toe in and rear spring untill its comfortable for you. For me-I actually want even more steering now so last two runs I sauced the front tires out to the orange, put a little toe out in the car, took off the sway bar..... And still its So easy to drive and carries corner speed. Next time car hits track I will have raised the frnt roll center. This will definately add steering. I'll then probably be faced with putting the sway bar back on and make some other changes to compensate.
I am the quintessential sedan whore-I'll buy and drive almost anything, but ths car is awesome!! I am going to run this for a long time I think.
Old 06-28-2004, 10:45 PM   #7642
yes neil new toys!
yea yea
Please PM me your goodies!
Old 06-28-2004, 10:51 PM   #7643
rough512's Avatar
Thumbs up
Ray
Thanks for the reply.
So what is the F/R weight distribution of the 350 BMI like? 50/50?
Old 06-29-2004, 08:52 AM   #7644
Yo,
Check this out:
http://www.rcworld.ch/neueprojekte.asp?id=1236
New X-ray tuningsparts!
They all like nice
840918001 is offline   Reply With Quote
Old 06-29-2004, 09:13 AM   #7645
etzkev's Avatar
Send a message via AIM to etzkev
That stuff looks sweet! But will it be sold in the US?
etzkev is offline   Reply With Quote
Old 06-29-2004, 09:19 AM   #7646
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Those little ball thingies were on XRay's site last week. I'm assuming the rest will be coming?
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 06-29-2004, 09:28 AM   #7647
etzkev's Avatar
Oh wait, those are made by Xray? I was under the impression that is was an aftermarket company producing them.
-Kevin
Old 06-29-2004, 09:30 AM   #7648
Coney's Avatar
Send a message via ICQ to Coney
Any ideas of when these new parts will be available?
Also, just wondering what the use is for this part? Whats it do?
308090 Shock Foam Inserts (4)
Coney
Coney is offline   Reply With Quote
Old 06-29-2004, 11:55 AM   #7649
So many new goodies.
Old 06-29-2004, 01:12 PM   #7650
close ups of new chassis
