Old 06-21-2004, 08:31 AM   #7486
RCchica's Avatar
Send a message via AIM to RCchica
I have never seen an RC track that big...would be awesome to run on.
RCchica is offline   Reply With Quote
Old 06-21-2004, 11:34 AM   #7487
Neil Rabara's Avatar
Originally posted by Airwide
My rear belt is really loose with the recommended belt tension setting, but the front one seems rather tight. What settings do you guys use?
It depends on the class you are racing. When I run stock and 19T and so I have my belts at it's loosest settings. When I run mod, I tighten them up considerably.
What 's your experience with battery positions? I used the rear position on both sides, but I have noticed that many people have the batterys all the way up front at the left side.
I haven't seen anyone here in the states run the batts all the way up on one side. The car is unbalanced and would require alot of weight to counter balance the batts. Most everyone here runs the split saddle packs in the rear. Josh Cyrul uses split saddle with the left side in the forward position.
That's a huge track by the way. It looks more along the lines of nitro rather than electric.
Neil Rabara is offline   Reply With Quote
Old 06-21-2004, 05:49 PM   #7488
sands's Avatar
Originally posted by sands
What does front a-arm sweep do for handling? Can't remember.
Thanks!
anybody?
sands is offline   Reply With Quote
Old 06-21-2004, 07:20 PM   #7489
Wap
hey guys got a Problem w/ the x-ray. Maybe a dumb question but here goes.
I do not have any brakes. I bought a used cyclone on e-bay and i thought that it was the problem. I then bought a brand new GT-7, still no brakes. I have a M8 and it is at the default settings. Did i install something wrong in the diff? I just not sure never had this problem b/f. Thanks for the help
Wap is offline   Reply With Quote
Old 06-21-2004, 07:20 PM   #7490
sweeping the front A arm will just keep it clean
DOTMAN is offline   Reply With Quote
Old 06-21-2004, 07:26 PM   #7491
Wap
Hey guys besides the braking problem this is a great!!!! car. i practice w/ the car on asphalt with a experience driver running a x-ray and tc3 he would switch back and forth. I have not race for a long time. I am very pleased how the car handles, i just bought the box of springs so i can't wait to try some setups.
X-ray great car
Old 06-21-2004, 07:32 PM   #7492
Registered User
wap ygpm
Zach P is offline   Reply With Quote
Old 06-21-2004, 07:41 PM   #7493
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Sands, I am pretty sure front arm sweep will make the car less aggressive. That's what I've heard from others who've tried different arm sweeps on their losi's and HPI cars.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-21-2004, 07:44 PM   #7494
RBLove's Avatar
Trader Rating: 72 (100%+)
I believe arm sweep will give you slightly more turn in. Keep in mind that it also shortens the wheel base. Not by much, but it does.... A lot of the X-Ray guys are running 1mm to 2mm of arm sweep.......
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 06-21-2004, 07:46 PM   #7495
guys....I have some more factory team pieces that I am willing to part out.
I have 2 pairs of the aluminum axles (integrated hex). These are much lighter than the evo2 axles. should only run on the rear...use spring steel on front. 12.00 per pair shipped in usa.
I have the hollow light weight layshaft from the factory team 11.00 shipped in usa
I have 3 complete sets of the stock wheels. 12.00 shipped for all 12 wheels. ****SOLD****
I still have the bulkheads as well.
This stuff will be over on the buy sell forum tomorrow...giving the xray guys the first opportunity.
Joneser is offline   Reply With Quote
Old 06-21-2004, 08:09 PM   #7496
Trader Rating: 16 (94%+)
Joneser, pm sent.
domo is offline   Reply With Quote
Old 06-21-2004, 08:31 PM   #7497
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Originally posted by S-T-R-l-K-E-R
at speedzone my car's weight was 1508g. at mang's it didnt even reach 1500g.
i asked the cyrul the same question i will tell you as soon as he answers me!
I use the weights that real car uses for wheel balances. Only costs a couple of bucks if anything adn they segment it into 10/15/30 grams blocks which you can put on the bottom deck down the centre behind the servo saver. Just ask your local tyre centre...they might give you a weird look wondering what it's for but I'm sure they'll help you out.
Kennedy is offline   Reply With Quote
Old 06-21-2004, 09:15 PM   #7498
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
thanks kennedy
If you are happy with the car's balance then it's always a good idea to place weight equally around the car - that is if you can't place it all directly in the center of the car. It's not a bad idea to use parts that are stronger if you have room to spare on weight. Also, use steel screws in the bottom of the car - still a low cg but also stronger and less chance of a piece of weight flying out in a crash.... - J. Cyrul
S-T-R-l-K-E-R is offline   Reply With Quote
Old 06-22-2004, 12:11 AM   #7499
Kennedy's Avatar
Default Negative Castor
Me being the mong(aussie term) that I am I put the castor blocks on the Wrong sides thus giving me neg castor on the front blocks But I LOVE IT!!!! it's got so much steering it's beautifull!!! if any of you wanna experiment I suggest it
Old 06-22-2004, 12:13 AM   #7500
Already been done. Me no like.
