Old 06-21-2004, 01:40 AM   #7471
Trader Rating: 16 (94%+)
I've just finished building my FK (those shocks were a bitch), and now its time to wire up the elecs.
Does anyone have any pics of T1's running a Novak GT7? I'd like to see what options I have re. placement and wiring.
thanks
domo is offline   Reply With Quote
Old 06-21-2004, 01:58 AM   #7472
wrxmy99's Avatar
Originally posted by Vegetto
Thanks guys!!
Does anyone have a good indoor carpet setup?
I'm running Mod, the track is small and twisty...
Thanks guys
Ahhh mate....you've seen the light and come back to the fold. Good to see!
Sounds like you're after a setup for the indoors...well SHARE as I'm comin down again so get that spare room ready!
wrxmy99 is offline   Reply With Quote
Old 06-21-2004, 01:58 AM   #7473
Johnny J's Avatar
Here's mine
Ignore the ghetto switch
Johnny J is offline   Reply With Quote
Old 06-21-2004, 01:59 AM   #7474
Johnny J's Avatar
Motor
Old 06-21-2004, 02:19 AM   #7475
chambalero's Avatar
I don't know if anyone has posted this here earlier, but i've discovered that if I hold the flat spot of the shock shaft (opposite the side with the threads) with a vise grip, and thread the eyelet in, things would run smoother. Remember this is done before assembling the shocks. just keep on threading and un-threading the eyelet by using the shaft of an allen wrench through the "eye" of the eyelet as your lever. do this until it feels loose. after this, remove the eyelet from the shaft and assemble the shocks. you'll find that it'll be much easier to thread in the eyelet afterwards. I'm assuming this is where you're finding it tough to build the shocks i've popped the eyelet from the ballstud a few times during crashes but the eyelet has never stripped from the shaft, like what happened to some of my previous cars.
BTW, I've never had a car that handles as well as the FK and the quality is certainly the best i've seen. I'M AN XRAY FAN FOR LIFE!!!!
Striker, EVAA: How's the car bros?
chambalero is offline   Reply With Quote
Old 06-21-2004, 02:25 AM   #7476
chambalero's Avatar
Originally posted by evaa
congratulations on a very good purchase.
you sound like the first page of a manual
Old 06-21-2004, 02:30 AM   #7477
evaa's Avatar
you should know, ur a fan for life
by the way, as far as i can recall, the eyelet you busted while building the shocks was mine
car looks good, but dont know how it handles by the way, dont forget the graphite transponder holder, i'll get it from you on thu.
evaa is offline   Reply With Quote
Old 06-21-2004, 02:34 AM   #7478
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
do i smell another FK owner?
FK was hooked up at capitolyo. i joined mod class last saturday using my 19T motor. i still dont know the results are, but i finished 5th 1st heat, 3rd 2nd heat, and 2nd on the last heat of the mains.
my car is still underweight tho. need to put more grams into it to make the minimum requirement.
once again kudos to cyrul!!!!
S-T-R-l-K-E-R is offline   Reply With Quote
Old 06-21-2004, 02:53 AM   #7479
evaa's Avatar
WHO ME?
dude, i brought my car to the tracks last saturday and had it weighed, it tipped the scales at 1490 grams, despite all the stuff i put like bath tub tape and cone washers. any sugestions on how to add weight to the car without compromising its handling?
by the way, what was your car's eight when u ran it?
Old 06-21-2004, 03:05 AM   #7480
WHO ME?
at speedzone my car's weight was 1508g. at mang's it didnt even reach 1500g.
i asked the cyrul the same question i will tell you as soon as he answers me!
Old 06-21-2004, 03:52 AM   #7481
Caddzilla's Avatar
Send a message via ICQ to Caddzilla Send a message via AIM to Caddzilla Send a message via Yahoo to Caddzilla
I had to add a lot of weight to my car for the series that I race in. We have to weigh in at 53oz (1502.5g) so it took about 40 grams of weight to make weight for me. I just got the Xray chasis balancing weights and they did the trick for me.
Caddzilla is offline   Reply With Quote
Old 06-21-2004, 04:32 AM   #7482
rough512's Avatar
Somebody smells
rough512 is offline   Reply With Quote
Old 06-21-2004, 05:02 AM   #7483
sands's Avatar
What does front a-arm sweep do for handling? Can't remember.
Thanks!
sands is offline   Reply With Quote
Old 06-21-2004, 05:09 AM   #7484
Originally posted by Johnny J
Here's mine
Thanks Johnny, looks like the easiest way.
Pic of mine attached.
Old 06-21-2004, 05:41 AM   #7485
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
I did my first tests with the FK on saturday. Before I got the Xray a had an tc3. I must say I''m really impressed with the handling of the Xray. The car felt more precise, without tweak and had much more steering than my old TC3. That's good because I prefer slight oversteer over slight understeer.
Here's a pic of our track:
I started with Andreas' setup from last years euros. The car felt really good from the beginning. The steering was a bit touchy though, so I decreased the front toe-out before pack two and three. After that the car was easier to drive. I still had problems in the hair pin after the sweeper. The rear end suddenly broke loose in the middle of the corner. This was solved when I lowered the rear RC to the middle holes. This setup change also gave the car better corner speed, and I was able to lower the laptimes by 4 tenths. I lowered my previous track record with 6 seconds even though I dumped and lost 3 seconds on the last lap. I'm really excited with the new car and I'm looking forward to the euros in two weeks.
On to the questions:
My rear belt is really loose with the recommended belt tension setting, but the front one seems rather tight. What settings do you guys use?
What 's your experience with battery positions? I used the rear position on both sides, but I have noticed that many people have the batterys all the way up front at the left side.
Regards,
Arvid
Airwide is offline   Reply With Quote
