Old 06-24-2004, 08:01 PM   #7561
Neil Rabara's Avatar
Originally posted by etzkev
I just have a few questions. How often do the belts wear out (stretch out too much) and require replacing if running stock and 19T? Also, what are the most commonly broken parts (I'm guessing front arms and carriers, but let me know)?
Thanks,
etzkev
I haven't had a belt wear out, or even break. Just stretch. With the new factory kit, nothing so far has broken. On the Evo2, the rear shock tower is pretty weak with all the holes in it.
Neil Rabara is offline   Reply With Quote
Old 06-24-2004, 08:02 PM   #7562
Originally posted by OVA
How much does the X-Ray T1Team Factory Kit weight from Box stock?
It's pretty far under weight. I had to add the amount of weight equal to a motor to bring it up to 53oz.
Old 06-24-2004, 08:06 PM   #7563
rayhuang's Avatar
MY FK kit but with a BMI 3mm chassis and top deck, PT and foam tires is 49.5 oz. Thats includes the Parma Alfa body too.
Ray
Old 06-24-2004, 08:17 PM   #7564
JDXray's Avatar
Send a message via AIM to JDXray
what is the advantage to a belt tensioner? Is it worth it?
JDXray is offline   Reply With Quote
Old 06-24-2004, 08:45 PM   #7565
Pyramid's Avatar
Haven`t tried one but I`m thinking instead of adjusting the eccentric to make belt very loose for stock racing, why not adjusting it from the tensioner? How`s that sound?
Pyramid is offline   Reply With Quote
Old 06-24-2004, 09:55 PM   #7566
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
just use the eccentric man. Belt tensioner adds more friction to the overall drive train
Kennedy is offline   Reply With Quote
Old 06-24-2004, 09:57 PM   #7567
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
I have the tensioner installed but I don't use it. I set my eccentric hubs to loose to reduce drag a bit. it rolls very free like this.
g_bruin is offline   Reply With Quote
Old 06-24-2004, 10:12 PM   #7568
etzkev's Avatar
Send a message via AIM to etzkev
Thanks for the help to everyone that replied.
About the belt tensioner - I asked the same question to Josh, and he said it really wasn't necessary. Just use the eccentrics like you all have said.
-etzkev
etzkev is offline   Reply With Quote
Old 06-24-2004, 11:41 PM   #7569
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Ray
Thanks Dude
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-24-2004, 11:42 PM   #7570
OVA
OVA's Avatar
Thanks Neil
Old 06-25-2004, 12:48 AM   #7571
No problem. Just make sure you add the weight (if you intend to) down the center of the chassis, not the edges or corners. Centralized mass is better for transitioning.
Old 06-25-2004, 02:40 AM   #7572
Arthur's Avatar
Default Belt tensioner/eccentric bearings
I use the eccentric bearings to try and adjust the diffs into a position so that they are as in line with the hubs as possible so that the drive shafts don't sweep back as much. I think this reduces the maximum angles that the front drive joints have to cope with. I think this is important if you are on a very tight high grip track and especially if you use a spool.
I guess it also reduces wear on the joints and plastic blade and maybe even makes the car run more freely.
But adjusting the eccentrics this way means that the belt is slack so you may have to use the tensioner.
Am I the only one that does this, what have I misunderstood?!
I do realise that because of the Ackerman steering the outer wheel doesn't turn in as much as the inner wheel, so the fact that the drive shafts sweep backwards isn't as bad as if the shafts swept forwards...
Arthur is offline   Reply With Quote
Old 06-25-2004, 02:51 AM   #7573
Johnny J's Avatar
Default Screw Kit question
Hi all.
I wanna get some spare screws for my FK, and was wondering which to get. I want to get 2 sets from www.rcscrewz.com, but don't know which set to get?
There is the T1R, T1, and Evo 2 kits. I am guessing the Evo 2 kit will be pretty much the same as the FK.
Thanks guys
John
Johnny J is offline   Reply With Quote
Old 06-25-2004, 04:51 AM   #7574
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
I got the T1 Evo2 kit and they work great. You should have some spares also.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 06-25-2004, 11:26 AM   #7575
Hey, I've had my FK for 2 weeks now and i already have rust on my hinge pins. Does anyone else have this problem.
magerz24 is offline   Reply With Quote
