Old 06-28-2004, 07:06 AM   #7621
I run my FK with a Ko Propo receiver.
To prevent glitching I putted a small peice of shrink tube over the recieverwire, so that there isn't any contact with the chassis.
840918001 is offline   Reply With Quote
Old 06-28-2004, 08:46 AM   #7622
Default ball diff for fk
I have a fk and i was wondering if the rear diff fits the front? I also was wondering if the evo2 rear diff works?
tqboy is offline   Reply With Quote
Old 06-28-2004, 08:50 AM   #7623
rayhuang's Avatar
Default Re: ball diff for fk
Yes on both.
Old 06-28-2004, 09:02 AM   #7624
Default bmi chassis
rayhuang: i was wondering how you like the bmi chassis? would it be better for carpet. do you have a pic of the chassis? Is there a big difference in the kit chassis and the bmi? with one felts easier and smooth to drive? thanks
Old 06-28-2004, 09:27 AM   #7625
rayhuang's Avatar
tqboy,
Understand that I am a paying BMI customer-I am not sponsored by them so I hope my comments are fair.
I went with the BMI 350 chassis because a buddy and I had tried 1/8" in batteries forward on a Warpspeed chassis and it felt better than stock (Much stiffer too), but still too easy to drive. So he had Jason at BMI make him a 350 forward chassis. At the same time, the XRay guys at the Snowbirds were running a chassis like this, and then JOsh Cyrul started running his chassis with batteries split Corally style. So all fingers were pointing towards batteries further forward for much higher corner speed. Also to a much stiffer chassis. To accomodate the stiffness, but not lose the roll centers, 3d cutouts were used by JAson. Now the car-on carpet and with JOsh's Nats set-up o it is very fast and also quite easy to drive (this owing a lot to the third position on the steering knuckles).
I have let all the fast guys at track drive it and everyone of them was impressed with the car. MOst said fast and easy to drive-the combination you want.
HOpe this helps,
Ray "windbag" Huang
Old 06-28-2004, 09:36 AM   #7626
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Hi Ray
I hearing that BMI product works great for indoor but what about outdoor?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-28-2004, 10:34 AM   #7627
Rob Mincey's Avatar
Ray - can you snap a closeup pic of your steering knuckles with the third holes? I'd really appreciate it.
Rob
Rob Mincey is offline   Reply With Quote
Old 06-28-2004, 10:37 AM   #7628
scmicromike's Avatar
Send a message via AIM to scmicromike
Default new akerman setings
this third hole on the blocks is it molded into the blocks or is it screwed in like they where at the snowbirds. also can these be purchased seperatly?
scmicromike is offline   Reply With Quote
Old 06-28-2004, 10:50 AM   #7629
theisgroup's Avatar
no, the extension is not molded into the steering hub. They are actually scrap pieces of graphite. I believe that there is a pic in the "ask josh thread", like on friday of last week that ray posted. I am using the 3 holes off of the carpet shock towers. just take 2 hole that line up with the sterring hubs and the third is where you screw the ball stud into. you will have to modify a button head screw to make then work
sorry guys,
it was the bmi thread on 6/25 - rays post of pics
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-28-2004, 11:16 AM   #7630
rayhuang's Avatar
Originally posted by OVA
Hi Ray
I cannot really comment because I dont race outdoors.
Old 06-28-2004, 12:59 PM   #7631
Neil Rabara's Avatar
Hi Ray
I used it at the Reedy Race. Works fine on asphalt. You just have to setup your car.
Neil Rabara is offline   Reply With Quote
Old 06-28-2004, 04:44 PM   #7632
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
got some thick chassis today will let you guys know how they work on asphalt
(sorry no pics)
and ont he arm pics i almost have a full set done soon so ill put pics up as soon as they are done
Andrew Swanson is offline   Reply With Quote
Old 06-28-2004, 05:07 PM   #7633
Rob Mincey's Avatar
Thanks, Andrew.
Rob
Old 06-28-2004, 05:34 PM   #7634
Registered User
My car was money on asphalt with the bmi 350 chassis. I left my setup the same as it was without the bmi chassis. Here it is. Also this is recommened for stock and 19.
Front
Camber:-1.5
toe in:0
anti dive:0
droop:3
springs: light blue
oil:30 wt xray oil
ride height:5.5
shock tower F:#2 hole
Rear
Camber:2
toe in:2
anti squat:0
droop:1
springs:white
oil:30 wt xray oil
ride height:5.5
shock tower:#2 hole
wheel base is stock.
Zach P is offline   Reply With Quote
Old 06-28-2004, 05:42 PM   #7635
how much caster?
trigger is offline   Reply With Quote
